9dreizig's Avatar
Send a message via AIM to 9dreizig
Ok I'm finally giving this some serious consideration since my garage will finally be done in a couple weeks.. Does anyone have or offer a complete parts list for this conversion ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 12-14-2016, 01:57 PM
TurboKraft's Avatar
ECU + harness
EFI Injector Blocks & Fuel Rails (TK)
Injectors -- we use/sell Injector Dynamics or Siemens
Fuel pressure regulator -- pressure depends on sequential or semi-batch
MAP sensor -- usually GM 3bar
TPS + adapter kit (TK)
Head temp sensor + adapter kit (TK)
Air temp sensor (usually GM 3/8NPT)
Crank/flywheel speed sensor & trigger -- mag or hall;
factory mag sensor + machining your flywheel perimeter for timing teeth = very easy, reliable
Camshaft synch signal, hall -- if doing full sequential
Ignition -- how fancy you want it?
a. Lock down distributor, use CDI & coil
b. Distributorless coil-on-plug, smart coils triggered directly by the ECU
We carry all this stuff, make it easy for you. The only thing we don't sell is the MS computer & harness.
A few other things you can add for safety / fail safe setups, or just for info:
* fuel pressure
* oil pressure
* oil temp
Boost control is also easy, solenoid valve and factory low/high switch = clean installation
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 12-14-2016, 02:13 PM
Coil on Plugs whick ones?
Hi All
MS3 Pro will be here any day. Trying to decide which coil packs to go with.
Audi R8 Coils
Or
Honda V6 coils
Anyone have any experience with either?
I understand that the Audi coils are a 4 wire coil. Power, Ground, Signal, and Ground to ECU. Where as Honda is only 3 wire Power, Ground, and Signal.
Would the Audi coils be better from a noise standpoint? Any fitment issues on the lower valve cover?
John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 12-14-2016, 04:55 PM
Chris from Tubrokraft can you modify the Oil Pump housing to accept a hall sensor for me?
If so how much?
John
Old 12-14-2016, 05:08 PM
Chain fence eating turbo
I was going VAG recently, but read lots of threads in MSExtra forums about losing spark as they get hotter. Something about them needing more power than what the ECU can supply requiring additional igniter boxes or buffer boxes or something?
But, those were related to NON-MS3Pro boxes.
Might want to take a quick look before pulling trigger.
I know I wanted the VAG coils because they pop in perfectly apparently in out valve covers.
Old 12-14-2016, 05:34 PM
MS3 Pro Arrives
Hi All
Well Christmas came early. The MS3 Pro arrived today. Thanks Derek.
Looks to be of high quality. Still have some items to purchase.
COPs, Hall Cam Sensor, CHT sensor, Electronic Boost Controller,
80 lbs. Injectors.
Where is best place to install the unit? I was thinking of fabbing up a mounting plate, that fits under passenger seat.
Regards
John
Old 12-16-2016, 10:39 AM
scottrx7tt's Avatar
I have some 60lb Siemens/deka injectors for sale. if you are interested let me know
Originally Posted by jpilcher View Post
Hi All
Well Christmas came early. The MSPro 3 arrived today. Thanks Derek.
80 lbs. Injectors.
Regards
John
Old 12-16-2016, 10:55 AM
If I could do it again, I'd put mine behind the panel in the back seat on the drivers side.
With those straight connectors, youre probably limited to underseat.
Thanks Tippy
That's where my current SDS ECU is mounted. I guess I could just re-use the existing mounting plate.
Regards
John
Old 12-16-2016, 11:23 AM
Slippery slope skier
Costa P's Avatar
I was planning to fit mine under the seat.....but I like this idea better.
Need to invistigate this option further...
'85 930 ...the oil leak rebuild which mutated into more than I could chew... then came back to my senses and climbed "back up" the slippery slope!
A stock 930 is far better than an incomplete project car!
930 rebuild – The revival of my mothballed project
Old 12-16-2016, 12:13 PM
Yeah, I don't know if there's enough real estate for my MS2, but I thought that'd be a great spot
Old 12-16-2016, 12:16 PM
puddy's Avatar
Hey John, i'm curious about that MS3 harness, is there instructions that detail which coloured wire connects to which sensor etc? Something a dummy like me can figure out?
Any chance I can come checkout your set up once you've dove into it. I live about 1.5 hours away, I can't offer any useful technical support but can bring coffee!
Cheers, Chris
1986 951
SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Old 12-16-2016, 12:30 PM
TurboKraft's Avatar
Hi All
Audi R8 Coils
Or
Honda V6 coils
John
Why reinvent the wheel?
We tried over 20 different COP units -- German, US, Japanese -- to find ones that work exceptionally well on the 911 engines.
* checking for fitment on the engine:
* whether it would clear the frame rails with the engine in the car so you could actually service it (we once got a customer's car in that another shop had done -- impossible to R&I the coils with the engine in! Idiots.)
* whether they had the firepower to support serious cylinder pressure -- so far, we've done over 125hp/cylinder without a problem. A drag car on the dyno did 44psi, no spark issues.
We settled on a Toyota/Lexus-application COP that is easily supporting 125+hp/cylinder. We were blown away when we saw a 4-cylinder Time Attack car on the dyno run 45psi boost with these COPs and have no ignition issues.
They fit quite securely, or you can restrain with the old RSR-style hold-down tabs if desired.
If so how much?
John
Yes, have done that before.
Which sensor do you have -- or do you need one, too?
Last job we did with machining + sensor + connector was $245.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 12-16-2016, 12:40 PM
TurboKraft's Avatar
Behind the seats, on the vertical panel at the end of the floor pan.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 12-16-2016, 12:44 PM
Hi Chris
Thanks for info on Toyota plugs. Can you give me a price for a set of 12? Please PM me.
I do not have sensor yet. $245 sounds good to me. I will get oil pump housing removed over Christmas and send it down to you. Does your sensor come with pull up resistor?
John
Old 12-16-2016, 12:51 PM
The MegaSquirt harnesses have the wires labeled in print on the insualtion/sheath like every 6 inches.
You never not know which wire is which.
Old 12-16-2016, 12:52 PM
Hey Puddy
My plan is to start diving into things after Christmas. My first task is to remove my old setup. The most challenging thing being the crank pulley. Your welcome to come to my place anytime. Chris at Turbokraft is going to modify the oil pump to accept a new hall sensor for the cam trigger.
I hope to keep posting my progress as things happen.
Regards
John
Old 12-16-2016, 03:49 PM
puddy's Avatar
Ok thanks John, I'll be watching and will be in touch.
Cheers, Chris
1986 951
Old 12-17-2016, 06:43 AM
Costa P's Avatar
I like this spot for the short run for the harness.
But I'm having 2nd thoughts regarding:
a) the exposure to being bumped/kicked
b) don't necessarily want to advertise the EFI conversion so openly. I'm thinking I prefer a more stealth install...
Old 12-18-2016, 01:15 PM
The MS3-Pro Fits under the drivers seat just fine.
I followed the same route for the harness as the factory did on the NA Carrera. In the corner of the drivers side passenger area where the floor pan meets the rear seat lateral wall there is a gromet/plug. I just went to the local junkyard and found a wiring harness grommet
with the same diameter and used that.
Old 12-18-2016, 02:03 PM
