Custom User Title
mikepellegrini's Avatar
Power stays on when key off - Ignition switch toast?
I found my 951's battery dead a few days ago, so I hooked it up to the charger and noticed the fresh air blower going (with the key off).
I pulled the G1 relay and the fan went off, so I figured the relay was toast and ordered a new one.
I got a new relay yesterday and plugged it in and the fan still ran with the key off.
Investigating further, I found the power windows work, as well as the radio and the rear window defroster. The wipers have some power to them - you can hear their relay click when you push the lever, and the wipers shiver a little. But not enough power to run the wiper motor.
None of the instruments light up with the key off or out and the car starts and runs normally.
I know there's a feature described in the owner's manual that the windows will work with the key removed until one door is opened and closed. But I don't see anything in the manual about the other equipment operating. The equipment still doesn't go off when you close the door with the key out.
Which leaves the ignition switch as culprit? Anyone ever had a switch fail in this manner?
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 01-06-2009, 05:45 AM
I recall that the radio works with the key in place. There might be other systems that do as well but I don't know about that. Perhaps this key-in-radio-on feature has failed for your switch, or maybe it just thinks the key is still in the ignition. I know it sounds stupid-simple, but have you tried lubricating the ignition switch to see if that helps?
Old 01-08-2009, 11:20 AM
Custom User Title
No, I haven't tried lubricating the switch. I may, but I don't think that's the problem. The switch turns easily, without hesitation. The detents for each position seem firm, with no slop.
I was playing with it, turning it on and off, and after maybe five minutes of this, everything went off when I turned it off. I repeated this several times and each time, everything went off - I was feeling good. I figured it had cured itself.
So I pulled the radio, intending to hook up the antenna amplifier. As I was working on the antenna wires, I heard the relay click and the power came on, by itself.
Just for the helluvit, I pulled on the antenna wires, jiggling them, and the power went off. This happened several times, and seemed to work each time.
Then I was standing at my workbench and heard the heater fan come on. This time, no amount of jiggling of the wires in the radio area would make the power go off.
None of this makes any sense, of course. Either the power going on or off was completely coincidental to the jiggling, or I must have some really nasty wiring problems...
Jiggling the wires directly at the back of the ignition switch produced no results.
I s'pose it's possible there's something broken in the switch (resting partially across the terminals) which could account for the intermittant problems. Although it seems odd that with me out of the car, the power would come on by itself.
I should probably take the switch apart and look at it.
I spent some time looking at the wiring diagrams, but haven't been able to figure out exactly how the "windows work when the key is removed till you open a door" is accomplished. I figure it has to be another relay, but am unsure which one. If that relay was broke, that could produce the same sort of effects I'm having - in theory.
Or, maybe the car is haunted?
16 Ford Expedition
Old 01-08-2009, 07:16 PM
What I meant was lubricating when the key goes in and out, not when you turn it...
Old 01-08-2009, 07:38 PM
Custom User Title
I hadn't thought of that but you're right. I'll try it.
16 Ford Expedition
Old 01-08-2009, 07:51 PM
The next time your car gets haunted, how about reaching under dash and pulling the round black molex connector off the back of ignition swith. If all return to normal, then it might point you to the switch
Old 01-08-2009, 09:06 PM
legoland951's Avatar
The plastic/electrical portion of your ignition lock can go bad though most are the early 944s that are problematic (I bought 10 of those ign switches last time I ordered and only have 3 left since most of them are cracked). The late models are normally better and I can't remember the last time I had to replace one. I would look into a bad installation where the antenna power out or amp out to the radio is hooked up to the radio ign power input to somehow channel 12v or something along that line from an alarm system.
There is no mechanical task so great that brute force and ignorance cannot overcome
Old 01-09-2009, 07:07 AM
Custom User Title
Yeah, next day off, I'll take the switch out, take a good look at it, and take a good look at the wiring in the area.
If the problem persists with the switch unhooked, then obviously it's a wiring problem.
