Senior Member
Very nice work!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Thanks - it's a slow go. I think everyone that gets involved in the projects realize that - but until you do...you have no idea what time commitment it is.
It's coming along. This board is full of some great projects.
Jeff |
Nice Job!!!!!
Fantastic Post! I love following these threads. I did this project a while ago but did not detail the car a good as you. ER certainly makes great stuff! I had the same problem with the rear brake rotor. Turned out the rotor was for a 993TT. No matter how much I indexed the rotor the wholes would not line up. Pelican sent me a 930 rear rotor and it went on no problem. Where is HMB, CA? Hermosa Beach? Where did you buy the Castrol Purple? Thanks Mark
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes 2006 M3 Competition Package 2007 997 GT3 - SOLD |
Thanks - Yeah pretty sure those are TT rear rotors - I just drilled and tapped and it went fine. (2 drill bits later) I like to have the rotor still when I am putting the wheel on other than cramming it all together and tightening it with the lugs - just feels better.
Got the Castrol in a jug from HD - more econmical that way.
Jeff |
AutoBahned
cost = $0.0005; time < 1 minute also, there will be a future owner someday - make them happy |
Thanks for the suggestion
Jeff |
I'd go without sealer. Six years my car is done and I'm not suffering from dust in the trunk. I've driven in the rain once or twice, when in a pinch. Great job on this project! Doug
1971 RSR - interpretation |
French Import
Very clean oil lines! What did you use to get them so clean?
I am about to embark on the same cleanup job and address a small leak near the cooler (most likely hose connection) and replace the front hoses. Did you drain the engine oil before taking the lines out? If not, how much oil is left in the lines and cooler so I can be ready with a drip pan? TIA!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
AutoBahned
Yes empty both the tank and the sump - even then the lines are still full and the cooler also - it is pretty messy.
Jeff |
Jeff |
Small update - had a buddy come over and used the second set of hands to good advantage getting the a-arms back in, t-bars and steering rack with spacers and got the ball joints in and torqued properly.
My a-arms don't have much droop, I guess once the struts get in they will force them down more. Where is a good place to start the indexing on the end caps? Some pics - ![]() ![]() ![]() ![]() Things should move a little quicker now. I need to do something with my hubs, they look pretty tired. Nothing wrong with the seals, bearings etc with only 33k on them so not sure the best way tp get them clean without getting media all over the internals.
Jeff Last edited by NoLift911; 03-11-2011 at 05:19 PM.. |
Max Sluiter
Rubber bushings do not let the A-arm droop. They are their own torsion bars in series with the metal ones.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Also didn't notice any difference in the t-bars in terms of splines - obviously left and right but I put the writing facing out on both - didn't see any difference on the bars from one end to the other.
Jeff |
Not debating here. Apparently what works for you doesn't work for everyone. If i were in the PNW, maybe I'd need to be more creative. That's not the case. Sorry for the distraction to this impressive build thread. Doug
Small update - got the struts in, t-bars, caps indexed, strut top plates, steering gear hooked back up, tie rods done, RUF sway bars in (23m front)...and what would an update be like without pics? So here are a couple...
![]() ![]() ![]() ![]() ![]() ![]() So couple of questions - I tried to get my caps on the bars as close to 4 and 8 as possible, there does not seems to be enough fine adjustment in the splines so they are as close as I could get. Got about 10mm on the adjuster bolts...I guess i will see when it touches the ground where that leaves me and plan for some final tweaking. On the strut top mounts what is a good reference point to start with for alignement - center the thing? No idea what position to tighten it down to. Going to need some type of strut bar - my preference is for one of the weld in types, simple, straightforward and light. Not sure about the triangulated ones...opinions welcome - thanks.
Jeff |
Hubs cleaned, mounted and ready to go....hope to have the car on the ground by this weeks end....
We'll see if my sons agree/cooperate/let me do that......![]() ![]() So what's left - seems like everything. Need to get the horns on wired up, rest of wiring for front lights, clubsport valance mounted, chin spoiler, remove the rest of the wiring for everything that I "removed" (anyone know where the brake pad wear sensor lines run from the back to the front?) Rear suspension, bars, plates, angle, SS lines all around, 23mm mc, shocks, sway bars, set ride height once on the ground....wow, this weekend might be tight - we'll see!!
Jeff |
Paradigm Short Shifter
Question about the "dum dum" stuff.
Is that the same stuff as that black window caulking stuff that comes wound in a cardboard box? It's about maybe 3/8" - 1/2" thick (or somewhere in that area)? Anyway, I'm planning on doing the full overhaul fairly soon, including replacing the upper strut mounts with a modified set that my friend has, with monoballs installed, and your chatter about the resealing of the upper mount. Thanks in advance. Michael |
Sorry - not real familiar with the dum dum stuff but in my mind that might not be the best solution, witht he alignement settings etc.
If I was going to do anything I would simply use some black/clear silicone to seal up any areas that look to be exposed to the elements. Personally it doesn't seem like a huge issue to me, but I won't be driving in the rain etc. I guess the other part that I don't understand is with all the old 911's running around out there that have had their alignments and suspensions tweeks, that black gunk simply breaks iff in chunks and leaves the areas open anyway - when I removed mine it was clearly not sealed up "well" and I had no issues with anything getting into the trunk. Hence the non issue for me.
Jeff |
Okay little more progress, didn't get as far as I had hoped and ran into a few snags as is always the case - in any event got the brakes on, every looks good, did a wheel test fit, no rubbing etc.
Couple of pics (still trying to figure out the brake line routing...) ![]() ![]() ![]()
Jeff |
