l_turn9's Avatar
Mysterious Wire Behind Dash
Hello, i have a large black wire that is not connected to anything. I don't believe it has been connected as long as I have owned my 74 911 (since Jan 99). It is hot when the ignition is on but cold when the ign is off. It drops down from behind the ashtray, just below the radio which is an SONY system installed by a PO.
Any idea where this should go? BTW, everything on the car works as it should... Here's a photo of the end...
Thanks!
LarryT
Old 09-16-2016, 06:37 AM
Kind of hard to tell, but it may be the light socket for the ashtray--yes, the ashtray has a light that should come on when the ashtray is opened.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-16-2016, 07:02 AM
l_turn9's Avatar
I never knew the ashtray had a light - there's not one now so that's probably where the wire goes. Great! I'll check that as soon as I go downstairs to the garage.
Thanks much!
LarryT
Old 09-16-2016, 07:14 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 Ashtray Light
'85 Carrera Targa
PCA/POC
Old 09-16-2016, 07:28 AM
Registered Minimalist
75 911s's Avatar
Just cleaning up some wiring on mine. I had one of these loose also, for me it was the fan icon light in the fresh air controls. There are two lights there the top one tends to pull out as and in my case was part of the stereo power harness so it tends to get pulled out easily. My ashtray light is much more secure.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-16-2016, 07:52 AM
ROW '78 911 Targa
timmy2's Avatar
Looks more like a heater control lamp socket. The ashtray lamp is much bulkier.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-16-2016, 09:55 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Socket.
Correct-I've ben in there.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-16-2016, 11:14 AM
l_turn9's Avatar
Thanks Guys - Haven't been able to crawl under yet but all of your info is very helpful! I seem to recall the fan switch mechanism coming loose after I bought the car and I ended up replacing it with a used set of switches. I recall the switch having a light at each end - I could have easily left one bulb receptacle loose. There is a little fan icon on the switch and it never lights up - This could be the reason.
BTW, I found a strange connection consisting of 3 or 4 wires that meet below the radio and I'll have to take a picture of it. There's no insulation on it so it's kind of troubling. Later Guys - Thanks again -
LarryT
74 911
Old 09-16-2016, 11:48 AM
Tags
74 911 , connector , electrical , wire , wiring