If it were an early car, I'd throw a new switch in it just for the heck of it (they're less than $5), but the late switches are about $65...
16 Ford Expedition
Old 01-09-2009, 04:58 PM
Custom User Title
I disconnected the switch and the power was still on.
The circuits affected: Heater fan, radio, windows, rear window defroster and a small amount of power to the wipers (enough to make the relay click when you turn them on, but not enough power to make the motor run - weird!).
I believe all those circuits have their own relays and fuses. So the short - if there is one - must be inbetween the ignition switch and the central electric.
I'm still wondering if it couldn't be a relay - the one that powers the windows till the door is open and closed.
While I was under the dash, I pulled on and jiggled all sorts of stuff but nothing happened. Same with the wires in back of the radio.
All the wiring looks just great. It looks like it was all fresh from the factory, without any "improvements" made by anyone.
16 Ford Expedition
Old 01-10-2009, 01:55 PM
rmcdonnell's Avatar
It's going to take a few minutes with the circuit diagrams to work out what might be shorted to what. You might have thought a fuse would blow somewhere.
Start pulling unrelated fuses and see if and when the power dissapears to the wipers or rear window. These circuits are supposed to be off when the ignition is off, so something is keeping them alive. Of course nothing may happen until the wiper and rear window heater fuses are pulled anyway. Grab a DVM and see what the voltage is that is still available; it might be less than full battery voltage.
Maybe you can find a particular circuit that is providing power to this portion of live circuit, or maybe you will find that if the fuse for the wipers or rear window are the only ones left in, that they are supplying power to other circuits.
Anyway, you might get some more info about where your problem is, which might point you towards wherever your short is...
Best of luck, cheers
Russell
944 Alpine White '89 2.7L
Old 01-10-2009, 03:28 PM
Custom User Title
It appears to have been the heated seats circuit. I pulled fuses and relays till I found it.
Fortunately, I don't have heated seats, so I'll just leave the fuse out. If that is indeed all it is, I'll consider myself very fortunate.
16 Ford Expedition
Old 01-10-2009, 06:09 PM
cro-cro's Avatar
The same thing just happened to me, turn the car off, pull out the key and open the door and the radio still plays and the windows still roll.
I took out the heated seat relay and nothing changed. I started taking out other relays and when I got to the G14 x terminal or ignition relay the radio and fans stopped going on their own. I have another relay that I put in the g 14 and it all turned back on.
I can turn the key in between 0 and 1, so its not to the aux stage yet the fan and radio stop. I can hear some sort or relay that appears to be under the dash clicking inbetween the key turns. Am I hearing something that exists? Possibly getting closer?
Drew Croley
1985.5 944 Guards Red Stock
1970 Chevelle Malibu 307 Pretty Original
2005 Ford F-250 FX4 6.0
Old 10-19-2013, 02:37 PM
Custom User Title
Per the manual for late cars, "When the ignition is turned off or the key is removed from the ignition, power is still supplied to the window switches until one door is opened." That's gotta be a relay.
G-7 is listed as "window winder." If you pull that and the windows still work, then perhaps it could be the relay you hear under the dash.
These sorts of problems are real PITA's.
16 Ford Expedition
Old 10-19-2013, 08:46 PM
"until one door is opened" - Your logic regarding the relay seems sound, but what about the door switch, if you have a faulty door switch that is not opening when you open the door it would keep the circuit alive. Doesn't explain all of the issue, but it could be a factor.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 10-20-2013, 04:29 AM
one of gods prototypes
bell's Avatar
The relay for that circuit is just to the right of the steering column in early cars, not sure if its in the same spot on later cars.....its attached to the side of the center console just under the dash, on early cars there is a removable black plastic panel that hides it....
It turns on the radio, windows and the UN secure part of the sunroof so you can take it out.....
Brought to you by Carl's Jr.
