Interesting and thanks. Yes, I will be dropping my 3.2 targa off this Saturday for Al to install his Option 2 EFI ITB kit with rain hats.
Scott Quote:
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now - 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs |
83 911 Production Cab #10
I just switch from the rain hats...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Why? Did they not work well? Not sure if those ITG filters will fit Al's kit. Where did you get them?
Thanks, Scott [/QUOTE]
Guess your setup kinda goes like this. With all other things being the same If you want to get more power at higher rpm's then use shorter length yet wider intake runners ... If however you are wanting more power and response at overall lower rpm's then use longer intake runners that are more restrictive / narrower to create a more turbulence effect for increased airflow /velocity.
antares fatnwide - uncle dave 79 steel wide body Targa / euro 915 oil cooled LSD / SSI's / RUF 8 & 10's / Monty M22 / Alum flywheel plus lots of other silly little mods n upgrades |
Previous versions...
Rain Shield ![]() Race Top ![]() Flat Top Filter on Flute ![]() Half Tea Ball Filter on Flute
Racer
The ITG filters seem to make the most power while still providing enough filtering.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
A few years ago we had a 3.5 on the dyno with PMO ITBs. We had the chance to dyno 2 different set ups. I don't have the sheets, like I said, it was a few years ago. But, we tested the often thought of restrictive "rain hat" set up vs open velocity stacks with no filter. The thought of "worst" vs the "best" in terms of power. We saw no measurable difference on that particular motor. Yes, one sample size done back to back within an hour of each run. We did post something regarding that tidbit at the time. For years there was lots of hyperbole about what filter flowed best and what cost you power. Lots of "white paper" type thinking. So we had the chance to do a ONE time test with ONE motor combo, so we did.
A filter on an ITB motor hurting performance means everything else in the complete engine system is dialed to 110% and drawing more air than the filter can deliver without restriction. I wish we still had the dyno plots. Maybe we will going forward with engines that see the dyno... Anyways, food for thought.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
What’s the consensus of shaftless (AT Power) versus others with a shaft/butterfly?
Racer
You mean these:
![]() They work really well. What is your application?
Street stock Euro 3.2. Want reliability but miss the sound of the Weber’s
Racer
They won't pass the visual inspection CA smog...is that an issue?
Racer
That's cool.....
I would contact William Knight (knightrace at mac.com). He can tell you what ITB size (I assume 42mm) and intake port size would work best and get your a quote.
Do you have an EFI ITB kit from x-faktory / Al? How well do the ITG foam filters hold up to keeping rain out of the intakes? Does the foam get saturated in a heavy rain?
Thanks, Scott Quote:
Hi Scott,
My kit are PMO EFI. As for the ITG foam filter, it will be the first time I will run them on the road. As for water in the rain... I drove with the top down in a piss down rain at 60 mph and thanks to physic, I did not get a drop in the cab so I doubt anything happened in the engine bay. JJ
Dean
Dean |
Racer
I have other photos but no build thread. What, specifically, are you interested in seeing?
And so it begins...
![]() ![]() FYI, I will be selling the following from this upgrade: - basically everything you see removed between the two pictures (the full euro factory intake system with the aftermarket filter and tube) - DME, wiring harness and Steve Wong euro chip Send me an email if you are interested to purchase the above, Scott
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
