So where do the ignition wires go on the distributor cap?
Changing out plugs and ignition wires on my 1973.5T (2.4 liter/CIS) when suddenly I realized I could not figure out where the ignition wires go on the distributor cap! I pulled several off without marking. Pretty stupid!
Anyone have a mapping on the distributor cap of the order? I do not expect Bosch to be thoughtful enough to stamp numbers on the caps by the cylinder firing order like most others. Lends to confusion otherwise.
Bob
1973.5T
Old 04-24-2016, 08:54 AM
Off the top of my head ...1-6-2-4-3-5. the arrow on the distributor will indicate clockwise or CCW rotation. There is a notch on the lip of the distributor under the cap to indicate where cylinder # is connected.
There is also an engine bay sticker that shows the firing order.
Best of luck,
Rahl
Here is the sticker...don't know if it will show.
https://tse1.mm.bing.net/th?id=OIP.M6f71f2fbc19494029c4524a7729ce11ao0&w=140&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2
Old 04-24-2016, 09:06 AM
I have that order by cylinder relative to engine order, but need to map on the distributor cap. That is where my inexperience comes into play.
Old 04-24-2016, 09:11 AM
That is the firing order so, assuming you have a Bosch distributor in clockwise rotation, wires go 1-6-2-4-3-5.
If you are standing in back of your car, cylinders are 123 on the left bank, 456 on the right bank.
Cylinders 1 and 6 are the ones closest to your legs on either side.
Usually cylinder 1 is marked on the top of the cap. If not, on a Bosch cap it is the one below the right hand clip.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 04-24-2016, 09:50 AM
Mike80911's Avatar
First you need to find TDC on the number 1 cylinder to establish where to place the first wire on the cap.
89 930 Cab Black
11 Cayenne
Old 04-24-2016, 09:53 AM
So starting at 1 go clockwise with 6 then 2 then 4 etc.
If you have a Marelli distributor I think they go Counter clockwise. You can verify by watching which way the rotor goes while cranking the engine. Just to be sure.
1991 C2 Turbo
Its a Bosch distributor.
Old 04-24-2016, 10:29 AM
I'd still double-check rotation with cap off. Just to be sure.
1991 C2 Turbo
Old 04-24-2016, 10:37 AM
pete3799's Avatar
Cylinders 1 and 4 are at the rear of the car.
Pete
79 911SC RoW
Old 04-24-2016, 10:39 AM
Pete is correct, brain f*rt. sorry.
1991 C2 Turbo
Old 04-24-2016, 10:50 AM
quote:There is a notch on the lip of the distributor under the cap to indicate where cylinder # is connected.
This should have read: There is a notch on the lip of the distributor under the cap to indicate where cylinder # 1 spark plug wire is connected to the distributor cap.
Hope this helps,
RAhl
1 is the first one after the clip.
1991 C2 Turbo
Old 04-24-2016, 11:10 AM
Thanks.
I found a photo of the cap ignition wire set up and according to the line up, Number 1 is to the right of the retention clip (on the above photo) followed (working clockwise looking down), 6, 2, 4, 3 and 5. I will give it a go....................
Bob
Old 04-24-2016, 01:08 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dizzy.
Does this help?
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-24-2016, 01:18 PM
Thats a beautiful thing.......................................
Thanks Gerry
Bob
Old 04-24-2016, 04:12 PM
Damn engineers, they make things so clear!
1991 C2 Turbo
Old 04-24-2016, 04:54 PM
Senior Advisor
James Brown's Avatar
B e n t l e y
08 Cayenne Turbo
Old 04-24-2016, 08:49 PM
