Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
robs944's Avatar
Price seems a little on the high side to me. I paid 10,000 less for my 89 Turbo; of course you have to take into account 160K on the clock (rebuild at 145K) maint records. Everything works interior in great shape (no seat tears or dash cracks) only a minor exterior blemish (little dent in hood). I looked around for quite a while before I found it.
KBB values the 88 Turbo S your looking at (excellent cond, 75,200 miles, loaded)
a little over $8,000 for private party sale and $9,700 for retail.......of course that is subjective.
If I was going to pay that amount I would expect the "Silver Rose" model, in excellent shape.
There are cheaper ones out there, little higher mileage but well sorted.
Are you looking for a track car, daily driver???
Rob
87 944 * 89 951
"When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car."
Old 10-19-2007, 11:56 AM
Super Moderator
nize's Avatar
searching for this information turns up bits and pieces, but not a complete list. i'm surprised someone hasn't already come up with this list yet, so here goes.
how to visibly tell a 1988 951 turbo-s (must meet ALL of the below requirements). note that all 1989+ 951's are automatically turbo-s.
visible outside the car;
bigger front brakes from 928s4 (the non-s has front/rear brakes of the same size)
rolled rear fenders to accommodate larger wheels (this can be felt by hand, the non-s will have rear fenders with sharp edges)
turbo-s forged aluminum wheels (not available on the non-s, but easily swapped. beware of immitation d-90 wheels!)
visible under the car;
koni yellow adjustable shocks all around (this was the m030 option on the non-s)
ride-height adjustment threaded collars on the front struts (not sure if this was an option for the non-s)
thicker 26.8mm front sway bar (not as obvious unless you're familiar with sway bar diameters)
metal transmission cooling coil on rear-passenger side (available as option on the non-s)
M030 front hubs and spindles with ABS sensors
Rear trailing arms drilled and tapped for ABS sensors
visible inside the car;
abs (light visible on dash, the non-s had abs as an option)
full power seats for both driver and passenger (available as an option on the non-s)
10 speaker sound system and equalizer/amp. it has different speaker panels on the doors and the EQ below the radio
visible under the hood;
engine designation M44/52
engine number between 47J00001 - 47J01830
adjustable front shocks (available as an option on the non-s)
intake manifold has two vacuum ports instead of one (the one with the 12mm banjo bolt)
chassis stiffening brackets in the front for the struts
ac dryer lines are different to clear the front frame brace on the drivers side.
larger turbocharger (not available on the non-s). how to tell instructions here;
http://www.clarks-garage.com/shop-manual/eng-19.htm
less obvious or not easily visible differences;
larger sodium-filled exhaust valves
progressive springs
larger 25.5mm rear torsion bars
harder bushings throughout
1st gear hardened transmission
2nd gear hardened transmission
limited slip differential (available as an option on the non-s, can tell by jacking the rear of the car and turning one wheel to see which way the opposite wheel turns)
AOR Case Code Transmission: the turbo-s LSD had thicker friction discs and modified pressure cups to accommodate the thicker discs (AOR code is visible on top of the transmission with tranny removed)
larger front brake discs (.2" bigger)
different DME and KLR - chips were mapped for the K26/8 turbocharger
references;
porsche 944 turbo (link dead as of 7/28/2011);
http://vista.pca.org/stl/944turbo.htm
preserved web.archive.org:
https://web.archive.org/web/20041117101432/http://vista.pca.org/stl/944turbo.htm
turbo-s registry (link dead as of 7/28/2011);
http://www.geocities.com/MotorCity/Pit/4786/
https://web.archive.org/web/20091027032350/http://www.geocities.com/MotorCity/Pit/4786/
i'll add to this list as additional things come to mind. please contribute.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 10-19-2007, 12:09 PM
schmedes1's Avatar
Very cool Peter!
1989 944 Turbo (100% stock and restored)
1996 Mustang Cobra - Track Ready via Griggs Racing
Old 10-21-2007, 03:33 PM
schmedes1's Avatar
Originally Posted by schmedes1 View Post
Very cool Peter!
... and we know a great guy who probably has all this and more details...
Old 10-21-2007, 03:36 PM
armandodiaz's Avatar
I'm looking for a strickly street, completely stock.
