Jozef Schumann's Avatar
The 'Well, I bought it' R11S Trans Failure - UPDATE!
Originally failed at 18.935 miles
64,910 miles later.
Hello gentlemen. It's been a long while since I've actively participated though not due to a lack of want, but from an ongoing cardiac issue which, as some of you may recall - I underwent a triple bypass procedure back on 11/06/2012. I've had a couple of related issues - fortunately, all is A-Okay for now. Enough of that - Let's jump right into my long term oil head esmirspacer evaluation.
Though not by majority consensus, a few pelicans, ( I admit I am one) - felt spacing the clutch hub for full clutch hub/input shaft spline engagement would result in an temporary-at-best fix as many were of the opinion that concentric indexing was/is the root cause of this boggle, and perhaps - this may very well be the case - on an unknown number of machines. My particular machine, however, failed dramatically at the 18,935 mile mark and has subsequently accumulated some 64,910 miles post spacer/input shaft retrofit/replacement.
Now - bear in mind, as I had indicated in prior posts, my machine has been mercilessly flogged on an almost daily basis for tens of thousands of miles by numerous riders in a veritable plethora of dynamic scenario's ranging from hour after hour of heavy commuter traffic situations to several all out closed course track days and no less than three cross country L.A. to Boston and back trips - with the specific intent to expose any weakness of the esmirspacer clutch hub modification. Basically, I volunteered my machine as an evaluation guinea pig in order to glean valuable empirical data providing useful information to the oilhead community. Yes, the transmission bearing did fail - however, considering the terrific amount of abuse imposed by such rigorous stress testing - the now proven long term durability of components, particularly the hub spacer allowing full engagement of available spline area is impressive - So much so that I sourced another option which addresses this well known potentially catastrophic BMW engineering shortfall and here it is:
Correct dimension fully broached hub. NO spacer required! Exceptional Quality - Made in Japan (not China) by an well known automotive friction disc manufacturer. For those interested - I have only a very limited number of these available.
$189 free ship anywhere in the states. Anywhere else on the planet contact me.
J.S.
Old 06-14-2017, 02:10 AM
Registered Agitator
sgoodwin's Avatar
Was this made specifically for the 1100S or is it a stock item for something else?
Glad to hear you're doing well.
Old 06-14-2017, 03:26 AM
encantado
darkonaut's Avatar
thanks for checking back in. your original thread was one of the most descriptive "splines lol" stories and the difference in your wear patterns is night and day--really sobering actually. i'm considering buying some of these puppies for when mine wears out...
like sgoodwin i am interested in knowing more about the mystery japanese source
which trans bearing failed? if it was the one closest to the clutch unit i would wonder about extra loads on it from the heavier clutch disc spinning on the input shaft closer to the bearing
"It’s what makes life interesting, finding the balance between cigarettes and tofu."
Old 06-14-2017, 04:24 AM
It looks like it was the front intermediate shaft bearing. At least, that is the one that broke through the casting.
Old 06-14-2017, 04:40 AM
Brent
ohh ohh can i have one.
I can pp money
Old 06-14-2017, 06:25 AM
Milepost Racing's Avatar
Thanks J.S.! I'm thinking of doing this to my BCR over next winter. Please PM me with your info... Will PP be OK? I'll be ordering one up in few weeks.
Old 06-14-2017, 07:30 AM
Yes, it's specifically made for BMW oilheads. I'll be posting additional photos illustrating a side by side vs. O.E. and Siebenrock discs later today.
J.S.
Old 06-14-2017, 09:35 AM
I can pp money
Yes, Brent. You certainly can! I pm'd you my paypal info. I'll try getting it out to you the same day as payment is received - no later than the next day unless, of course it's Sunday.
J.S.
Old 06-14-2017, 09:37 AM
PayPal info sent - Please post your thoughts upon receiving the disc. Being an ME, my standards are accordingly stringent. This unit surpasses my expectations and am quite certain you'll concur.
J.S.
Old 06-14-2017, 09:43 AM
terrym's Avatar
I'll take one. Please send PayPal info.
Terry
2016 Cayman
2004 R1150S
Old 06-14-2017, 11:15 AM
Jon
BMWWERX's Avatar
It is for the Sachs or OEM clutch disc correct? Would like one too. Please PM your PP info. and thanks
Old 06-14-2017, 12:25 PM
If you have one left I would like one as well.
Old 06-14-2017, 12:37 PM
If you sell out of first batch, will you order more?
How many is "very limited" 5, 50, 500?
Thanks!
Old 06-14-2017, 05:03 PM
Thanks!
Of course, good question:
Several sold - 2 remaining. 20 more on the way - which should be available by the end of next month if not sooner. Stay tuned.
Also, check back as I'll be posting more photos as well as additional pertinent details later this evening.
J.S.
Old 06-14-2017, 05:13 PM
Hello Jozef,
Quick question, would this work on my 2002 GS1150?
Thanks, Ron
Old 06-14-2017, 05:53 PM
Brent
ok I ppd the money thanks
Old 06-14-2017, 06:14 PM
Originally Posted by Carrottopper View Post
Hello Jozef,
Thanks, Ron
Yes, Ron...The disc suits the following applications - i.e. all oil heads listed below:
•R850R '99-'04
•R1100S '97-'05
•R1150RS '00-'04
•R1150RT '02-'04
•R1150R / ROCKSTER '00-'04
•R1150GS '98-'03
•R1150GSA '01-'05
•R1200C '96-'04
•R1200CL '01-'04
•R1200 MONTAUK '02-'04
J.S.
Old 06-14-2017, 07:19 PM
Got it - Now, all I require is shipping info/address.
(Folks, I appreciate you sending funds via PP "friends/family" - however, this option does not allow me to print out shipping labels nor is there a shipping address shown in transaction details.) I'll gladly absorb the small convenience fee imposed by PayPal.
Thank you Brent - your disc is waiting to be shipped!
J.S.
Old 06-14-2017, 07:42 PM
Here are several additional photos for your collective perusal detailing various specification differences between two popular (O.E.M Sachs/Siebenrock) clutch discs and the newly offered 'superschiebe' (scheibe = disc).
*note - I employed my newly acquired Samsung smartphone in obtaining these photos. Optical deception is at work here as the left and right discs are identical in diameter. The Siebenrock disc, however - is significantly smaller.
The disc order from left - O.E.M Sachs, Siebenrock Basic Plus, 'Superscheibe'
Interestingly, I discovered the highly-touted-by-many Siebenrock disc showing a dimensionally smaller circumference/diameter specification - in addition to a lower friction material surface area value vs. both the O.E.M. Sachs and 'Superscheibe' discs which are virtually identical in this regard as evidenced by the photos below.
O.E.M Sachs = Approx. 164mm
'Superscheibe'= Approx. 164mm
Siebenrock 'basic plus'= Approx. 160mm
More info coming tomorrow
J.S.
Old 06-15-2017, 12:07 AM
Thank you very much for the kind sentiments. Life is precious and not a dress rehearsal. We only have this one shot - live it well and fully. Yes, specifically made for our oil heads. The piece exhibits outstanding quality in materials as well as manufacture. They actually present more favourably than the O.E.M. Sachs and certainly the Siebenrock disc when viewed next to one another.
I should add the price quoted is an introductory price and will most assuredly be going up in the future though I'm hoping to keep the price point for at least a couple of months. Quite a bargain considering alternative options and the inherent ailment being addressed.
J.S.
Old 06-15-2017, 07:56 AM
