Part no for flex hose at smugglers box
Does anyone have a part number for the approx 3" dia flex hose that connects to the evap blower in the smugglers box and goes towards the dash. Must be all of an inch long.
Old 05-25-2016, 08:01 PM
Member 911 Anonymous
DRACO A5OG's Avatar
That one is a hard item to find.
I used HVAC dryer hose from hardware store. You could go to a Aircraft Spruce type store, they may have it.
'85 Carrera Targa
PCA/POC
Old 05-25-2016, 08:09 PM
I bought this hose, fits very well: 28mm x 24mm Flexible Bellows Hose Pipe Wire Protect Corrugated Tube 4 6M Long | eBay
Old 05-25-2016, 08:26 PM
My PET lists this as 911-571-240-01 for my 87 Carrera and PP indicates that it has been updated to 911-571-240-02 for a 74-89 911.
Old 05-25-2016, 11:14 PM
Thankyou Harold. Are you sure this is the right hose. The hose I need is only about 1-1/2" long. When I look up that part number it looks like a much longer hose.
Old 05-26-2016, 06:06 AM
This one here.... you can almost see the other clamp, shows you how short this hose is.
Old 05-26-2016, 06:11 AM
I'm sure based on comparing the PET diagram and what is on my car. You could confirm with PP or by checking page 364 from this PET,http://www.porsche.com/all/media/pdf/originalparts/usa/911_USA_87_89_KATALOG.pdf. The Air Distributor, Gasket and Connecting Piece are very distinctive.
Old 05-26-2016, 06:47 AM
Andy,
I'm in the process of converting my A/C system from R12 to R134 and received the replacement hose from Griffiths but it did not have a part number on the package. To replace mine, I used a tie wrap on one side and spun it around to check the fitting. It's a tight fit.
Harold
Old 05-26-2016, 06:59 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Andy,
911-571-240-02
It is the correct P/N.
I bought one last year when I replaced the A/C in our 3.2.
I did have to cut off about 2 inches.
Tight, but great fit no problem.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-26-2016, 09:33 AM
911-571-240-02
Correct P/N.
Gerry
1986 911 Targa.
Only in L.A.:
Old 05-26-2016, 09:36 AM
DRACO A5OG's Avatar
Originally Posted by 86 911 Targa View Post
911-571-240-02
Correct P/N.
Gerry
Please show me when I see you next :-)
The PAG diagram is horribly not to scale.
Oh wait, if the same as in the pic above, Thanks Doc, time to change my dryer hose :-P
'85 Carrera Targa
PCA/POC
Old 05-26-2016, 10:27 AM
Wait, do you guys have a collapsing/wire wound hose there? Mine is a thicker rubber piece, like the rubber connectors between the CIS airbox and intake runners which is a bear to get connected on both ends. Is mine non-stock?
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 05-26-2016, 12:37 PM
My old one, from what I could tell from it's remains, was a wire spiral hose.
It has crossed my mind just to pick up some 3" dryer hose. I don't think it's hot air there or anything. it's not doing much of a job really.
anyway - looks like we are in agreement about the part number. Thank you everyone.
Old 05-26-2016, 01:10 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Let me check I might still have the one I remove which you could have for the cost of shipping or free pick up in Ottawa.
Who Will Live... Will See
Old 05-26-2016, 04:11 PM
That would be superb.
Old 05-27-2016, 06:37 AM
JJ 911SC's Avatar
Found it (after opening the 10th bin). Not perfect but its still would be functional. The inside diameter is 83.5mm (~3.25").
It yours for free but the only problem is that I dont think Post Canada has anything less then $12 shipping for small box. Any other way I can get it to you?
Old 05-27-2016, 10:36 AM
Thank-you so much for digging that out. I found one here in Winnipeg on this morning so I took it. I really appreciate you digging it out though. And yes, Canada post is not cheap.
Old 05-28-2016, 11:26 AM
JJ 911SC's Avatar
Good for you.
One day, when I'm retired (13 months to go), I will spreadsheet the 20 bins so I don't have to go through all off them when I look for something
Old 05-28-2016, 12:48 PM
ooh - must be ace to be retired! Congrats.
Old 05-30-2016, 08:56 AM
