Price seems a little on the high side to me. I paid 10,000 less for my 89 Turbo; of course you have to take into account 160K on the clock (rebuild at 145K) maint records. Everything works interior in great shape (no seat tears or dash cracks) only a minor exterior blemish (little dent in hood). I looked around for quite a while before I found it.
KBB values the 88 Turbo S your looking at (excellent cond, 75,200 miles, loaded) a little over $8,000 for private party sale and $9,700 for retail.......of course that is subjective. If I was going to pay that amount I would expect the "Silver Rose" model, in excellent shape. There are cheaper ones out there, little higher mileage but well sorted. Are you looking for a track car, daily driver???
Rob 87 944 * 89 951 "When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car." |
Super Moderator
searching for this information turns up bits and pieces, but not a complete list. i'm surprised someone hasn't already come up with this list yet, so here goes.
how to visibly tell a 1988 951 turbo-s (must meet ALL of the below requirements). note that all 1989+ 951's are automatically turbo-s. visible outside the car; bigger front brakes from 928s4 (the non-s has front/rear brakes of the same size) rolled rear fenders to accommodate larger wheels (this can be felt by hand, the non-s will have rear fenders with sharp edges) turbo-s forged aluminum wheels (not available on the non-s, but easily swapped. beware of immitation d-90 wheels!) visible under the car; koni yellow adjustable shocks all around (this was the m030 option on the non-s) ride-height adjustment threaded collars on the front struts (not sure if this was an option for the non-s) thicker 26.8mm front sway bar (not as obvious unless you're familiar with sway bar diameters) metal transmission cooling coil on rear-passenger side (available as option on the non-s) M030 front hubs and spindles with ABS sensors Rear trailing arms drilled and tapped for ABS sensors visible inside the car; abs (light visible on dash, the non-s had abs as an option) full power seats for both driver and passenger (available as an option on the non-s) 10 speaker sound system and equalizer/amp. it has different speaker panels on the doors and the EQ below the radio visible under the hood; engine designation M44/52 engine number between 47J00001 - 47J01830 adjustable front shocks (available as an option on the non-s) intake manifold has two vacuum ports instead of one (the one with the 12mm banjo bolt) chassis stiffening brackets in the front for the struts ac dryer lines are different to clear the front frame brace on the drivers side. larger turbocharger (not available on the non-s). how to tell instructions here; http://www.clarks-garage.com/shop-manual/eng-19.htm less obvious or not easily visible differences; larger sodium-filled exhaust valves progressive springs larger 25.5mm rear torsion bars harder bushings throughout 1st gear hardened transmission 2nd gear hardened transmission limited slip differential (available as an option on the non-s, can tell by jacking the rear of the car and turning one wheel to see which way the opposite wheel turns) AOR Case Code Transmission: the turbo-s LSD had thicker friction discs and modified pressure cups to accommodate the thicker discs (AOR code is visible on top of the transmission with tranny removed) larger front brake discs (.2" bigger) different DME and KLR - chips were mapped for the K26/8 turbocharger references; porsche 944 turbo (link dead as of 7/28/2011); http://vista.pca.org/stl/944turbo.htm preserved web.archive.org: https://web.archive.org/web/20041117101432/http://vista.pca.org/stl/944turbo.htm turbo-s registry (link dead as of 7/28/2011); http://www.geocities.com/MotorCity/Pit/4786/ preserved web.archive.org: https://web.archive.org/web/20091027032350/http://www.geocities.com/MotorCity/Pit/4786/ i'll add to this list as additional things come to mind. please contribute.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) Last edited by nize; 03-22-2020 at 08:42 AM.. |
Very cool Peter!
1989 944 Turbo (100% stock and restored) ![]() 1996 Mustang Cobra - Track Ready via Griggs Racing |
... and we know a great guy who probably has all this and more details...
Super Moderator
looks good, though personally i'd prefer a 951 for that price.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
for close to the same money, you outta take a hard look at the 968.
maint records are important on both.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
After strongely chasing after 2 968s I ended up getting the 951S. My brother who's a Porsche tech at a local dealer looked at it and said it was one of the nicest ones he has seen in a long time. The only thing wrong was a leaking PS rack. So I was able to talk him into taking the price of the rack off. I'll be picking it up tomorrow. Final price $16.750.
I'll take pictures and post next week. Why not the 968s? I really wanted one (I have always like them) but these owner's think they got gold and don't want to bugde on price.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
Super Moderator
951 will outrun a 968 easily.
vott does ziss do?
that price is way high. the ad says "just serviced". with what? an oil change and a wash?
what did the records reveal?
thats very high, IMO. the option for the turbo S is M758 iirc. included are 10 speaker sound, split rear seat, LSD, 928 S4 brakes, rolled fenders, full adj. koni susp, ABS, stiffened chassis, clubsport wheels, and of course the k26/8 turbocharger.
let us know if you buy it, perhaps i could come oogle it
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
I bought it a week ago. I'm still doing some detailing to it and also added tint. I'm still trying to decide weather to put the "Turbo" script on the right fender. I can't believe Porsche didn't do any visual changes to distinguish it from the regular turbo. I'm also adding a new sound system, which I'm trying to decide which way to go on it.
To all who say I paid too much. When ever I floor it and the turbo kicks in, it's worth every penny I spent on it. I would dare to say, it feels better than the 996 I just sold.
if it's worth it to you, who cares what anyone else says. sure i paid way way WAY less than that, but i'll also enjoy replacing brakes, exhaust seals, and a few other needed items.
looks like i need to polish my wheels also.
btw how's that cup motor running?
Super Moderator
i'm happy you bought it! post up some pics!
Super Moderator
here is the factory frame rail stiffener brackets on the turbo-s;
All Spooled Up
I guess that answers the question of why the following came up when I tried to view the link: This car is no longer listed for sale.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
![]() I have a real turbo S for sale if anyone is interested.......... ![]() Its a project car. Please email me for details. Len at Autosportengineering dot com
Super Moderator
i guess i'll ask the obvious question, why does that car not have the factory turbo-s wheels?
![]() That how I got it. Right now its for sale. Once I finish a few other projects I may decide to keep it & finish it myself. It has air bags & ABS & some features my 86 turbo does not have. Len at Autosportengineering dot com
