How do I replace the rubber material around engine bay?
Does anyone know how I can replace this rubbery flap that runs along the sides and back of the engine bay?
I'm not even sure how you remove it... or if that's even possible?
1987 Porsche 911 Carrera Coupe |
Definitely possible to replace. I have only done it with the engine out of the car. I think it would be very hard to do with the engine installed, if not impossible. Wait until your next engine drop.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
It is actually two flaps, one over the tin one under, it slides into a "track"
It helps if engine is out but I suppose it could be removed with a partial drop and some lube
I think that maybe I'm dreaming.. |
Does anyone know the replacement part numbers for these pieces?? I guess the other question is... can the originals be restored/reshaped? As I mentioned, they've developed a wavy pattern to them (probably from heat) that's trapping a lot of debris. (FYI... engine is already out)
Short section goes laterally across front of engine. Long section goes around remaining three sides (two sides and rear). These are plainly shown on Parts Diagram on website. Happy trails learning to use info that Pelican provides.
![]() I only have 3 sections total... left and right sides of the frame, and the frame section towards the front of the car. From what I can tell, the front section is the longest (and curves slightly), while the left and right are the shortest.
I can only imagine what a chore it would be to try and replace the seal with the engine in the car. It takes a bit of work to get the seal to slid into the channel even with all of the space of an empty engine compartment. The "long section" goes on the left ,right and rear as one piece. The "short section" is the piece in the front side (under the shock mount area) Here are some photos Good luck
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) Last edited by stevie 77 930; 10-26-2017 at 08:08 AM.. |
You replacing these because they are wavey? They are wavey when new.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Yeah, I replaced mine when I had my motor out and it was brittle and would break if you pushed on it too hard. The new one is pliable and wavy, and it seals the top and bottom of the tin quite well.
1988 930 Venetian Blue |
What about the body seal between the torsion tube and tub? Mine fell out on my face while working on fuel lines. Was wondering if I should replace. Looks easier to access than the one shown above.
Cheers Sent from my iPad using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 10-26-2017 at 08:40 AM.. |
I just did this to my 930, with the engine out. Still a bit of a pain. OEM parts are long section in a U shape, for the sides and back; short section as a single piece for the area under the shock mounts. Bought the parts from our host.
For what it's worth, the rear channel on my car was deteriorated and starting to rot away (but nothing else around it was messed up). Found the correct channel from Sierra Madre.
Garen GNdesignLLC.com - Automotive Art & Sculpture |
soapy water helps (I used aerospace 303 as a Lube)
Once a friend of Cliff
lots of soap to grease the skids
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Its a real PITA replacing, trust me.
If yours is not fully worn/ripped, then clean and lubricate it and your good.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Silicone spray and a plastic dash tool with a dull point on it. Partial engine drop then silicone the metal channel and the seal about 1 foot at a time. Insert the lower edge in the channel then use the plastic dash tool to press in the top. Expect it to take 1 hour on a lift. Along with lot's of cursing. If you're doing it on the floor you have my sympathy. I would pull the engine before I'd do it on the floor.
