Still can't get my 2.0 started after adjusting the Crane optical unit in the stock distributor. I did not remove the dizzy from the block, but I have now rotated it back and forth several times so that the timing is now just a guess. My question is: to set the timing approximately (enough to get it started), should I set everything at TDC and then rotate the dizzy counterclockwise a smidge to advance it?
914 Geek
If all you're after is "close enough to start it", try TDC. Rotate the motor until you're at TDC, then rotate the distributor until you get a "zap" from the center coil wire. You can use a plug wire and a plug (tape the plug so the threaded part is against a ground) to tell when you get a "zap".
The key should be "on" when you listen for the "zap"... --DD |
Thanks, Dave. I followed the procedure you outlined and got a nice strong "zap" at TDC, but the car still does not start. I did find a wire to the cold start valve disconnected and fixed that, but I am stumped. I have fuel pump "whirr", the FI wires to the trigger points in the base of the dizzy are connected, installed a new Bosch rotor and cap, and double-checked the firing order. Hate to have it towed to my favorite Porsche fix-it shop, but...
914 Geek
Three things are needed for a motor to run: 1) Air (or compression). 2) Spark. 3) Something near the right amount of fuel.
Are you getting a spark from the plugs? Are you getting any fuel from the injectors? Are the hoses and wires and such all hooked up correctly? Have you started going through Kjell Nelin's D-jet Guide http://www.914fan.net/djet.html ? --DD |
