Engine mounting question
Hey guys,
I've never mounted an engine on an engine stand before.
I just pulled my 951 motor and I've got an engine stand, so my question is simply. How do I combine the two?
My current plan looks like:
1) Pull the bell housing
2) Go get some super long bolts and washers
3) Mount engine to stand and use washers to offset as necessary
Is this plan realistic?
Old 02-21-2009, 10:13 AM
BoxxerSix's Avatar
Yes, pretty much on par. When setting up the stand adapter to the motor itself loosen the arms enough that they move easily, and adjust the positioning of the adapter in relation to the engine so that the main rotating pivot is closer to the center of the motor.
Some new folks tend to position the pivot along the center line of the crankshaft which is fine, but then when they go to rotate the motor so the oil pan is up they have 75% of the weight of the motor leveraging against them. I just try to position motors in stands so the motor spins in the stand in a balanced fashion
Adam Hennessy
Old 02-21-2009, 10:23 AM
So frustrating trying to find bolts! No bolt/fastener store is open on Saturday/Sunday, and most close around 5 on weekdays. When the hell am I supposed to get bolts? haha
Old 02-21-2009, 04:39 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Depending on the length of the tubes on your engine stand, the trick is to use the crossmember mounting bolts to secure the engine to the stand. You gotta take them off to get it out, and you gotta take it off the stand to put it back in, so they are never needed in 2 places at the same time.
If the tubes are really short then you'll have to take the clutch pressure plate off as well, and you may need some washers to space the bolts back, depending on how much of them are threaded.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 02-22-2009, 12:37 AM
Nobody Special
As mentioned the X-member bolts are your best option unless you go on-line. I think you will have a very hard time finding the 12mm x 75 (1.5) at any local suppliers. The 12mm I found stocked at various places were all 1.75 pitch. I found out the bellhousing bolts are too short(55) or too long(90) for my new engine stand. Mine is mounted so the mass is fairly centered for a complete long block and it turns much easier.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 02-22-2009, 07:17 AM
BoxxerSix's Avatar
Yes finding the right pitch bolts in proper length is difficult in most places. I purchase hardened threaded rods for my stands and use nuts on the backside of the stand adaptor. Beats fussing around finding bolts in the right pitch, then fussing with proper lengths because some holes are blind while others are bore through.
the x member bolts do work though if you're not using them at the moment, but from the looks of your engine stand adaptor I'd say removing the clutch and FW are going to be necessary in your case as the stub arms look way too short on the adaptor to clear those components..
Adam Hennessy
Old 02-22-2009, 08:22 AM
After I pulled the clutch and bellhousing I was able to mount it using the xover bolts just fine.
Thanks for the help!
Old 02-22-2009, 07:41 PM
do remember the first time u turn it upside down, there's still going to be some fluids inside. get that drip pan underneath
and this is the perfect time to clean everything to a whistle.
Old 02-22-2009, 08:45 PM
