When bleeding brakes and the new fluid is the same colour
as the old, how do you know when the old fluid is out?
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster Last edited by bcgreen; 03-29-2018 at 07:36 AM.. |
Sounds like you are changing it fairly frequently (a good practice) and hence no color changes. There really isn't a lot fluid in the lines from master cylinder to the calipers. I remove the old fluid out the master cylinder with a Mityvac and fill it with new then start. So rough guess from past jobs, 4-5 ounces for the rears and 3-4 for the fronts (all per side) to clear the old and run with the new fluid.
1986 Targa Guards Red 2021 MT09 SP Last edited by brighton911; 03-28-2018 at 05:55 PM.. |
I use a quart and it gets all the old out. When i used Super Blue, I would alternate it with the amber colored and a quart would ensure the old was out. plus it's not like you can really save an opened can of brake fluid (so I'm told) so I just used the whole quart.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
I used to measure the volume when I went from Blue to gold (or back). In my 1973 it took about 150 ml to flush the farthest caliper. If you do about a liter equally divided, you will get the old stuff out.
as said,, you need to remove the old fluid from the reservoir before putting in new.
Wildman Emeritus
+1 on cycling an entire quart/liter thru the system. I did this initially and now alternate colors to simplify things.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Thanks guys, will go through the whole container.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Food color added to brake fluid ??
Another question -
Has anyone ever added food color to the brake fluid to determine old and new fluid ?? I wonder what ATE used to make their fluid blue ?? Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Bad idea. The food color is water based. Water and brake fluid are not a good thing. Anything the end user would put in brake fluid is going to adversely affect the fluid performance.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Functionista
Doing the farthest first (LR on 911) showed me that it takes the most so I do about .35L on it followed by .2L on RR. Then .35 on RF and last bit on LF. I learned this back when Superblue was common. Bet I’ve done thousands of cars...
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Thank you for the good advice . . . and I thought I came up with a novel idea . . . ha ha. Regards,
How do know you're using 0.35 or 0.2?
Functionista
Our machines reservoir is clear and has four distinct lines. Pretty easy to eyeball from a distance.
