is the stock air filter on the 3.2 restrictive
Hello,
Notice some swap out the stock air box for a cone filter. Is the stock air box know to be restrictive? Thanks, Chris 89 Carrera |
abides.
Graham 1984 Carrera Targa |
Mo money = mo parts
Agree with gtc. Some have pointed to the "barn door" on the AFM as being less than desirable, but moving to a new AFM is a much more complex and costly swap.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Spiderman
Many threads spend time trashing the KN option as being a poor filter and gaining nothing measurable other than physical space sometimes. I think the KN is a yearly PIA to service so I removed the one that came on my car which was a drop in replacement for the stock filter fitting the same housing. Back to stock paper. Cutting the top off the stock airbox supposedly results in some measurable increase of performance. Would make reaching the box clips easier if your arms/hands are big.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Vintage Owner
Dyno numbers
Does anyone have any Dyno numbers to actually give real results? The filter or housing would have to be the flow limiting point to make any difference I would imagine.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Spiderman
Think that answer is yes, you'll have to do some searching/reading. Could be some of that info. with regard to Steve Wong performance chip. Basically key on the very few incremental improvements that you just drop in.
Porsche was pretty good on the engineering for the intake and exhaust of the 911. The Electrical and AC engineering sucked big time, but the performance of the intake and exhaust is hard to beat by more than a few HP. Steve Wong showed that with the stock intake just removed, it was almost no gain or very little. You really need the filtration of the filters.
A few HP can be gained on the exhaust if you don't want to have heaters. I really like having heat so that ain't an option for me.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Registered Cruiser
Changing the airbox will net you a different sound with no HP gain. You could lose some though. I have an MAF conversion on my car. It makes no difference over the stock box.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
Schleprock
Airbox is not a restriction. The same general airbox is used on the 964 3.6 and that engine easily makes more power and torque. Swapping out that box on the 3.6 nets very little, if anything, in power gained on that engine too. So in my mind that too proves that the airbox is not a restriction.
A lot of the cheapo cone filters that can be adapted to the air flow meter are actually a bigger restriction. I grabbed a cheap Spectre brand piece of crap from a local Pep Boyz (purposely misspelled........... ) to do a comparision. I did this because my friend with the same 3.2 Carrera 911 as mine, who is a pro mechanic, put on one of these crappy horseshiat filters. I measured the length and depth of the Spectre filter pleats and compared that to the typical original paper filter surface area. The difference in surface area was huge in favor of the original filter element. So my point is, your cone filter has to be quite larger in order to have the same amount of filtration area as the original filter. That said, i'm sure the cone filters have a less restrictive filter element and that makes up for the lack of surface area.
Kevin L '86 Carrera "Larry" |
Irrationally exuberant
I seem to remember Bruce Anderson (RIP) said that leaving the filter and filter cover off caused a 3 hp loss in power.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Functionista
Recently drove a completely stock 60k mile 1987 911 and a coned, chipped, dual outlet exhaust and who all knows what else 80K 1987 911. Not really a fair comparison without testing leakdown or knowing condition or correct plugs plus valve clearance, but back to back the stock one was noticeably quicker down low, in mid-range and top end pull.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
The answer to the original question is probably NO... However, Porsche left 20-30Hp on the table for the US version of the 3.2L. The biggest gain potential is probably on the exhaust side.
With an opened up airbox, MAF sensor (ditch the AFM barn door), extrude honed intake, bored out throttle body, good headers, a low back pressure muffler, and a good tuned chip, you might get 250Hp on a good day. All for around $5-6k...
1985 928 S3, 5-speed 1987 Carrera, current project 2012 Jaguar XF 5.0, Wife's d.d. 2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's... |
Registered Cruiser
Member 911 Anonymous
![]() I went home and swapped back too plus cut the bugle off
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
1988 3.2, 56,150 miles, stock air box with open cover, stock filter element, Web 20/21 cams, pre-muffler, single in / out Dansk SS 84mm tip sport muffler...
Baseline: 193 hp / 168 tq Same engine configuration, one hour and ten minutes and nine dyno pulls later, Steve Wong working his techno wizardry on the ECU tune... + 19 hp / + 18 tq = 212 hp / 186 hp I know this doesn't fully answer the OPs question, but it seems to support the stock filter element and AFM as being "adequate."
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
