winter-hater club member
does removing the battery 'reset' the computer?
as the title says....
thanks, darell
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Rogue Tuning
On the 951? The 951 does not have a 'memory'. There is nothing to reset.
-Rogue
-Joshua www.RogueTuning.com |
yes, on the 951. any other takers? i think rogue is correct.
still trying to sort another problem and i thought that *IF* the computer were 'reset'....
Rogue Tuning
I know I'm correct
![]() The DME does not have any non-volatile memory, besides the EPROM (which the DME can't change the code). What kind of issues are you having?
failed emissions. high CO and high HC. which is EXACTLY the opposite of what i expected. i was expecting high NOx.
i think my air filter was plugged.
Rogue Tuning
How old is your O2 sensor?
two years, i think. at most, three years.
i pulled the k&n air filter and it was very dirty. i cleaned it and re-oiled it. back to the IM station tomorrow.
i checked the voltage coming from the O2 sensor: .3V at idle, dropping to .15 or so revved. i thought it was supposed to be around .8V at idle. can someone confirm?
Rogue Tuning
Hmm, O2 should cycle once the car is warmed-up and in closed-loop. It should cycle around .5v when in closed-loop.
Might have a bad O2.
yeah, i think it might be bad. i'll be replacing it tomorrow.
new O2 sensor reads .9V at idle and heated up. the 951 passed emissions, with significantly better numbers.
Rogue Tuning
Good news!
-Rogue
All Spooled Up
Conversely, you could say that it gets reset every time the ignition is turned off.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Rogue Tuning
Eh - semantics. The 951 does not have a 'fuel trim' or other resident memory feature...
-Rogue
All Spooled Up
Looks like, technically speaking, you got me on that one. What can I say? - nice job!
