My second request for Dennis (he’s a wiring genius and always a pleasure to work with) was to make me another relay socket with foot long leads, so instead of mounting a Bosch relay to the small amount of real estate I have on the rear relay panel, I can use the space available on the panel for relays- I have 5 holes and only one factory relay.
This relay is the one that gets switched on by ignition to power up the EFI and EDIS systems by a bigger gauge of wire.
Rutager West
Old 04-17-2021, 01:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #121 (permalink)
77 Restorer
Fantastic, Rutager! I need to do something similar for the relays and am working with Al on this.
Bert
Bert
77 911 Targa (Maize, or Talbot yellow as the case may be)
04 C4S Cabriolet (sold)
Old 04-17-2021, 03:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #122 (permalink)
al lkosmal's Avatar
Bert, I plan to supply a nice relay that can be used to provide the proper signal to your stock fuel pump relay. It will require you to do some installation and wiring. You might want to talk to Dennis and see what he is supplying too. It sounds like Dennis is using the stock type relay socket....so if you have an available relay socket hole in your panel...it may be a tidier install for you. I'll ship you this relay and instructions on monday, but check out the alternative too.
regards,
al
regards,
al
RGruppe #669
http://www.x-faktory.com/
Old 04-17-2021, 06:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #123 (permalink)
Been doing a lot of thinking and planning without a lot of wrenching, but I feel like I’m solving my little issues.
One of my big goals for this project is reliability, so I spent a bit of time sourcing brass fittings and in doing so realized that I could couple my IAC directly to the vacuum manifold by using a 1/4” to 3/8” NPT fitting. This will eliminate one hose and one fitting as well as solve where to mount the IAC.
I don’t deal with pipe fittings much and man are they confusing as the internal is what they measure from, so the fittings look huge compared to what they are listed as.
Rutager West
Old 04-21-2021, 02:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #124 (permalink)
al lkosmal's Avatar
Rutager,
I recently bought one of the FAST IAC valves. this is a GM style IAC valve in a machined assembly that includes the filter. It is a 4-wire stepper and I got it working pretty well in very little time......using a MS2,3.57.....
This unit, just by luck, threads directly onto the RHD vacuum manifold that I supply.....very tidy install and works well.....I'll post a pic, once the wiring, etc. is finished.
regards,
al
PS: the unit i received is all black...no shiny valve body on mine.....
RGruppe #669
Old 04-21-2021, 05:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #125 (permalink)
Looks interesting Al,
Simpler is better!
Rutager West
Old 04-21-2021, 06:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #126 (permalink)
77 Restorer
regards,
al
regards,
al
Thanks Al. Have communicated with Dennis, and he's wanting to see how Rutager's set up works first. Much appreciated.
Bert
Old 04-22-2021, 05:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #127 (permalink)
Hi Bert,
I plan on testing the adapter out quickly once it arrives as I know it would be useful to many people.
Rutager
Rutager West
Old 04-22-2021, 05:33 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #128 (permalink)
77 Restorer
Hi Bert,
Rutager
Thanks so much Rutager. I hope it works out for you and the rest of us. Collective wisdom is a great thing!
Best,
Bert
Bert
Old 04-22-2021, 07:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #129 (permalink)
The new harness socket for supplying power to the EFI and ignition as well as the fuel relay adapter arrived yesterday and I took the week off for tinkering on the car and around the house, so that’s what I did!
The new harness fits in my new relay panel nicely and will help with a factory appearance and by using the factory relay, I can always swap in the one from the horn or fog lights in an emergency.
Rutager West
Old 04-27-2021, 11:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #130 (permalink)
The fuel pump relay adapter was an idea so I could adapt the current factory wiring to work in a fashion that the ECU wants. Dennis made me up a custom harness and my tests proved that power would go to the pump when the Megasquirt ECU supplied ground and more importantly wouldn’t power the pump when it shouldn’t!
It is going to be a bit interesting to run the wires in the relay panel to mount the socket in an open space- appears that the panel may unbolt at the top giving me some extra room to work.
Also need to figure out a way to label so when my forgetful mind works on it down the road or the next owner or shop finds themselves digging into it.
Rutager West
Old 04-27-2021, 11:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #131 (permalink)
What the...
While cranking over the engine to verify pump operation in the start position I got two backfires?????
...on a engine that physically has no ignition or fuel injectors!
A bit of detective work finally figured out that my masking tape over the intake to stop junk from falling in was stuck well enough that it ripped loudly- whew, I don’t need anymore evidence that I might be going insane.
Just need to remember to put engine back on TDC at cylinder #1 before starting the tune later- good to circulate some oil though.
Rutager West
Old 04-27-2021, 11:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #132 (permalink)
77 Restorer
Pretty exciting update, Rutager! Glad to see you have been able to get more stuff done. And you're right - documenting the changes is a really good thing to think about now, rather than as the memories fade after driving the car for a bit!
Bert
Old 04-27-2021, 12:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #133 (permalink)
Did a bit of wiggling and wrangling and got the socket in the spot next to the original relay- 2nd pump relay location for the turbos.
Rutager West
Old 04-27-2021, 01:05 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #134 (permalink)
77 Restorer
Rutager, which IAC did you go with? I noted the one Al did recommend. Did you decide to put a Y in to get vacuum to the brake boost? Been talking with both Al and Dennis, and given the cold-to-me climate of CO, the better part of valor might be to put one in now rather than later for the very reason you note. Thanks,
Bert
Bert
Old 04-28-2021, 10:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #135 (permalink)
Hi Bert,
After some questions and answers from Al, I opted to stay with the original one he supplied, but instead of extra hoses, I found a brass fitting that allowed me to screw It directly into the vacuum manifold. I like that it is from a Jeep, so likely easy to source if a replacement is ever needed. There was a real cool all in one manifold IAC unit, but it used a BMW part and also needed an resistor wired inline too.
Rutager West
Old 04-28-2021, 11:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #136 (permalink)
Brake booster- I got the PMO units and they have a port on the intake manifold just for the brake booster, so good to go!
Rutager West
Old 04-28-2021, 11:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #137 (permalink)
scumbag
I have this setup with my Triumph ITBs and I hate it. It works just fine. But in my head, it's weird to pull all the vac from one cylinder instead of a little from all 6.
It's on my list of things to change this year...when I add an IACV.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
AchtungKraft #009 - IG: @doktor_b
Old 04-28-2021, 12:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #138 (permalink)
77 Restorer
Thanks Rutager. I don't have the same vacuum manifold as you do, but I think going down this route is the best approach. I did discuss this with Al and Dennis, and they were quite helpful in their thoughts as well. I don't have the PMOs so will need to tap the vacuum manifold either directly or via a Y-connector to go this route.
Does the Jeep IAC run off 12v dc?
Regards,
Bert
Hi Bert,
Bert
Old 04-28-2021, 02:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #139 (permalink)
Hi Bert,
Sorry I didn’t answer your question about the Jeep IAC, because I don’t know... if I read it correctly and hopefully Al or someone who is familiar with the MS ECU can verify that it gets hooked up directly to the ECU and uses whatever voltage comes out of the box.
Just like most of us, we have too much going on and not enough time, but I found a bit of time last week and this weekend to continue fab work on three custom mounts that I hope to get to the anodizer early this week.
Even used the old rub trick from grade school- hold paper against an object and then use the side of the pencil lead to get the impression of where edges and bolt holes are so I can drill properly.
Rutager West
Old 05-16-2021, 12:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #140 (permalink)
