Send a message via Skype™ to kyngfish
Where to Test Oxygen Sensor
Hi All, I've been poring through old threads trying to find a picture of where to test the oxygen sensor. I have a Fluke Digital Multimeter ready to go.
I need to connect the positive to the signal wire, and the negative to the ground, while the engine is hot to test the sensor. That much I know. The only thing is, where is the sensor wire and which is the signal wire?
Thanks!
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 06-20-2016, 02:48 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Thanks!
I believe that pins 2&3 are the heater 1 is the signal wire to pin #24 of the DME.
Your voltages should fluctuate between .1-.9 VDC
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-20-2016, 03:25 PM
Cool. Thought there was a way to test in the engine bay?
Old 06-20-2016, 03:34 PM
wrxnofx's Avatar
You should get a Bentley manual...
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 06-20-2016, 04:14 PM
Lol
Between the fluke multimeter a wide band oxygen sensor and a Bentley manual I'll be spending nearly a thousand this week just on tools! Thanks for the photo. Care to tell which is the ground?
Old 06-20-2016, 06:27 PM
T77911S's Avatar
it does not matter. just forget about the - or swap the leads if you don't want to see the - if you connect it backwords
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-21-2016, 03:47 AM
(Thumbs Up)
Old 06-21-2016, 04:34 AM
This is going to sound like a really stupid question, but I'm REALLY new to all this. The Fluke has a setting for Volts DC or AC - I'm assuming that because the car uses a chemical battery, that the Alternator is also generating DC current and I should always test using the DC setting.
Correct?
Old 06-21-2016, 07:47 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Dc.
'85 Carrera Targa
PCA/POC
Old 06-21-2016, 08:35 AM
Thanks!
Old 06-21-2016, 08:36 AM
DRACO A5OG's Avatar
M,
In the pic above, you want to connect the Red lead from your DVM using alligator clips to post #1, on the connector going to the O2S and the Black lead to a good ground on the engine.
You want to do this when the engine is hot or at 194F aka Operating Temps.
At DC, note the voltage.
'85 Carrera Targa
PCA/POC
Old 06-21-2016, 08:40 AM
I am trying to follow the math
Bentley $150 USD
Multimeter $5.00 to $50 for a good one.....Fluke $400 usd
Wide band o2 sensor $90 [but what do you need this for?
so I am up to $200 on the low side for stuff that works??
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 06-22-2016, 02:18 PM
LM-2 Wide Band Oxygen Sensor 300
I have several things happening at once
Add CHT to the list
Old 06-22-2016, 02:29 PM
