Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by Chuchuf View Post
. . . I also ass some of that splooge mixture on the back side by the cracks.
Terry
Terry, now that is a trick that I bet some folks would pay good money to see video of!
Old 03-20-2017, 11:52 PM
Yes I used West 205 on mine to fill in the cracks and holes, and applied just enough to get it up to the surface height again. I would think that the sawdust would be OK to thicken but I used milled fiber (flox) and cabosil to thicken mine as I had the materials on hand.
After letting that harden for about 2 days, sanded so that it had the right shape with the dash and then bondo to fill in the small voids left.
Oh and anyplace the dash was cracked through to the back I also ass some of that splooge mixture on the back side by the cracks.
I think this dash can be repaired.
Terry
The SIX/10 is pre-thickened so no additives are needed. On a dash I would steer away from both the milled fibers and the cabosil as they are both designed to add strength to the epoxy. Pure epoxy is plenty strong for this application and far stronger than the material it is bonding. The dash will fail loooong before the epoxy. In this application the only purpose of a filler is to ad body to the epoxy to fill faster. In addition both the fibers and cabosil will cure very hard and will be difficult to sand due to the hardness. This could become an issue as the dash will be much softer and will sand much easier. The harder epoxy will stand proud and create a noticeable ridge. I suggested oak only because it is a low oil wood and can be had free. The only expenditure is a few minutes on a sander to create the dust. A better application might be balsa dust much softer also low oils. As I said just about anything can be used to create the body to keep the epoxy from slumping. As crazy as it sounds things such as paper out of your shredder or dryer lint. Both would suspend the epoxy until cured and would be easily sanded.
Old 03-24-2017, 03:09 AM
dash repair
I first removed all cracked pieces and beveled the edges. Then I used flexible bumper repair to cove the bad areas. After that I had an upholstery shop cover with vinyl. It turned out very nice.
Old 03-24-2017, 05:04 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
I picked up the Six/10, but I've been at a conference all week! Stay tuned...
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 03-24-2017, 08:13 AM
Bill Douglas's Avatar
Good skills!!!
Old 03-24-2017, 02:06 PM
Rennch on YouTube
rennch's Avatar
Ok, time for an update. Was at a conference all week. I've just dremeled out any major cracks in an effort to let the epoxy sit flush with the dash. The first priority is to get structural integrity before I work on building up the phone again and sanding into the final shape before the leather or vinyl is applied. Again, I have no idea if this will work but I'm going to give it a shot.
Michael O'Neal -
Old 03-26-2017, 04:06 PM
Rennch on YouTube
rennch's Avatar
I'm going to be doing an instagram live video of the epoxy if you want to check it out: http://instagram.com/_rennch_
Michael O'Neal -
Old 03-26-2017, 04:15 PM
Rennch on YouTube
rennch's Avatar
Well, it ain't pretty, but it feels pretty effective. I had a real challenge with the corner piece that had broken off trying to keep it lined up, but I held it in place while I put on thin layers of Epoxy and hit it with the heat gun, so would cure the epoxy quite quickly.
Instead of feeling "floppy" in my hands, it feels really solid now. I will give it a day to cure, then will start working on the expanding foam.
Michael O'Neal -
Old 03-26-2017, 05:23 PM
Looks good empty, I think you did a great job. Now that it is all glued back together and sound switch over to body filler. As explained above the epoxy is going to be harder than the surrounding dash. You will run the risk of sanding the dashboard before the epoxy. The body filler is designed to be sanded and will sand before the dash. Use the filler to get your shape. Of course scuff your epoxy so the filler will stick and take it slightly below the dash surface so you can build up the filler to the finished surface.
Looking good.
Old 03-27-2017, 04:53 AM
Discseven's Avatar
Wow! Have not read through posts M... Just looked at pics. That's a fine project to dive into. Looking forward to see where you take this. There is dash media that will work for that. Been a long time since I used so forgot brand.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 03-27-2017, 10:10 AM
Rennch on YouTube
rennch's Avatar
After the initial sanding, I am pretty pleased with the outcome. It's starting to look like a dashboard again!
Today I'm going to use the expanding foam to fix the large gaps. Then I will use some body filler to smooth out any uneven spots and give it another sanding.
Michael O'Neal -
Old 03-27-2017, 10:19 AM
3rd_gear_Ted's Avatar
Have you considered RTV,
you can get a real smooth finish by using an ice cube.
I have fixed cracked dashes this way many times.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-27-2017, 10:32 AM
Rennch on YouTube
rennch's Avatar
What is rtv? And what's the ice cube method?
Michael O'Neal -
Old 03-27-2017, 05:01 PM
Rennch on YouTube
rennch's Avatar
More epoxy buildup, and foam applied.
Michael O'Neal -
Old 03-27-2017, 05:02 PM
3 restos WIP = psycho
kenikh's Avatar
I bought a Lakewell. Best on the market doesn't mean as good as factory. I'm still considering repairing my stock '69 dash. Not pleased enough to make using it a slam dunk.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-27-2017, 05:06 PM
Rennch on YouTube
rennch's Avatar
So you are telling me I'm not completely insane? :-)
Michael O'Neal -
Old 03-27-2017, 05:07 PM
kenikh's Avatar
Far from it. Cnielsen and I were just discussing this topic the other day. He dumped his Lakewell for the route you're going.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-27-2017, 05:20 PM
Silicone bathtub caulking is RTV
You fill the void with RTV as smooth as you can with your finger, then take an ice cube wider than the void in the dash filled with RTV and drag the ice cube over the whole thing.
It creates an amazing finish with a little practice.
2016 Cayman S
Old 03-27-2017, 05:30 PM
kenikh's Avatar
RTV = Room Temperature Vulcanizing rubber.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 03-27-2017, 05:33 PM
Rennch on YouTube
rennch's Avatar
Now you tell me.
Michael O'Neal -
Old 03-27-2017, 05:35 PM
