Nabeel's Avatar
Send a message via AIM to Nabeel
Instruments don't work
Went out driving just now and none of the guages (speedometer, tachometer, oil pressure, fuel, mpg, temp) are working, everything is on zero. Yestarday morning the same thing happened, but they came back to life after I revved the engine a bit. They were fine just a few hours ago. Oh well, I'll be trying to take apart the cluster tommorow and figure out what's wrong with it. Any thoughts?
edit: I hope its just a fuse. That will be the first thing I check. Or maybe grounds.
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 07-03-2003, 11:32 PM
Roger Hall's Avatar
I would bet on a blown fuse.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 07-04-2003, 03:08 PM
TSNAPCRACKLEPOP's Avatar
you are now qualified for visual flight rules.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-05-2003, 07:21 AM
AFJuvat's Avatar
Check fuse, also check wiring and grounds behind the cluster.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-05-2003, 07:38 AM
When mine behaved that way, it was the grounds. Hope its just a fuse. If not, prepare for a long journey.
Old 07-05-2003, 11:47 AM
Nabeel's Avatar
Thanks guys. The fuse seems alright. Now I'll check the grounds. I'm fairly sure the grounds back there are the culprit. For quite some time now the fuel guage has been innaccurate (goes up and down, sometimes almost by 1/2 tank while driving) so this seems to make sense.
'85.5 944
5-speed
76K miles
color-matched fuchs
SOLD
Old 07-05-2003, 06:21 PM
