Senior Member
I.D. this part and win a prize!!
OK....I lied about the prize, but help me figure out the what/where of this part......
It is what it looks like.....a large rubber grommet, about 1.5" in diameter, with a 1" hole. This goody came in my official, super-duper Porsche Top-End Gasket Set. Didn't come across anything like this when I pulled the motor apart, so now it's a leftover. Whatiszitfor? Will my freshly rebuilt motor blow-up without it?
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
1.367m later
isn't that the grommet for the alternator wire harness where it passes thru the engine cover?
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
That's the rubber doughnut. When you see a cop in the rear view, pitch it out the window.
oh wait are you sensitive? |
Senior Member
And, please, enough of the do-nut/cop quips....this is a serious technical quiz....
Bill, shush, you never know what might happen when you make jokes.
Doug's got 3100 posts he ain't going nowhere.
Got one of those too in my kit, did not use it, and still don't know what it was for.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Sorry, I don't recognize it, but it does look like a wiring harness grommet and it probably is, but for a later (or earlier) model. When they put these "kits" or "sets" together they usually try to cover as many models as possible, so there's often (usually) something in the kit that isn't to be used on your particular car. If it doesn't match up to anything you removed when you took it apart it probably isn't meant for your car. In fact I'm surprised this is the only "left-over" part from the "kit" usually (of course I'm more familiar with American iron here) there's several left-over gaskets or O-rings or etc. that were put in a kit so it would be correct for several model years.
Just my opinion, Jerry M '78 SC |
Senior Member
Good call, Jerry.....there were a few other strange bits in the kit I did not need/use.
yelcab....at least we have some things for the next swap meet
Super Moderator
Okay,
How about the grommet where the oil filler neck goes through the body?
Senior Member
I'd say it definitely seems to be for wiring, but if so, why would it be in a *gasket* kit??
That's the fabled Super Carrera Grommet! Worth at least 20HP, maybe more. Be warned though it will subtract a like amount of HP from inferior non-SC engines.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com 1966 912 converted to 3.0 and IROC body SOLD unfortunately ![]() 1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity! |
I think thats for the smog pump hose that goes through the engine tin to the air injectors... by the way I need one...
Tim in Sac |
Author of "101 Projects"
Replacement grommet for the O2 sensor plug perhaps?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
packing material for the muffler bearing???? Probably for another year car like mentioned earlier.
Chris |
Hilbilly Deluxe
I dug up the part number for the smog pump gasket, then looked at the contents list of the seal kit, and it was listed, even for a car without a smog pump. Thanks Doug, this saved me some head scratching in a month or so. I picked up the same gasket set today, thanks to my $100 PCA certificate. Tom |
That looks like the wiring harness grommet for the hole under the dash (close to the glove box).
I pushed a bunch of amplifier wires into the trunk through a grommet that looked just like that (not what you'd expect to find in a top end gasket kit, though).
Bob '82 911SC Targa Last edited by BoogieOnSkis; 01-04-2003 at 12:13 AM.. |
I'm putting mine on E-bay.
Kevin 72 911T/E |
Senior Member
THE WINNER!
I do believe you are da..... winner!! I looked it up in the parts book, and it's #911 113 146 00 For '75-'79 air pump equipped motors. You can claim your prize (the grommet) by sending me an e-mail with your postal address. Thanks all for playing along.
Actually it has nothing to do with the engine! Its for the AC hose to the evaporator which fits through the wheel well!!! Sure could use one of these....................
Bob 73.5T
