AC Compressor Temperature
Saturday when I was trying to chase down the reason for the fuse on the AC relay in the smugglers box burning I was using my IR thermometer to check the temperature on the wires and fuses. I happened to shoot the AC compressor while it was running and the temp was around 150 degrees on the body of the compressor while the surrounding surfaces were in 110 range. That struck me as high but is it really? does anybody know what temperature a Sanden 507 style compressor should run at? Ambient temp was about 95 and the car windows were open.
i just got a inferred therm as well and did the same thing, also got about the same reading and I recall seeing somewhere else that thats about the expected temp. seems a little high to me. Mine is a 508 so very similar
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Fuse.
I posted a fix a while back. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Check the fuse contacts for corrosion. Use a ceramic (not plastic) 25 amp fuse. Next, check the spade terminals for the primary ac relay you have, clean any corrosion, cut back burnt wires. A 20+ amp relay is preferred. Next, check how many amps your evap motor is drawing (an inexpensive analog 0-25 amp meter in line works fine) wired directly to the battery for full fan speed and then through fan speed switch's 3rd speed. Well you are putting a heavy load on the evap coil running windows open, but 150F (give or take because of IR emissivity) is fine (safe at 95F ambient).
Kuehl 1987 911 cab, modified https://griffiths.com/ |
I've seen comp temps near discharge port at 160. Guessing ambient was 90'ish.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
If you think about it, R134a at a discharge pressure of 265 psi is 150F, while in at a suction pressure of 30 psi 35F.
And, when you look out the windshield and you see rain drops hitting it then you know its raining, or maybe a United Air dumped its grey water tank to save some fuel.
Thanks for the responses, the fuses and the wiring all look very good and the wiring going to the evap fan was not getting hot so I replaced the crappy relay with the built in 15 amp fuse with a new bosch relay and the high temps I was seeing in the wiring to the relay and at the two fuses dropped from 140 degrees down to 100 so I think I found the culprit.
When I started checking temps of different things on the car while I was waiting to see if the new relay cured my problem I was a little surprised at how hot the compressor ran which I now know is normal |
Its more fun to look at the exhaust header temps.
![]() If you get the AC tuned up and working at peak capacity the incoming refrigerant can help cool the compressor. This was on a 90 degree day after a 30 minute drive.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Random Pics
Drier temp 118.6F operating ![]() Evaporator outlet pipe 30F operating ![]() Kuehl Center Vent 32F
GH85, apparently I have some work to do because mine is definitely not that cold on the inlet side!
Kuehl, very Kuehl pics! makes it much easier to understand the refrigerant flow through the system |
I suspected I had a leak in the system because my vent temps have been creeping up all summer long, guess it's time to break out the gauges for a quick look see!
^^^ Wydbod... Might want to take a look at underside of evap. (Look through passenger side intake. Put small camera in to pic it... or mirror.) Debris combined with condensate algae growth here in FL is temp killer.)
Looks like our host has the Porsche one but it's a 15A plastic fused one. ![]() A/C Relay 91161510301 - Genuine Porsche - 911-615-103-01 | Pelican Parts Other related question- does this relay power everything electrical downstream in the AC system? I ask because I have an intermittent scenario where my condensor fans and evap fan are blowing, but my compressor clutch is not getting power and I obviously do not have cold air. Very intermittant... wondering if that's possibly related to this relay or, if "fans running" means the relay is exonerated and my intermittant connection is elsewhere.
Ken 1986 930 2016 R1200RS |
You simply need a standard 5 pin, spdt, 12vdc, relay, commonly used for AC and things like aftermarket fog lights, etc.
It is more common to find 25,30 or 40 amp, either will work just fine The pin outs are as below ![]() maybe Pelican has one under a different PN
Kuehl 1987 911 cab, modified https://griffiths.com/ Last edited by kuehl; 08-23-2016 at 12:15 PM.. |
Thanks Karl I did that when I checked the ac temp switch probe to make sure it was properly set all looked clean
Mighty Meatlocker Turbo
Karlicious is talking about the bottom side of the evaporator (visible through the intake duct which is behind the passenger floorboard) - not sure if you were aware of that. Karl's was so covered in mold/funk buildup on that side, that it looked like a flattened squirrel carcass was stuck to it!
Yes thanks I was checking the bottom of the evaporator to make sure the temp probe was not sticking out the bottom of it
