Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Bell housing work
Audi V6 spacer welded to 931 Bell.
Old 11-08-2019, 01:24 PM
Hvac
Going over the Late model HVAC unit, needs some work. few things broken, but all repairable. I got the whole unit for free. so I am not worried.
Old 11-08-2019, 07:44 PM
Steering
received my A8 steering column system that I am going to either pull it apart and use what I need, or adapt the whole set up which would be really cool to have the adjuster system and all for it. will see how it all pans out when I go home to work on my swap after the 20th of Dec. If it does work out like I am thinking. I will have some fun and try molding in a Porsche crest to the steering wheel center.
Old 12-11-2019, 01:00 AM
HVAC fitting
Hey all, working on fitting the late model 944 HVAC unit in. It is going pretty good, got it set about where it needs to go, required some extra cutting.... but what has not required that on this lol! But it will be a nice upgrade from the old worn out 81 924 stuff.
I will continue working on her after Christmas
The Dash will require a bit of mod work, but nothing crazy at a, was pretty surprised at how well it fit over the upper section.
Old 12-23-2019, 11:09 PM
Update!!
https://www.youtube.com/watch?v=jRPi51xZ-Kk&feature=share
Old 12-26-2019, 06:22 PM
HVAC Unit Update
Went through and opened up the blower system area, made my upper support shelf and bracket. very pleased with the progress.
Old 12-26-2019, 09:53 PM
HVAC Unit Update
almost have the passenger side paneled up, and the rear upper section done around the HVAC unit, it is going slow, but smooth, which is great. lots of hand fabwork for sure.
Old 12-27-2019, 09:32 PM
Passenger side header
Fabricating the Passenger side header, it has turn out pretty good. quiet pleased with the shape, everything is tacked into to place and can be installed and removed with out taking it apart, which is huge! considering the space I am working with.
Drivers side is certainly going to be more tricky.
Old 12-28-2019, 07:59 PM
Drivers side header
Fabricated the drivers side header. I am really happy with the progress this trip, tomorrow is my last day for working on her until possibly May or June.
Old 12-31-2019, 05:26 PM
This was super cool to see. my 924 got her own little article on Pistonheads.
https://www.pistonheads.com/news/ph-germancars/porsche-924-v8--readers-car-of-the-week/41577
Old 01-16-2020, 12:07 AM
Dashboard work
Hey all. I will be starting my Dashboard modifications and repairs to fit my A8 cluster and to make room for my wiring that will need to go through. I will post pictures of the dash as I make progress. should be able to start it this coming Friday or Saturday. depending on work schedule. Thankfully I have 2 spare dashboards here I pulled out of 2 old cars going to the scrap due to some awful crash damage. I plan to do the top of the Dash in Black, and the lower half in out family tartan as shown in my thread a bit earlier on my Door cards and arm rest/cassette holder
Old 01-22-2020, 12:46 AM
Dashboard work In Progress
Started working my 924 Dash First time ever recovering a dash, so been a big learning event. pretty happy with results. Also fitting the A8 Cluster into the dash. happy so far. the Plaid is our Family Tartan.
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 01-25-2020, 08:15 PM
Dashboard work In Progress cont.
Old 01-25-2020, 08:17 PM
I will continue to work as time permits ^_^
Old 01-25-2020, 08:19 PM
Dash material Change
Having a lot of fun. I changed the upper dash material. Now I need to order more haah!
Old 01-31-2020, 07:42 PM
Steering column
https://www.youtube.com/watch?v=OG1hWNN3MdQ&feature=share
Old 02-14-2020, 11:09 PM
steering column set up
Old 02-20-2020, 07:13 PM
Calipers
Worked on my Calipers today, Base coat color is down, next will be all new hardware, bleed ports, and turning the letters Silver.
Old 06-16-2020, 10:33 PM
Caliper Progress
Made some more progress on my calipers. First coat on Paint applied to the Letters and markings.
Old 07-01-2020, 06:55 PM
Intake
Did some work on my 4.2L intake. The lower air gate was jammed to the shut position which ends up breaking the Actuator arm. Next I will be sealing the intake back up and the wrapping it up for transport back up to my Dad's place where my 924 is.
Here is a Picture of how the gates actuate.
Old 07-03-2020, 10:43 PM
