I'm good with tools.
Down but not latched......bulb removed from frunk light.......what's the point of that? If I need light it's called a flashlight.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
I unplugged the light under the hood. I can always plug in if I need it (or if I start driving the car enough that it does not need a tender).
On my previous 911, I ran a wire from the tender through an existing hole (with grommet) that under the front valence near the fog light wiring.so that I didn't have to open/close the hood. I don't bother with my current cars and just leave the hood down/latched now.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
The Porsches and some other euro cars are in kind of a different situation for battery charging as in they have the battery located in enclosed spaces. My picture just illustrates the potentials that are there. I wonder what the actual occurrence is, 1 in 10,000-100,000 or 1,000,000? Do I trickle charge my truck or other vehicles with the hood closed? heck yes, it is all open under the engine compartment and the hoods are not sealed like the Pcars |
unplug light first day of ownership.
leave hood ajar when trickling end of potential problems. until i let the wife take the 964 to work. me glad the hood was partially latched - never did recover the smart tender ......... Last edited by creaturecat; 03-23-2021 at 09:21 AM.. |
I take the batteries out of all my cars put them on the bench to use the tenders.
I bought a CTEK 7002 battery tender. Basic question: Do you just connect to positive and negative terminals of the battery and not to a separate grounding location? Or connect to one terminal and a separate ground. The CTEK instruction video says one thing and the manual says another. And if it's a separate ground, what do folks suggest attaching the ground to? The cables that came with the unit are pretty short--not sure what they'll reach from the frunk.
—— 1987 911 Cabriolet 2008 Honda S2000 2008 VW R32 Last edited by dtsol; 03-25-2021 at 10:39 AM.. |
In my 911, the positive is on the battery terminal connector and the ground goes to the ground star that is also the negative lead from the battery. Seemed to make the most sense to me. On my bus both leads are connected to he battery terminals as that made the most sense there. Neither one has exploded nor burned down yet and I doubt any thing bad will happen.
https://www.ctek.com/uk/ctek-accessories I bought the extension cables and the indicator eyelet (hardwire to battery and displays state of charge). Might pickup the wall mount as well...
1978 SC Targa |
another satisfied CTEK 7002 user here too -- I connect the alligator clips directly to the battery's positive and negative terminals and then completely shut the trunk (wire's thin enough to comfortably compress under the hood seal and the hood seal's) generally leave the CTEK itself on the floor of my garage by the front bumper so I can monitor its status lights.
RETIRED
I connected the o rings to the terminals. Lead hangs out the trunk lid. Has a cap to protect the ground from corrosion. Pull into the garage and the Tender Junior gets hooked up. Easy Peasy. I have a minor parasitic draw and it can sit a few days. Always has 12.8+ for an easy start up.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
My car is charging up as we speak. Tomorrow's Friday, looking forward to going for a drive!
—— 1987 911 Cabriolet 2008 Honda S2000 2008 VW R32 |
Down and latched, but not closed. More important is a quality charger that will recognize and shut down when things are not going well and a properly vented or AGM battery.
1989 Carrera Former flings... 2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera |
Pavement Pounder
Location: Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
Latched tight to keep out Mickey and Minnie, but careful not to pinch cable.
'88 Carrera
'73 911 T Targa
I just close far enough to engage the safety latch. This way if I back out without disconnecting the charger, the quick connector comes apart rather than ripping out the cable. Don't ask how I know!
Plus one. 🐭
1984 Targa |
I just bought a Ctek from 4wheelonline because of the recommendation of my cousin. When using it, I leave the trunk open just a crack. No problems so far.
"Latched but not fully shut and no problems. At least, so far."
Same here!
Ole Skool - wouldn't have it any other way |
Enginerd
Battery tender cable
Same here, no issues.
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS IG: @pcar911fan |
