I am feeling more and more confidant that I am on the right track. Why does the cross bar need to be bent? Is it because the 993 case w/ 3.2 mount console pushes the center of the bar back more than a 3.2 case would?
Crossbar was bent so that the G-50 would fit without cutting the torsion tube.
Bill,
The 993 crossbrace was bent when I installed the 993 3.6 with a 915 into my 86’ coupe in 2004 as well. It’s just a different chassis thing as far as I understand. I am not sure of the dimension differences between the 3.2 and 3.6. But my intuition says the 3.6 could be a bit longer due to the size of the bore and it’s more modern chain ramp architecture etc… Dannobee, I have a thread showing that the torsion tube still needs to be cut up and pounded in to fit a SBH G-50 into a G body. And yes, the crossbrace still needs to be bent forward a bit for all that to work. I hope this clears up some questions. Regards, Steve
Formerly owned 70 911S, 73 911S. Wish I had pickled them! had a 75 930 #17. now in museum in Canada. 81 930 , 84 911 Cpe. 74 Carrera cpe. , 72 BMW 3.0 cs, 91 M3, memory foggy on some of the rest. Current toy car 86 911 cpe. |
Racer
Nope. The 3.2 and 3.6 engines are the same size.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
dimensionally there is no external difference between the 3.0, 3.2 and 3.6 cases, all the differences were internal. Just looking at the modified tin you can see how deep the tin tray is which is what i suspected being the issue for using the 1.25" spacers here's what I currently have, I guess the last question still is can I retain the 993RS pulley? or from another angle what are the specs of the 3.2 pulley or what ever pulley was used for the t/p, I doubt that a stock 3.2 pulley can be fitted w/o machining the crank snout. ![]() ![]() Here's a pic of one of the buggers causing the issue
Is that a Rennline crossbar? and Sheridan f/g?
Bill,
I am using the Sheridan “Tin” Order from Roger Sheridan directly to save a lot of money. Keep in mind he does these one at a time since he’s basically retired and living in Hawaii. But his turnaround is pretty quick. As far your pulley is concerned, I am not sure if it will fit. But I hope and think it will fit a 3.2 console. I was forced to replace my crank pulley as I was running the factory 993 3 belt with a single RS for the alternator in a 993 engine console etc… Now I am using a Rothsport single belt crank pulley to fit the 3.2 console. I hope that clears some things up. Regards, Steve
Crossbrace is from a Pelican on the forums here. Give me a moment to see if I can mine that out for you. He does a nice job. Fair price as well.
Search under: RSR Engine Cross Bars 304 Stainless
User name is : dg567 prompt shipping, good quality
Racer
I am using a Clewett serpentine belt setup with a 1973 fan setup.
now I hope that the single sheave pulley can be retained, it seems that it's only the longitudinal thickness that can be an issue. this seems to answer the pulley ? Quote:
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 04-30-2023 at 01:45 PM.. |
here's a non AC/964/003 engine mount console here a 3.0 console ![]() and bar ![]() and a 3.2 ![]() and bar
Racer
I have a 3.0 or earlier carrier and a special crossbar.
But, I have used to have a stock 3.6 carrier and crossbar that was reinforced that mounted in the same position as what you see in the photos.
clewett serpentine?
Racer
Yes, Clewett. Since it is a non-standard config (3.6 crank pulley with 2.4 fan setup), Richard had to customize the fan pulley. The belt is a tad longer than I'd like it...but it works great.
Great info here , great thread. !!!
Danny's products are very nice.
I've bought several TI pieces from him. I have one of his RSR cross braces now that I'm about to install on my 86. There is a change to the way it installs though that I still need to figure out. The motor mount bolts do not thread into the new cross brace mount like the factory design. The new brace requires a longer bolt and nut to install into the chassis. Not to hijack the thread but has anyone else ran into this issue and know what size nut and bolt is required? I was just going to take the original bolt up to the hardware store and look for something longer. We all know that any project requires 27 trips to hardware stores and auto part places that eat up so much time. |
3.2 console and 993RS pulley. Fits with plenty of room.
![]() 3.0 console and 993S pulley. Fits, but not enough room to change a fan belt. ![]() Mark |
Any pics of the installed engine and exhaust ?
