LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Perfect explanation exactly what I was looking for.
Old 06-14-2017, 12:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
More progress tonight. Jacked rear of car up. Supported engine on floor jack. Removed rear engine tin, removed engine support bracket bolts, and then engine mount bolts.
I was then able to remove engine support bracket and support beam in one piece, exposing crank pulley.
Old 06-14-2017, 05:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
Work in Progress
Rich76_911s's Avatar
Nice work. The engine looks really clean.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 06-14-2017, 05:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
I put the tranny in 3rd gear, put parking brake on, and crank bolt came loose very easily.
Old GSF pulley looks to be in good shape.
Test fit new pulley and VR sensor. No issues that I can see. What should gap be set at?
1 mm?
I torqued pulley bolt to 59 ft.lbs. as per Bentley manual.
I did temporarily install engine support bracket and support beam, just so I could get under engine easily to remove oil pump. That's tomorrow nights job.
Old 06-14-2017, 05:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Here is my proposed location for Cam sensor.
Old 06-14-2017, 06:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
Was thinking about temperature sensors.
I am currently running the Bosch Cylinder Head Temperature sensor. This is a single wire and I don't have the exact thermistor values. I am also concerned that with it being a single wire there is no sensor return wire.
Should I be concern about this? On my old SDS system this sensor work well, gave quick warmup values, although not to sure about it's accuracy. I was wondering if any one else is using this type of sensor? Should I consider going to a GM Coolant temp sensor, and if so where is the best place to locate. I understand these are 3/8 NPT threads. What about oil chimney at rear of engine. Is it simply a case of tapping the old sensor location for 3/8 NPT?
Old 06-14-2017, 06:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
Was given this link on Megasquirt Facebook page.
https://www.porscherepair.us/porsche-911-1984-1989/cylinder-head-temperature-sensor-testing.html
Old 06-14-2017, 07:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
Stick with the head temp, oil temp is too slow.
Old 06-15-2017, 04:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
I will give it a shot. I noticed in Tunerstudio there is a setting for a VW CHT sensor.
Old 06-15-2017, 05:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
Work in Progress
Your torque setting on the crankshaft bolt seemed a lot lower than I remembered setting mine at. So I checked in Waynes book. According to Wayne the 59 ft/lbs is for engines without AC, engines with AC get 125.3 ft/lbs of torque.
Just wanted to pass that information along.
Awesome progress.
Rich
Old 06-15-2017, 06:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
Thanks Rich, I will re-torque. I probably will never run AC again, but good to know.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 06-15-2017, 09:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
Crank bolt retorqued to 125 lbs.ft. Got the oil pump out. I have to pickup a 12mmx1 tap to tap hole for sensor. Sensor is a Hamlin 55075-02. It has pickup resistor.
Old 06-15-2017, 04:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
Old 06-15-2017, 04:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
I was wondering if I should use a little JB Weld to lock the sensor nuts in place? Or perhaps some Blue Locktite.
Old 06-15-2017, 04:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
Jake Barrell
I completely agree that the ms3pro is absolutely great. The best thing about it is that it is easy to wire and setup. And works like a charm!
Old 06-16-2017, 04:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
Use the blue loctite, you don't want JB Weld on the threads.
Old 06-16-2017, 05:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
scottrx7tt's Avatar
Clewett makes a great solution for the cam sensor.
1978-98 Cam sync adapter w/sensor [1001-61] - $190.00 : Clewett Engineering, The complete solution for ignition & fuel injection
Old 06-16-2017, 05:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
Hoping to be up and running this Sunday if every thing goes well. Really just plug and play from here.
Old 06-16-2017, 05:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
Hi guys
Today I got the oil pump modified for full sequential. Took me approximately 3 hrs to remove the pump assembly, disassemble, drill and tap the housing, test fit, find crank position on compression 90d BTDC, Drilled and tap cam pulley. Installed cam pulley, set cam sensor and pulley bolt clearance to 1mm. Used blue locktite. Then reassembled oil pump, reinstalled lines. Also managed to get rear engine tin back on. Along with exhaust mount bracket. Tomorrow I will be concentrate on installing wiring harnesses.
Old 06-17-2017, 04:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
I was wondering if someone could provide me with a startup or base tune?
What are most people using for tuning, laptop, tablet, raspberry Pi?
I will make sure I do a video of first start.
Old 06-17-2017, 04:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
