Thumbs up Valve Adjustment Decal for the masses
Update:
Original Message:
OK, somebody smart check this for accuracy;
I plan on printing this out and putting it on a thin magnetic background to fill one of the empty decal slots in the engine bay.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-13-2008, 11:10 PM
Oahu, Germany ?
Old 07-13-2008, 11:27 PM
SP2 SP2 is offline
SP2's Avatar
Looks nice, but it is a little wordy, isn't it?
The cam should be a little more to the left so the rocker hits the base circle.
I would delete the 2nd and 3rd lines. It just makes line 4 redundant.
I would replace the word "guage" with "shim".
I would replace line 6 ".004"" with 0.1mm, and delete line 7. Anyone that checks at the elephant foot uses the special tool, and it is 0.1mm, not 0.004inches.
Looks nice! Please show us a photo of the magnet. Thanks.
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 07-13-2008, 11:43 PM
Good comments,
I agree, its a little wordy...
I stole the diagram from somewhere else...I guess I could edit it
Looking through the previous valve adjustment post and the tech article most posters seem to refer to the "Shim" as a "Gauge" I was trying to use a technical reference to the actual tool used.
Additionally most post refer to the .004 as the most common tool, of course anyone can edit the picture to suit there own needs I haven't copyrighted it, and in fact I have stole everything on it from somewhere on this site.
The magnet is just paper thin magnetic material that has a sticky side to it to affix a decal, it can be trimmed to the same shape, my wife bought it from the stationary section at W-mart.
I think I put the 120 mark in the wrong spot.
I will refer to the initial post as a prototype and see where this post leads for the final edit.
Old 07-14-2008, 12:01 AM
Thrlls's Avatar
snbush67...nice post count!
Woody
Slow n Fast
1984 Guards Red 911 Carrera
Old 07-14-2008, 12:08 AM
6 more and I shed my Noob status.
Old 07-14-2008, 12:27 AM
Shed the Pelican number, sub a Pelican tele order number, and maybe we can get 'em as a refrigerator magnet/ free gift ::wink wink::
Old 07-14-2008, 12:49 AM
I like it, with other comments noted. Here's another....
..if you rotate in 240 degree increments....you stay on the "same-side" of the engine instead of having to jump back and forth across the engine. So...after you do #1, rotate 240 degrees, do #2..and so on.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 07-14-2008, 07:43 AM
3.2 CAB's Avatar
Porsche Crest Nice!
Originally Posted by snbush67 View Post
Good comments,
I am still LMAO!! This was just too funny...
With just a little tweaking, I think it will turn out pretty nice! Good work!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 07-14-2008, 08:25 AM
snbush67,
Nice job. I agree the 120 mark belongs on the other side, as it is the next stop.
I would suggest you indicate "rotate CW 120 deg. check/adjust #6"......
Great thinking.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-14-2008, 08:59 AM
Originally Posted by 2.7RACER View Post
snbush67,
Great thinking.
Thanks, I had CW in there but took it out I think you are right I will put it back on, even though it is obvious to some, it cant hurt.
I will make adjustments soon, I'm just waiting on a little more input.
Wil,
I agree that the 240 is easier but couldn't figure out a way to make this simple without having to explain why to rotate 240 vs 120, it just seemed logical to follow the firing order sequence. I guess I could make another optional "Advanced Valve Adjustment" decal with less wordiness and 240 rotations for the veterans, and we could call this wordy one above "Valve Adjustment's for Noobs"
Mahalo for the input,
Shane
Old 07-14-2008, 03:47 PM
Shane....
keep it simple...use the original 120 degree pattern....
We can always read up ( here ! ), how to go 240 if we want to....
Wil Ferch
Old 07-14-2008, 04:17 PM
After looking at it again, I think I will make the following changes;
The diagram point two (2) "Backside" will Change to point (1) as this is the first point one should check. then the adjustment screw (3) will change to a (2) as normally the adjustment would be the next probable step, and lastly (3) will be the gap at the valve.
I will add CW to each of the rotations
I will add a final line that says;
"240 deg. rotations allow for a 1,2,3,4,5,6 adjustment order". (is this correct?)
I will correct the 120 deg. mark on the Diagram and add a 240 deg. mark
I will probably also use the updated engine firing order sequence diagram if I can steal one from somewhere.
I really wanted to keep it simple, finding the balance between making an idiot proof reference for noobs (me) and a simple visual reference for the experts (not me) is what I am shooting for.
I'm just trying to get to 1000 post by providing something more then just 800 post containing two word comments.
Old 07-14-2008, 04:45 PM
Subscribed! Keep up the good work and thx.
87 blk coupe
Old 07-14-2008, 04:50 PM
SP2 SP2 is offline
SP2's Avatar
Can I have one when you are done?
I like your edits. Yes the 240 CW edit is correct, except delete "1". I.e. "2,3,4,5,6".
James
1981 911SC Wine Red
Old 07-14-2008, 04:55 PM
Once I am finished, I will post you should be able to print it out. I was not intending to put these into production but I like the idea above.
I will request to post this with the Pel Tel order on it. It shouldn't be a problem but I understand legality and liability.
Here is a blank one for edit if anyone wants to show of their skills, (yes I stole it).
Lets see what you can come up with.......anyone,... anyone.....Bueller....
Old 07-14-2008, 05:16 PM
Nice..but wasn't there an issue with the backside method and different cams?
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 07-14-2008, 05:17 PM
SP2 SP2 is offline
SP2's Avatar
FYI the method worked yesterday on my stock 81SC engine with 964 cams that were reground from original SC profile cams by John Dougherty. He said he took about 0.002 off the base circle to do the regrind.
I say it worked because I double checked with the standard method at the elephant's foot with a 0.1mm shim tool.
James
1981 911SC Wine Red
Old 07-14-2008, 05:23 PM
911 Dog's Avatar
Hey Shane,
I think its great! What program are you using to create the decal? Do you have it in different formats (.ai, .eps, .cdr) or some other vector based program? I would be willing to help out, if needed. I have large format printer with laminator that would make some sweet decals or magnets.
Looks great keep up the good work!
Dave
Old 07-14-2008, 06:31 PM
GrantG's Avatar
I love it - sign me up for one when they're available!
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 07-14-2008, 07:35 PM