Just had a preliminary talk with the owner about price. I suggested mid teens, he said the car is in such good shape he will not let it go for under $17K. What ya think?
I'm also looking at a 94 968:
http://www.autotrader.com/fyc/vdp.jsp?rdpage=thumb&car_id=226589211&dealer_id=60 661195&car_year=1994&model=968&num_records=25&make 2=&start_year=1981&keywordsfyc=&keywordsrep=&engin e=&certified=&body_code=0&fuel=&awsp=false&search_ type=both&distance=0&marketZipError=false&search_l ang=en&make=POR&color=&page_location=findacar%3A%3 Aispsearchform&min_price=&drive=&default_sort=pric eDESC&max_mileage=&style_flag=1&sort_type=priceDES C&address=33028&advanced=&end_year=2008&doors=&tra nsmission=&max_price=&cardist=607
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 10-22-2007, 12:36 PM
Super Moderator
nize's Avatar
looks good, though personally i'd prefer a 951 for that price.
Old 10-22-2007, 01:54 PM
bearone2's Avatar
for close to the same money, you outta take a hard look at the 968.
maint records are important on both.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 10-22-2007, 02:51 PM
After strongely chasing after 2 968s I ended up getting the 951S. My brother who's a Porsche tech at a local dealer looked at it and said it was one of the nicest ones he has seen in a long time. The only thing wrong was a leaking PS rack. So I was able to talk him into taking the price of the rack off. I'll be picking it up tomorrow. Final price $16.750.
I'll take pictures and post next week.
Why not the 968s? I really wanted one (I have always like them) but these owner's think they got gold and don't want to bugde on price.
Armando Diaz
Old 10-26-2007, 09:41 AM
Super Moderator
nize's Avatar
951 will outrun a 968 easily.
Old 10-26-2007, 10:13 AM
vott does ziss do?
ronin's Avatar
that price is way high. the ad says "just serviced". with what? an oil change and a wash?
what did the records reveal?
Old 11-02-2007, 12:12 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
thats very high, IMO. the option for the turbo S is M758 iirc. included are 10 speaker sound, split rear seat, LSD, 928 S4 brakes, rolled fenders, full adj. koni susp, ABS, stiffened chassis, clubsport wheels, and of course the k26/8 turbocharger.
let us know if you buy it, perhaps i could come oogle it
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 11-06-2007, 05:33 AM
I bought it a week ago. I'm still doing some detailing to it and also added tint. I'm still trying to decide weather to put the "Turbo" script on the right fender. I can't believe Porsche didn't do any visual changes to distinguish it from the regular turbo. I'm also adding a new sound system, which I'm trying to decide which way to go on it.
To all who say I paid too much. When ever I floor it and the turbo kicks in, it's worth every penny I spent on it. I would dare to say, it feels better than the 996 I just sold.
Armando Diaz
Old 11-06-2007, 05:40 AM
ERAU944's Avatar
if it's worth it to you, who cares what anyone else says. sure i paid way way WAY less than that, but i'll also enjoy replacing brakes, exhaust seals, and a few other needed items.
looks like i need to polish my wheels also.
Old 11-06-2007, 05:55 AM
ERAU944's Avatar
btw how's that cup motor running?
Super Moderator
nize's Avatar
i'm happy you bought it! post up some pics!
Old 11-06-2007, 08:29 AM
Super Moderator
nize's Avatar
here is the factory frame rail stiffener brackets on the turbo-s;
Old 06-07-2010, 08:49 AM
All Spooled Up
I guess that answers the question of why the following came up when I tried to view the link: This car is no longer listed for sale.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold)
Old 06-08-2010, 07:40 AM
BoxsterGT's Avatar
Porsche Crest
I have a real turbo S for sale if anyone is interested..........
Its a project car.
Please email me for details.
Len at Autosportengineering dot com
Old 07-07-2010, 11:08 AM
Super Moderator
nize's Avatar
i guess i'll ask the obvious question, why does that car not have the factory turbo-s wheels?
Old 07-07-2010, 11:14 AM
BoxsterGT's Avatar
That how I got it.
Right now its for sale. Once I finish a few other projects I may decide to keep it & finish it myself.
It has air bags & ABS & some features my 86 turbo does not have.
Old 07-07-2010, 11:52 AM
