xbmwguy - how did you handle the twin COPs on your car with the MS3?
Injectors and fast idle valve do not get grounded to block. One pin on Injectors get +12 volts from fuse block. The other pin is a ground signal to fire injector which comes from ms3pro. PIN# 1,2,4,6,8,10 "Grey Connector on MS3pro." Fast idle valve gets power on center pin (3 wire connector). The other pins get idle pwm signals from ms3pro. Pwm is always switched on the ground side of a pwm controlled device. On my setup I am using: Pin#14 PWM (idle out) "White Connector on MS3pro" to one side of the idle valve +12 volts from fuse block to center pin of idle valve Pin#29 PWM out2 "White Connector on MS3pro" to other side of idle valve The 3 wire idle valve works by varying the duty cycle on two opposed coils in the idle valve. In theory lets say you have 50% duty cycle on each of the opposing coils and the valve is closed. When you apply lets say 51% duty cycle on one side and 49% on the other side the valve opens slightly. Apply 52% and 48% the valve opens a little more and so on and so on. Last edited by nocarrier; 01-12-2017 at 07:21 AM.. |
Nocarrier is correct. The injectors and idle valve are grounded through the MS3Pro.
I am sure xbmwguy will chime in, but I believe he wired both logic inputs for the dual coils to each MS3X spark output. There has been a lot of debate about whether the MS3X spark outputs could handle the current for two coils. But it has apparently worked well for him with these Toyota COP's. It all depends on the input impedance of the coil's logic circuit. Toyota (Denso) will work. Other brands may not. Also, I have heard that the MS3Pro spark outputs can handle more current than the MS3X.
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R |
The BOSCH bip373 ignition driver tranistor designed especially for ignition and used in a lot of coils only draws about 25ma max to trigger (typical 5-12ma) That would mean 8 drivers one one channel! I have no idea what the toyota logic level input draws exactly but we split the signal with no issues. One day I will hook my scope up to one and get the data. |
Thanks a lot guys for the input I really appreciate it, this is great information.
Dennis you are spot on. The ms3 pro does have more output for coils. I went ms3x as I thought I would need all the expand ability it offered but I'm barely scratching the surface. Oh well it's working just fine
88 930 3.4 ,Twin plugged billet Xtreme cylinder heads and denso COPs, Dougherty custom GT 2 evo cams,pauter rods,Garrett Gt40,ms3x Efi ,1100cc injectors,extrude honed 3.2 intake,TK billet fullbay I/C,MODE headers,KEP stage 2, E-85, 706 rwhp |
x2 on the great info, thanks. MS3Pro is looking good.
Follow
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
Hi Guys
Haven't posted for a while. I have received some parts in the last 2 weeks. Here is my list: DiyAutoTune 460pc WeatherPack Connector Kit https://www.diyautotune.com/product/460-piece-weather-pack-kit/ GSF 36-1 Crank Pulley wheel for Megasquirt http://www.goingsuperfast.com/Porsche.html Ford Crank VR Sensor http://www.goingsuperfast.com/Porsche.html Hall Effect Sensor Litttlelfuse 55075 Stainless Steel M12 Geartooth Cam Sensor c/w resistor http://www.mouser.com/ds/2/240/Littelfuse_Hall_Effect_Sensors_55075_Datasheet.pdf-938853.pdf EBC from DIYAutotune https://www.diyautotune.com/product/ebc-electronic-boost-control-solenoid-kit/ 12 Toyota coil on Plug Connectors Balanger Autosport https://www.bmotorsports.com/shop/product_info.php/products_id/1667 6 EV6 Fuel Injector Connectors https://www.diyautotune.com/product/fuel-injector-pigtails-bosch-ev6/ GM 3Bar Map Connector https://www.diyautotune.com/product/map-gm-3-bar-map-sensor-6-pigtail/ GM IAT Connector https://www.diyautotune.com/product/iat-sensor-pigtail-for-gm-open-element-sensors/ 3 Wire Bosch IAC 20'Roll of Sheiled Wire Only thing missing is 12 Toyota Coil on Plugs. Trying source best deal, looking at going true Denso versus aftermarket. Regards John
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. Last edited by jpilcher; 02-07-2017 at 01:55 PM.. |
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD. |
Should I run shield wire for Cam Sensor? The roll I show up above is 2 wire for the crank sensor.
Regards John
I ran both crank and cam with shielded. Unlike using ford EDIS which needs a ground on the cam sensor shield I decided to do it to help alleviate noise
I will pick up a spool of 3 wire shielded wire, Thanks xbmwguy.
Is it it okay to run used Denso COPs? or should I go new?
Chain fence eating turbo
Yes, shield the cam trigger. Used Denso is fine, IMO, they make the best auto electronics.
Also looking for some high Z 80 Lbs. injectors. Ev6 Connectors. Longer stye.
Injector dynamics
You should ground one end (source end) of the shielded cable. This provides a drain from the Faraday effect from the emi produced by the signal wires. Without this drain you can induce unwanted noise on the signal wires. Grounding both sides of the shield can induce potential differences.
