Fleabit peanut monkey
Had to look that one up. Wow and a big +1
Please disregard below. Field test of new computer. Sorry ![]()
1981 911SC Targa |
Sturmvogel
Yes, well. It is the tech forum, and my experience has been that every published wiring diagram for every German car I have ever owned has been wrong in minor or major ways. Sometimes the only way to figure out what the actual hell is going on is getting out a multimeter and tracing the circuit. Which is fun under the dash of a small Audi sedan, let me tell you.
Mighty Meatlocker Turbo
Across 20 years of combined ownership, no real AC problems, though.
1981 911SC Targa |
The lower 'bow tie' vent outlet in the bulkhead (firewall) behind center console can be a few degrees cooler. But, the evaporator core will usually be lower than your vent temp because of the distance and mass between the two. Digital thermometers tend to be more accurate than analog, however you might find an analog that's pretty close; analog units tend to be more accurate in the center of their range. If you go to a hardware store and see 25 thermometers (all the same model) in a point of sale display you'll probably find a few reading higher ambient temps and few reading lower. For what you have in mind you need a "Digital thermometer with remote probe". The wire on the probe to reach the evaporator core from the dash will probably have to be about 48" to make things easy. There are literally 100's of makes an models out there under $50.00. Some display just one value, some display 2 at once, some display ambient temp around the unit and some display both ambient at the unit and the remote value at the same time. ![]() ![]() If you look on ebay you can find a 12vdc thermostat you can mount in your center console (its an ugly hack) to replace the mechanical AC thermostat you now have to control compressor cycle. Lot's of things you can do, however the factory controls can be made to work if you understand them.
Kuehl 1987 911 cab, modified https://griffiths.com/ |
Sturmvogel
Sturmvogel
I mean, damn. I'm glad that Griff is here to help us sort out the AC part of it. |
I have to thank Corvus Corvax for his reference to the Dunning-Kruger effect. It should come in every owners manual for anything ever made.
AND part of the oath for any government official, elected or not. https://en.wikipedia.org/wiki/Dunning–Kruger_effect
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Sturmvogel
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/C circuit.
My factory A/C manual is spot-on.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Corvus Corvax,
With regard to the Dunning–Kruger effect, a rather bourgeois hypothesis for Cornell brats, do you suggest that: A) Readers on the forum could fall under such a spell, or B) A particular weasel has been infected with such, or C) It is a character of a the unnamed moderator, or D) It is alike Trumpitis however not chronic
E) All of the above . . . and then some! |
Sturmvogel
The moderator not taking action is curious to me. Its obvious to me that this person has a personal animus toward you, and he does nothing but ruin every single AC thread in failed attempts to discredit you. What benefit is there to PP in that sort of posting? I have no idea. I'd love to get a straight answer. But that's not an example of Dunning-Kruger, IMO. I enjoy reading about the effort people make to get this half-baked add-on to work well in a car that has a ton of greenhouse, no effective insulation, and very little frontal area to mount condensers to. I'd love to be able to do that without some self-absorbed doofus derailing every thread, spreading falsehoods and changing the subject endlessly. Even goat pr0n is preferable. |
I've read more than a few AC threads myself. WWest is quite a character. People who believe everything they read on the internet, might be led down the garden path by some of his concepts. I, on the other hand think that about 70% of what he says has merit. That's just my opinion. I think the other 30% is either wrong, or not applicable, or irrelevant. He does repeat the same ideas over and over, but I think he truly believes in what he is saying. Charlie Griffiths has very thick skin and I don't think he takes any particular heed of WWest. And BTW only about 70% of what I say is worthy, so WWest ain't so bad. Good luck, Dave ![]()
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Sturmvogel
I'd advise rolling with the punches. The real information eventually rises to the surface.
Thanks, Dave
Sturmvogel
Tom 79 911 SC |
Tags |
air conditioning |
