-   -   Post your ITB Setup (http://forums.pelicanparts.com/porsche-911-technical-forum/925845-post-your-itb-setup.html)
Jjm4life 01-07-2023 12:46 PM
Originally Posted by MrBonus (Post 11890329)
Damn, that thing is a work of art.
thanks a lot. im hoping it runs as good as it looks
wallra 01-07-2023 01:03 PM
here is my 964http://forums.pelicanparts.com/uploa...1673125240.JPG
MrBonus 01-08-2023 06:47 AM
Originally Posted by ToySnakePMC (Post 11890575)
Love seeing updates and pics on this thread - one of my favorites. Planning to sneak by the shop and see Mr B’s air cooled toy sometime this coming week.
Sweet! It’s running and waiting for fine tuning on the dyno.
thetorch 01-08-2023 07:53 AM
1969 911T
3.4 liters
Rasant throttle bodies, crank and cam sensor
Modified 964 intake
Motec M84
http://forums.pelicanparts.com/uploa...1673193149.jpg
PeteKz 01-09-2023 12:39 PM
Side question: I have the complete carburetors (40IDTP.3C), throttle linkage, air filter box, etc. system from a 1969 911. I have listed it for sale in the local PCA region, to clear it out of my garage. I have CIS on my 3.2 engine in a 1973 911T, which I like, but sometimes I wonder about installing an ITB FI system. Would there be a good reason to keep the air filter box from the 1969 carb setup for future ITB system? Or should I just sell the whole carb setup complete and buy what I need if/when I go to ITBs?
MrBonus 01-09-2023 12:45 PM
My Clewett system came with its own filters and hats. My exact same carburetors will be sold with their air filter and hat setup.
rswannabe 01-09-2023 01:30 PM
The 40mm carb manifolds, linkages, and air box would all be usable with a set of 40mm PMO itb’s. They won’t work with any itb’s other than PMO though. The linkages and airbox can also work with 46mm pmo itbs. I run just that setup on my 2.8 short stroke motor in my ‘69. I’m a fan of running the old airboxes, but I’m in a minority there I think.
You could sell the whole setup and just buy what you need at the time if you ever go to itb’s.
Showdown 01-15-2023 04:32 PM
https://uploads.tapatalk-cdn.com/202...b9d1aee202.jpg
RHD ITBs running Megasquirt.
Otherwise stock engine for now (Melissa/M1 cams to come…?)
Plenty of custom fabricated/modified bits and pieces.
Hulley 01-15-2023 05:05 PM
Looks great, Julian, love your build!
r_towle 01-16-2023 09:44 PM
Originally Posted by Clay Perrine (Post 11727984)
I recently purchased a 935 Style flat fan for my 4.0L 964 motor. So now I can't use the factory intake or throttle body assembly. So I decided to go ITBs, coil on plug, and MS3Pro injection.
I found two sets of BMW K1300S Motorcycle throttle bodies that came like this:
http://www.914world.com/bbs2/uploads...1656292307.jpg
I cut them apart into individual throttle bodies, removed the studs and tapped the stud holes to M6x1.0.
I already had a set of MFI throttle bodies that were so corroded that they could not be saved. So I removed the throttle shafts and linkage from the MFI throttle bodies. I opened the slots on the shafts, and the BMW throttle butterflies fit perfectly. I had to cut the end off the shaft from one of the BMW throttle bodies and weld it onto the MFI throttle body shaft so I had a TPS drive. I pressed the cross shaft bearings out of the plastic MFI stacks for reuse as well.
Using a sheet of plywood, I built a jig to hold the throttle bodies in place with the fan so I can build the linkage and wiring harness before tearing apart the current Motronic setup.
Some time spent with Fusion 360 and a purchase from Send Cut Send, and I now have this:
http://www.914world.com/bbs2/uploads...1656292090.jpg
http://www.914world.com/bbs2/uploads...1656292108.jpg
http://www.914world.com/bbs2/uploads...1656292120.jpg
http://www.914world.com/bbs2/uploads...1656292135.jpg
I still have to make the correct length linkage to go from the crossbar to the center throttle bodies. And to do that I have to buy a M5x0.8 left hand thread die. I considered drilling the throttle bodies for idle air bleed screws, but I can compensate for that with the MS3Pro programming.
This setup is going in my 914 chassis, so it will actually go in with the crossbar at the flywheel end of the motor. I am going to make a throttle cable mount that will attach to the 4-6 side throttle bodies so I can hook directly to the crossbar with no additional linkage.
Clay,
Where did you get the fan shroud?