Old 10-20-2013, 04:54 AM
cro-cro's Avatar
I'm almost definite that it is the radio relay problem. I found a post where someone solved it, and there is a picture of someone else, but the picture was from an early '44 and mine is a late. Ive spent a good amount of time wiggling upside down under the dash with a flashlight trying to find something that looks like a relay that could be taken out.
I've been looking inbetween the key and the radio and also above the clutch (a black plastic shield that doesnt want to come down) When I turn the key I can hear clicking out towards the plastic shield area... But I still havent been successful in finding this friggin relay.
Am I getting hot or cold? Pictures?
This is the link I was talking about with the picture of an early.
Drew Croley
Old 11-16-2013, 11:55 AM
bell's Avatar
you need to remove the black plastic cover, the relay should be under there.....should only be held in place with a few phillips screws, 2 iirc are on the side of the console then one above.....
Old 11-16-2013, 03:47 PM
cro-cro's Avatar
I found two 9mm nuts and one spinning nut...
I'm still not seeing a relay under there. Is it inside this plastic piece? I don't wanna open/break anymore than I have.
I was picturing a regular looking relay like one in the fuse box, but I'm no expert.
Thanks!
Drew Croley
Old 11-17-2013, 11:48 AM
cro-cro's Avatar
Thanks!
I've been away from my car and should be around it tomorrow. Does anyone know if that is the right thing to take apart? Is there a replacement for the relay that has gone bad???
Drew Croley
Old 01-06-2014, 04:29 PM
cro-cro's Avatar
Exclamation I'm now beyond pissed
So THREE YEARS LATER, I have gotten no where, but now worse. I was sitting in a parking lot when all of the sudden my radio turned off and then the engine took its last breath and fell asleep. The battery was dead. I jumped the car and it fired up and then after a minute it died again. I came back cleaned the terminals and it drove home. Shortly after that the battery was dead again.
I took the battery off and charged it. 100% put it back in the car and the next morning the battery was dead, no crank. I put the charger back on it and it said it was fully charged. Took it to Advanced (since its the closest) and they said it was at 9V, they said it was dead, so i got a new battery.
The voltage reader on the dash was never above 12 on the new battery, but it seemed to be running fine. Some times when i start the car the voltage reader doesnt say anything until i thump it and then it wakes up.
I took my car to a guy that has better power reading equipment and he said the alternator had a "bad diode". I trusted him, since he was knowledgable. The next day I mustered up the energy and will-power to get to the alt. After using Clarks Garage Manual on the disassembly of the alternator I took it to a trusted alternator rebuild shop. They said they tested the fire out of it, nothing wrong with the diodes, and a perfectly fine working alternator.
Even more frustrated, I went home, put it all back together, and scratched my head. I have a feeling it is something to do with the ignition switch relay, or the "round black molex connector off the back of ignition switch".
Welp, I typed all that and figured before it got dark I'd go tug on the Molex Connector.
I have no clue if that was it or not, but that was THE WORST THING I'VE DONE!!!
Immediately my starter started starting and starting and starting. The car was in reverse with the parking break, so it went back back back, with me upside in it. I tried to switch the key placement, not thinking that what I did disconnected the key, I finally rolled out of the moving car and it backed into a stump, pushing the exhaust up under the bumper. It kept starting and starting, I pulled the ignition relay G14 out and it was still starting.
Smoke arose from under the engine, then there was a little light down there, a fire.
I grabbed the hose, which my car was on top of and hosed out the fire, ran to the garage and grabbed a 13mm wrench and yanked off the ground.
SMH
Thats what came out. I rolled the car forward, checked under it. My dad helped me get the exhaust tip out from underneath the car, I climbed under the dash and thought about at least putting whatever I took out, back in. A small attempt, and the brass part on top came off. So pissed, I rolled the car into its spot on the parking pad, took the battery out and put it on a charger, closed the hood and said good night.
I'm glad I was upside down and inverted un my car. If I would have been hanging upside down and hanging out the door, it could have been a million times worse.
Drew Croley
Old 01-03-2016, 02:29 PM
