Instruments don't work
Went out driving just now and none of the guages (speedometer, tachometer, oil pressure, fuel, mpg, temp) are working, everything is on zero. Yestarday morning the same thing happened, but they came back to life after I revved the engine a bit. They were fine just a few hours ago. Oh well, I'll be trying to take apart the cluster tommorow and figure out what's wrong with it. Any thoughts?
edit: I hope its just a fuse. That will be the first thing I check. Or maybe grounds.
'85.5 944 Kalahari Beige/Brown 5-speed 76K miles color-matched fuchs SOLD Last edited by Nabeel; 07-03-2003 at 11:41 PM.. |
I would bet on a blown fuse.
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
you are now qualified for visual flight rules.
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Check fuse, also check wiring and grounds behind the cluster.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
When mine behaved that way, it was the grounds. Hope its just a fuse. If not, prepare for a long journey.
Thanks guys. The fuse seems alright. Now I'll check the grounds. I'm fairly sure the grounds back there are the culprit. For quite some time now the fuel guage has been innaccurate (goes up and down, sometimes almost by 1/2 tank while driving) so this seems to make sense.
'85.5 944 Kalahari Beige/Brown 5-speed 76K miles color-matched fuchs SOLD Last edited by Nabeel; 07-05-2003 at 06:25 PM.. |
