Zeke's Avatar
What is the best way to cut open an oil filter?
Can opener? Not a hack saw, I'm not looking to add any metal to the inside, just find it. Any other tips?
Old 07-29-2003, 07:03 PM
I punched a hole in mine, then cut around the base with a set of tin snips.
Not the *cleanest* job in the world...
However, the tin snips haven't worked this good in a long time!!!LOL
Later,
Tom
Old 07-29-2003, 07:08 PM
John Rogers's Avatar
I do ours the same way as Tom although I guess you can buy one of those "filter cutters".
Old 07-29-2003, 07:21 PM
chrisreale's Avatar
Jewelers saw?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 07-29-2003, 07:27 PM
Too bad its after the 4th of July..... Crazy ideas come to mind
Old 07-29-2003, 07:41 PM
Zeke's Avatar
You get those at the same place where you get a "board stretcher?"
Old 07-30-2003, 06:57 AM
tat2dphreak's Avatar
ok, remember I'm an idiot, but I have to ask... WHY?!
'72, now with a living, breathing 2056...
Old 07-30-2003, 07:31 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
To look for metal bits from the engine self-destructing.
--DD
Old 07-30-2003, 07:33 AM
roadtrp204's Avatar
Milt,
The easiest way I have found is to poke a hole in the casing and then peal back a small tab. Next clamp the tab with a par of needle nose pliers and wind a continuious strip around the end of the pliers, just like the way old sardine can used to open with the key. It doesn't alway work in one try but it does get the casing off cleanly without contaminating the filter element.
Chris
75 914 2.0L
Old 07-30-2003, 08:05 AM
dc914guy's Avatar
Send a message via AIM to dc914guy
I have an old, rather big pip cutter (the kind with a lond chain and handle).. A $2 buy at a yard sale.. Slices through them like butter.
~Eric
Eric Devansky
986s - Radio Flyer
20% of a 951 parts car remains
Old 07-30-2003, 08:21 AM
Andyrew's Avatar
What if you drilled a hole in it and took a "nibbler" to it, I think that would do a clean job..
Old 07-30-2003, 08:40 AM
wouldn't the drill put extra shavings in?
Old 07-30-2003, 10:29 AM
Zeke's Avatar
--DD
Yes, indeed. To look for what kind of metal from the motor. Hopefully all it is is aluminum from the piston seizing. I will try to gather any metal with a magnet. I will also look at the color. I have an old school lab microscope. Lastly, to see what size the metal particles are. I figure if I can feel them with my finger tips, I'm in serious trouble.
Old 07-30-2003, 07:49 PM
chrisreale's Avatar
Zeke, have you split the case yet? There is a thread over at 914club about making two barrel webers more road-race-able (is that a word??) Seems that fuel starvation is common, and certain mods can help. Check it out.
www.914club.com
Old 07-30-2003, 08:29 PM
Administrator
Baffling the float bowls, for one. There's an update kit available from CB Performance that is supposed to help, as well.
--DD
Old 07-31-2003, 07:57 AM
Unregistered
sammyg2's Avatar
If you drill 3 or 4 small holes in the carburetor floats you won't have to worry about fuel starvation
PS to any newbies out there, please don't do this, I'm kidding.
Old 07-31-2003, 02:15 PM
dc914guy's Avatar
Does anyone know how to repair holes in carburetor floats??
LOL j/k
Eric Devansky
986s - Radio Flyer
Old 07-31-2003, 02:30 PM
