Mighty Meatlocker Turbo
![]() Terry, now that is a trick that I bet some folks would pay good money to see video of!
dash repair
I first removed all cracked pieces and beveled the edges. Then I used flexible bumper repair to cove the bad areas. After that I had an upholstery shop cover with vinyl. It turned out very nice.
Rennch on YouTube
I picked up the Six/10, but I've been at a conference all week! Stay tuned...
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Good skills!!!
Rennch on YouTube
Ok, time for an update. Was at a conference all week. I've just dremeled out any major cracks in an effort to let the epoxy sit flush with the dash. The first priority is to get structural integrity before I work on building up the phone again and sanding into the final shape before the leather or vinyl is applied. Again, I have no idea if this will work but I'm going to give it a shot.
![]() ![]() ![]() Sent from my iPhone using Tapatalk
Rennch on YouTube
I'm going to be doing an instagram live video of the epoxy if you want to check it out: http://instagram.com/_rennch_
Rennch on YouTube
![]() ![]() ![]() Well, it ain't pretty, but it feels pretty effective. I had a real challenge with the corner piece that had broken off trying to keep it lined up, but I held it in place while I put on thin layers of Epoxy and hit it with the heat gun, so would cure the epoxy quite quickly. Instead of feeling "floppy" in my hands, it feels really solid now. I will give it a day to cure, then will start working on the expanding foam. Sent from my iPhone using Tapatalk
Looks good empty, I think you did a great job. Now that it is all glued back together and sound switch over to body filler. As explained above the epoxy is going to be harder than the surrounding dash. You will run the risk of sanding the dashboard before the epoxy. The body filler is designed to be sanded and will sand before the dash. Use the filler to get your shape. Of course scuff your epoxy so the filler will stick and take it slightly below the dash surface so you can build up the filler to the finished surface.
Looking good. |
Wow! Have not read through posts M... Just looked at pics. That's a fine project to dive into. Looking forward to see where you take this. There is dash media that will work for that. Been a long time since I used so forgot brand.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Rennch on YouTube
After the initial sanding, I am pretty pleased with the outcome. It's starting to look like a dashboard again!
Today I'm going to use the expanding foam to fix the large gaps. Then I will use some body filler to smooth out any uneven spots and give it another sanding. ![]() ![]() ![]() ![]() Sent from my iPhone using Tapatalk
Have you considered RTV,
![]() you can get a real smooth finish by using an ice cube. I have fixed cracked dashes this way many times.
1980 911 - Metzger 3.6L 2016 Cayman S |
Rennch on YouTube
What is rtv? And what's the ice cube method? Sent from my iPhone using Tapatalk
Rennch on YouTube
More epoxy buildup, and foam applied.
3 restos WIP = psycho
I bought a Lakewell. Best on the market doesn't mean as good as factory. I'm still considering repairing my stock '69 dash. Not pleased enough to make using it a slam dunk.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Rennch on YouTube
So you are telling me I'm not completely insane? :-) Sent from my iPhone using Tapatalk
Far from it. Cnielsen and I were just discussing this topic the other day. He dumped his Lakewell for the route you're going.
![]() You fill the void with RTV as smooth as you can with your finger, then take an ice cube wider than the void in the dash filled with RTV and drag the ice cube over the whole thing. It creates an amazing finish with a little practice.
RTV = Room Temperature Vulcanizing rubber.
Sent from my Nexus 6P using Tapatalk
Rennch on YouTube
Now you tell me. ![]() Sent from my iPhone using Tapatalk
