livewirevoodoo's Avatar
Ignition Kill Switch in Center Console... Possible?
I'm looking into the possibility of using one of my center console blanks for an ignition kill switch. Currently I have Rear Wiper, P Windows and P Sunroof switches in the console.
Can I buy, say, another power sunroof switch and wire it for an ignition kill switch? It is a 6 pole connector. Looked @ haynes wiring diagram - not much help. Anyone familiar with the pin-outs on these switches?
Hoping for a little direction.
Thanks in advance.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 03-09-2005, 08:06 PM
Send a message via AIM to AznDrgn
Here's a write up on how to do it, where you put the switch will be your choice but I doubt one of those small switches will be able to handle the amperage load neccessary.
http://www.pelicanparts.com/techarticles/Mult_ignition_cutoff/Mult_ignition_cutoff.htm
'91 Jeep Cherokee 4.0L HO - Daily driver
'83 Callaway 944 2.5L turbo - Soon to be daily driver
'83 Porsche 944 NA - sold
'78 Porsche 924 NA- RIP
'89 Porsche 944 S2 - Parted
Looking for a nice 944S for a daily driver.
Old 03-09-2005, 08:24 PM
so better off going with just something mounted under drivers dash then, huh? I guess it server the same purpose.
I was looking to fill the center console with options... lol
''87 944na 85k
Old 03-09-2005, 08:43 PM
Get creative, if you don't smoke redo the cigarette lighter to make it a switch or do something fun with it. Just think James Bond car and lots of interesting ideas for switches will come to you.
Old 03-09-2005, 09:32 PM
adrian jaye's Avatar
if you use a relay then you dont need to worry about amperage
The fear of God is the begining of wisdom <><
NotJustPorsche
Subscribe: notjustporsche-subscribe@yahoogroups.com
Old 03-10-2005, 03:57 AM
I just bought a car with a kill switch in the console, I would have never found out if I hadn't been playing with the switches while the car was running. Moral of the story, if you do this and sell the car, tell the next owner.
Old 03-10-2005, 04:20 AM
This is true but to someone new to wiring adding a relay into the mix is normally quite confusing not to mention the fact that you have to run a lot of extra wiring straight from the battery or the panel.
Old 03-10-2005, 07:09 AM
Zero10's Avatar
Send a message via ICQ to Zero10
I did something along a similar line in a previous car.
I had a button you had to hold down while you started the car.
It was one of my home-made anti-theft devices. It would kill the fuel pump unless it was held down until the ignition switch was turned back to the on position from start.
Mind if I ask what your motivation for this is?
It would be pretty simple to do. Perhaps the sunroof switch is the best choice, since it's the only one I can think of that returns to the center position when released.
If you have a multimeter, just measure the resistance between pairs of pins until you find a set that is connected when you push the switch in the desired direction.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 03-10-2005, 08:36 AM
Zero -
Basically my motivation is to feel sure that when I step outside for work in the morning my car is where I left it. Audible alarms dont give me that warm & fuzzy feeling. A killswitch will leave me feeling a little better off.
I was thinking of a rear window wiper switch actually. So the connection is either 'on' or 'off'. Based on the setup you had, I can see the usefulness of a "hold down sunroof switch until ignition' setup. Although that would require 2 hands to operate if the switch was in the center console.
''87 944na 85k
Old 03-10-2005, 08:52 AM