ChrisHoover 01-17-2023 01:48 PM
Originally Posted by chrisbalich (Post 11357073)
There's been a lot of discussion about power increases (expected vs realized) and about drivability.
But I just got back from a 60 car rallye in the mountains of WV and I can assure you all of the ITB/EFI guys got markedly better fuel economy than the CIS guys. Doesn't sound that important until you get to the bottom of the mountain on Monday morning to tank up and head home and find there is no gas at the station. I wasn't worried as I knew my 1/2 tank would easily get me to the next station. My friend next to me in a CIS car was worried. (we did both make it to the next fuel station)
The main reason I’m interested in ITBs is fuel economy. My 1966 2.7l weber 40 gets 16 mpg. Any idea how much an improvement ITBs will offer?
na2ub 01-26-2023 05:10 PM
Where is everyone running their O2 sensor into the engine compartment? I have a ‘79 with no prev O2. Through the engine tin? Thanks! Gratuitious pic of my almost ready to install engine. http://forums.pelicanparts.com/uploa...1674781828.jpg
rwest 01-26-2023 05:18 PM
Doug,
I ran my O2 alongside the left hand heater hose by undoing the hose and feeding either end through the hole and then it’s just the wire thickness alongside the hose.
SiracHaile 01-26-2023 05:38 PM
What is everyone using for cylinder head temperature sensors and mounts.
I’ve seen the one on Turbokraft but it’s very expensive. Any other alternatives?
Showdown 01-27-2023 05:40 AM
Check out Chris’ Low Budget Dream Car Build thread; he fabricated one fairly easily (I think it was last winter or spring) and thus far it’s proven to be quite effective.
MrBonus 01-28-2023 05:53 AM
Just got my car back from Erik at Sport Purpose Garage who installed and tuned my Clewett ITBs with Masters ECU. 160 WHP but way, way better road manners and torque, especially at partial throttle. Super super happy with how this turned out versus my old Webers.
If you're looking for someone to install and tune one of these setups, I'd highly recommend him. Super communicative, works very fast, and does fantastic, clean work.
http://forums.pelicanparts.com/uploa...1674913921.jpg
Mixed76 01-28-2023 07:56 AM
That's a very clean setup.
Sent from my Pixel 7 using Tapatalk
cmpski 01-28-2023 08:11 AM
There is a lot of beautiful eye candy on this thread!
Here is my POLO 4 banger built in 2011. It has 23,000 miles on it now.
The latest ones being built by tuners like Jerry Woods and others are now getting 230 to 250 hp. See the second set of numbers.
The upper graph is of an engine speced close to mine. Mine has had head work done to my 993 heads with titanium valves and the dynoed engine has stock 993 heads. Dean guessed this engine makes maybe another 10 to 15 hp.
I've tried to keep a period look in my 67. Here is a newer vintage look product from Jenvey.
https://store.jenvey.co.uk/heritage/heritage-ida-pair-throttle-bodyhttp://forums.pelicanparts.com/uploa...1674922099.JPG
http://forums.pelicanparts.com/uploa...1674922099.jpg
OSC911 01-28-2023 02:16 PM
Lost for words, that is absolutely beautiful.
Jim2 01-28-2023 07:20 PM
Never get tired of seeing pictures of your engine. What displacement is your engine, and the 249 HP engine in the second graph?
cmpski 01-28-2023 08:23 PM
Mine is a 2.4 the 250 hp engine is a 2.5. Mine has 11.2 CR the 2.5 11.6 I think. I have a Webcam 993 Super Sport grind. I think the 2.5 is similar to a DC44 grind. Mine ported 993 heads with Ti valves. The 2.5 has Extreme custom heads. The 2.4 has Electromotive Tec-GT ECU. The 2.5 newer Motec.
It appears Electromotive is out of business as is Rasant. Bummer.
Jim2 01-29-2023 07:55 AM
Pretty impressive numbers out of those small displacement engines.
Phoenix 01-29-2023 03:48 PM
I went PMO EFI and couldn't be happier...
http://forums.pelicanparts.com/uploa...1675035942.JPG
Engine Build:
• LN Engineering custom 93mm Mahle Pistons for 9.8:1 compression ratio
• LN Nickie Cylinders
• Existing 70.4 stroke
• DC 40 cam
• Pauter rods
• ARP rod bolts
• Port heads to 35mm Exhaust
• Port heads to 36mm Intake
• Valves ground and lapped
• PMO EFI system
• Clewett EFI management system
• Oil pump: rebuilt by Glenn Yee Motorsports
• 3.2 Carrera front oil cooler with factory brass lines
• High pressure fuel pump
• ARP head studs
• Engine Case machined by Ollie’s
o Time-cert threaded inserts/ case savers
o Shuffle pin case to reduce flex & movement
o Reinforcing weld @ #3 cylinder
o Oil squirters
• Aluminum pressure plate
• ARP flywheel bolts
• Narrowed air deflectors
• Club Sport engine mounts
911MANN 01-29-2023 04:10 PM
Phoenix- Glad to see you are keeping your AC compressor with your ITBs! You seem to be in a well-respected minority!
