-   -   Post your ITB Setup (http://forums.pelicanparts.com/porsche-911-technical-forum/925845-post-your-itb-setup.html)
cmpski 01-28-2023 08:23 PM
Mine is a 2.4 the 250 hp engine is a 2.5. Mine has 11.2 CR the 2.5 11.6 I think. I have a Webcam 993 Super Sport grind. I think the 2.5 is similar to a DC44 grind. Mine ported 993 heads with Ti valves. The 2.5 has Extreme custom heads. The 2.4 has Electromotive Tec-GT ECU. The 2.5 newer Motec.
It appears Electromotive is out of business as is Rasant. Bummer.
Jim2 01-29-2023 07:55 AM
Pretty impressive numbers out of those small displacement engines.
Phoenix 01-29-2023 03:48 PM
I went PMO EFI and couldn't be happier...
http://forums.pelicanparts.com/uploa...1675035942.JPG
Engine Build:
• LN Engineering custom 93mm Mahle Pistons for 9.8:1 compression ratio
• LN Nickie Cylinders
• Existing 70.4 stroke
• DC 40 cam
• Pauter rods
• ARP rod bolts
• Port heads to 35mm Exhaust
• Port heads to 36mm Intake
• Valves ground and lapped
• PMO EFI system
• Clewett EFI management system
• Oil pump: rebuilt by Glenn Yee Motorsports
• 3.2 Carrera front oil cooler with factory brass lines
• High pressure fuel pump
• ARP head studs
• Engine Case machined by Ollie’s
o Time-cert threaded inserts/ case savers
o Shuffle pin case to reduce flex & movement
o Reinforcing weld @ #3 cylinder
o Oil squirters
• Aluminum pressure plate
• ARP flywheel bolts
• Narrowed air deflectors
• Club Sport engine mounts
911MANN 01-29-2023 04:10 PM
Phoenix- Glad to see you are keeping your AC compressor with your ITBs! You seem to be in a well-respected minority!
Jim2 01-29-2023 04:20 PM
Warmed up 3.0 with TWMs going into my 914 project. Running by spring.
http://forums.pelicanparts.com/uploa...1675037725.jpg
Uwon 01-30-2023 05:14 AM
Engine Build:
• DC 40 cam
• Pauter rods
• ARP rod bolts
• PMO EFI system
• ARP head studs
o Oil squirters
Looks like a great build.
Can you expand on your starting point? Was it a 2.4?
Can you expand on the EFI used?…….you mention both Clewett EFI and PMO EFI.
TIA
Johan
pampadori 01-30-2023 11:51 AM
Those TWM/Borla throttle boddies and the PMOs are my favorites. They're cast and so they don't have that bling machined look. They also have very stable/static linkage setups. I would love to come across a set.
TopTuning 01-30-2023 03:19 PM
Random photo dump of my drive by wire ITB turbo setups!
(I make and sell these affordable ITB kits if anyone is interested, just message me)
http://forums.pelicanparts.com/uploa...1675120601.jpg
rswannabe 01-30-2023 04:27 PM
Wow! Super impressive. Beautiful equipment and the performance must be stonking.
At first I thought that was a massive fuel line running across the top of the fan shroud before I realized they were intercooler coolant lines.
Showdown 01-30-2023 04:54 PM
I covet that flat fan.
Phoenix 01-30-2023 06:03 PM
TIA
Johan
Hello Johan,
The starting point was indeed a 2.4 with PMO carb induction. This was switched to PMO EFI units using a Clewett engine management set up (computer brain). We were able to keep some of the PMO carb linkage and modify a few bits. This is a much more reliable system also providing the ability to fine tune along the full rev range.
TopTuning 01-30-2023 07:03 PM
Thank you sir!
It's been a long development process that's still going. The performance is absolutely fantastic!
The water to air intercoolers are better than any of the air to air (over the engine) setups by an order of magnitude.
* NO heatsoak at all!
* Normal driving sees intake air temps basically ambient in boost
* Hard driving sees a few degree rise over ambient in boost, after a while.
* Water temp cools back down very quickly.
* Engine cooling fan is completely unobstructed
* Easy to work on anything in the engine bay!
The only way to go.
al lkosmal 01-31-2023 08:21 AM
Top Tuning...... absolutely awesome!
regards,
al
shamrok 01-31-2023 12:01 PM
(I make and sell these affordable ITB kits if anyone is interested, just message me.
Holy crap.
TopTuning 02-01-2023 12:06 PM
Also make NA setups as well of course!
http://forums.pelicanparts.com/uploa...1675281977.jpg
BoxsterGT 02-15-2023 12:20 PM
Top-
Are those some type of Plastic Intake manifolds? Are they printed or cast?
Len
Porkshop 02-15-2023 04:19 PM
how much are they? You can message me if you want, Or I will message you....Thanks
TopTuning 04-07-2023 02:06 PM
Originally Posted by BoxsterGT (Post 11924077)
Top-
Len
The parts that bolt to the engine are CNC aluminum. Adapters for air filters currently all ABS plastic (works great)
CNC parts for air filter adapters available
Turbo parts are all CNC!
Some pictures of the latest setup:
http://forums.pelicanparts.com/uploa...1680900965.jpg
http://forums.pelicanparts.com/uploa...1680901123.jpg
http://forums.pelicanparts.com/uploa...1680901168.jpg
http://forums.pelicanparts.com/uploa...1680901194.jpg
al lkosmal 04-09-2023 10:35 AM
RHD testing
Fire up/test of 3.2SS build with x-faktory/RHD EFI, Megasquirt etc.
<iframe width="839" height="629" src="https://www.youtube.com/embed/6NcE3cPvosQ" title="3.2SS...ready to ship" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
regards,
al
TopTuning 10-21-2023 02:08 PM
e-ITB setup going on a real 906!
http://forums.pelicanparts.com/uploa...1697922209.jpg
