ATPower - this 964 package looks good
https://www.atpower.com/products/porsche-964-plug-and-play-throttle-body-kit
Shirish 1987 Carrera, Granite Green |
Work in progress
Hmm would think 48 mm is a little small for a 3.8 seems 50 is a better choice at least for a track Porsche with all your mods
I wonder how durable the rp intake runners are.
Can you please post a few pics of what's under the foam and the underside of the foam?
Tru6 Restoration & Design |
[/QUOTE]Tav, that photo won't help with the down under jokes.
81SC Coupe Tony Kart/Yamaha |
83 911 Production Cab #10
LMFT4U...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thank you, this pic helps. Interested to see how the foam fits over these.
Hello TAV - the trumpet design looks very different from the ATPower ITBs I have seen which have the usual vertical stacks. What’s the reason behind the curved intake?
Mine. 3.2 short stroke, twin plug. Not quite finished in the pic.
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
Apparently they did some testing with different Inlet tube lengths to give a preferable lower end torque as well. The length they came up with would not fit in the engine bay, hence the curved inlets.
What cams, what size ITB, and who's control unit/ECU.. nice job too!
RGruppe #180 So many cars.. so little time!! |
The engine build and management system is by Rasant Products in Southern California. Cam is GT2 Evo with 108 center. Pauter rods, 10.5:1 CR. I don't have the ITB size at hand, I'll look for it.
Awesome thread!
Nice clean install - like
