Incorrigible
hood struts. Why did I wait so f#&@%$* long?
Rhetorical question, really.Flame awayI deserve it.
I guess I dont nee the tiny vice gtip and the piece of rolled cordura anymore. D'OH. Jeff
1988 951 all track modded and angry, 2002 Boxster '88 924S, '65 912/911, '86 951, '79 924, '85 944 N/A, automatic - all gone. "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a concours field. |
im fit that catagorey too. i did try a pair of used struts for cheap but they were no good. long term, I'm going to adapt 968 hinges and struts to my car. slightly different arrangement and looks like it should work fine.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Yep, picked up the car in November, and by December, new struts in place for the hood and hatch. I actually threw the black painted stick away......I know, blasphomy.
AFM #725
You guys are hilarious. One of the first things I did to my 83 was new hood and hatch struts. When my 86's hood strut started getting weak on one side, I ordered two new OEM ones the next day. Lol.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
I thought I read somewhere that the are hard to install?
86NA944 |
they are not!! less than a minute each side. probably longer to take them out of the box. the rear struts are equally easy.
The Weltmeister HD hood shock are one of the best out there with a lifetime warranty.During my twenty six years off 944 ownership I did replace the hood shocks at least three time to no avail,so I decided to buy the HD one, and after five years on the car they are still going strong.The rear hatch one I only had to replace once.
1983 944 N/A
I'm actualy going to eliminate my and go with the 924 hood prop, seeing that I have an early 944 With the prop holder on the driver side inner fender and I'm putting a 931 hood with no place to put the shocks on (it is already being painted and didn't get a chance to weld on the mounts)
"To my family, the 944 is more than a new car. It is a new and true Porsche. At Porsche, excellence is expected." Dr. F. Porsche Stuttgart |
If anyone reads this thread and decides to go out and change their hood struts, I have a very important tip for you: place a piece of cardboard or two (depending how thick it is) between the two rear corners of the hood and the windshield. If the hood slides back those sharp corners can crack/chip your windshield.
AFM #725
Nope, nothing is necessary besides this simple step. Put both of the hood shocks into the freezer. Go to bed. Next day just take off that clip and the pin and pop in the new shock on each side. Simple.
curtisr
Ditto. When the struts die.
Incorrigible
Mi.e required no freezer, and no cardboard, but both sound like reasonable methods.
Jeff
No need to fear new hood struts.... the hatch is another issue. New struts on an old hatch will end up causing seperation of the glass from the frame. Don't do it ! My hatch hasn't been opened in years but if I do.... then a small pair of vice grips to hold it open.
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
Incorrigible
Until now. ![]() Jeff
AFM #725
It takes 30 seconds per side!
Incorrigible
This thread was really intended as a joke.
Now you are in on it, too. ![]() Jeff
AFM #725
Don't feed the trolls
My hood struts are useable but, not perfect(who knows, they may have been replaced at some point in the last 30).. The hatch struts are dead but, the latch mechanism is the bigger problem, one side sticks and has to be manually fiddled with from the inside. A thousand little things, where does one start
Janet '83 944 |
Incorrigible
AFM #725
Thread Tools | |
Rate This Thread | |