Jim2 01-29-2023 04:20 PM
Warmed up 3.0 with TWMs going into my 914 project. Running by spring.
http://forums.pelicanparts.com/uploa...1675037725.jpg
Uwon 01-30-2023 05:14 AM
Engine Build:
• DC 40 cam
• Pauter rods
• ARP rod bolts
• PMO EFI system
• ARP head studs
o Oil squirters
Looks like a great build.
Can you expand on your starting point? Was it a 2.4?
Can you expand on the EFI used?…….you mention both Clewett EFI and PMO EFI.
TIA
Johan
pampadori 01-30-2023 11:51 AM
Those TWM/Borla throttle boddies and the PMOs are my favorites. They're cast and so they don't have that bling machined look. They also have very stable/static linkage setups. I would love to come across a set.
TopTuning 01-30-2023 03:19 PM
Random photo dump of my drive by wire ITB turbo setups!
(I make and sell these affordable ITB kits if anyone is interested, just message me)
http://forums.pelicanparts.com/uploa...1675120601.jpg
rswannabe 01-30-2023 04:27 PM
Wow! Super impressive. Beautiful equipment and the performance must be stonking.
At first I thought that was a massive fuel line running across the top of the fan shroud before I realized they were intercooler coolant lines.
Showdown 01-30-2023 04:54 PM
I covet that flat fan.
Phoenix 01-30-2023 06:03 PM
TIA
Johan
Hello Johan,
The starting point was indeed a 2.4 with PMO carb induction. This was switched to PMO EFI units using a Clewett engine management set up (computer brain). We were able to keep some of the PMO carb linkage and modify a few bits. This is a much more reliable system also providing the ability to fine tune along the full rev range.
TopTuning 01-30-2023 07:03 PM
Thank you sir!
It's been a long development process that's still going. The performance is absolutely fantastic!
The water to air intercoolers are better than any of the air to air (over the engine) setups by an order of magnitude.
* NO heatsoak at all!
* Normal driving sees intake air temps basically ambient in boost
* Hard driving sees a few degree rise over ambient in boost, after a while.
* Water temp cools back down very quickly.
* Engine cooling fan is completely unobstructed
* Easy to work on anything in the engine bay!
The only way to go.
al lkosmal 01-31-2023 08:21 AM
Top Tuning...... absolutely awesome!
regards,
al
shamrok 01-31-2023 12:01 PM
(I make and sell these affordable ITB kits if anyone is interested, just message me.
Holy crap.
TopTuning 02-01-2023 12:06 PM
Also make NA setups as well of course!
http://forums.pelicanparts.com/uploa...1675281977.jpg
BoxsterGT 02-15-2023 12:20 PM
Top-
Are those some type of Plastic Intake manifolds? Are they printed or cast?
Len
Porkshop 02-15-2023 04:19 PM
how much are they? You can message me if you want, Or I will message you....Thanks
TopTuning 04-07-2023 02:06 PM
Originally Posted by BoxsterGT (Post 11924077)
Top-
Len
The parts that bolt to the engine are CNC aluminum. Adapters for air filters currently all ABS plastic (works great)
CNC parts for air filter adapters available
Turbo parts are all CNC!
Some pictures of the latest setup:
http://forums.pelicanparts.com/uploa...1680900965.jpg
http://forums.pelicanparts.com/uploa...1680901123.jpg
http://forums.pelicanparts.com/uploa...1680901168.jpg
http://forums.pelicanparts.com/uploa...1680901194.jpg
al lkosmal 04-09-2023 10:35 AM
RHD testing
Fire up/test of 3.2SS build with x-faktory/RHD EFI, Megasquirt etc.
<iframe width="839" height="629" src="https://www.youtube.com/embed/6NcE3cPvosQ" title="3.2SS...ready to ship" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
regards,
al
TopTuning 10-21-2023 02:08 PM
e-ITB setup going on a real 906!
http://forums.pelicanparts.com/uploa...1697922209.jpg
