Guest
Posts: n/a
I installed a 19 MM master cylinder a few months ago and now it's time to get everything working. I've read in a few places the the M/C needs to be bench bled.
Do you guys think I need to take the M/C back out and bench bleed it or should I just press the pedal real slow to ease the fluid into it from the reservoir? That M/C was a real pain to install, I'd hate to have to yank it back out. ShawnO [This message has been edited by ShawnO (edited 08-20-2001).] |
914 Geek
You bench bleed it because it's a pain to bleed once it's in. Since it's a pain to install (again), just bleed it normally. A pressure bleeder may make it easier--I'm not sure.
Be prepared to go through at least a full quart of brake fluid. I'd have at least two quarts on hand. --DD ------------------ Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
