1987 carrera...
I am planning a long trip at the end of May, driving leisurely from Toronto Canada to Daufuskie Island South Carolina...(just adjacent to Hilton Head), approx 1200 miles each way. The trip will pass through historical Pensylvania, Virginia's skyline drive , North Carolina to its destination (4-5 days ) My car is well maintain and in good shape...but I would appreciate your suggestions as to what issues may arise and the parts that I should equip myself with...just in case. Things that you might have encountered in the past that should be noted. THANKS! |
Spare fuses
DME relay Window switch (how do I know) Belt required tools for belt change duk tape tie wraps oil (optional fix a flat) (spare fuel pump)
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
Flashlight
Passport US cel phone roaming plan
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
Having done a 3,200 mile round trip in a 86 Carrera a few months back, two essentials are a cup holder and a radar detector! BTW, the seat track mounted cup holder that our host sells is good. It's kind of in the way for ingress and egress, but it's just in the right spot for holding that large coffee for easy access to the driver (the passenger can hold on to their own damn drink, right?)
Retired, finally
Credit card with a large limit.
Roadside assistance plan with flatbed towing. There are some good independent Porsche shops in Charlotte and Charleston if you need them. Hopefully you won't, but the very 1st time I took my 84 out for a spin, I ended up calling GEICO for a flatbed.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project |
Spiderman
Porsche Shops
https://clubregistration.net/club_admin/files/Carolinas%20Region%20PCA/Approved%20Tech%20Inspection%20Facilities.pdf
Not sure you can access unless you have an account on club registration. A list of approved DE tech. inspection shops for a fair amount of the SE including up to VA an PA I think. If you get in real need a repair type trouble, these guys should know our cars better than most. I keep an up to date list in my car at all times as I drive alot. Be prepared. I assume there are lists like this all over the country.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
Troll Hunter
Having recently done a trip from NY to FLA, I can tell you the worst states are VA and GA for Troopers and speed traps.
I must've seen 10 cops in 50 miles in VA on 95. They're everywhere. Drive the speed limit or just be careful…your Ontario plates are a dead giveaway. Other states were fine…I did +10 MPH and I was fine.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
Second the comment on Virginia they are ruthless
i do a long trip every year - cleveland to hershey to baltimore to atlantic city to philly to nyc to cleveland in my 83. a good gps, good radar, AAA (or something similar), a cell phone and a credit card are all you need. maybe plan an extra day or 3 for each leg of the trip if something comes up, but other than a very thorough pre-trip inspection on the car not much more is needed.
-edit- oil.. forgot to say bring a few quarts of your favorite quality oil!
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. Last edited by nineball; 03-04-2014 at 09:10 AM.. |
I have driven from Tn to Fla on two occasions now in my 911 and mainly thru the state of Ga on I-75 but also with some miles on I-95/I-16(took a swing thru Savanah to eat at the Shell House on the way back) and the thing that I noted was the lack of full service gas stations. You will mainly be filling up at convenience stores so you will need to carry your own sources for oil and other consumables. You will probably pass a number of Walmarts so you may be able to restock if you are using mainstream products.
We do carry a small cooler with water bottles and some snacks and candies. One of the best (and worst) things about long trips in 911 is the range of a tank of fuel. I have to stop more frequently than the car does.
1987 911 Carrera (cassis red sunroof coupe) 2003 Toyota MR-2 Spyder 2006 Mazda Mazdaspeed 6 1992 Mazda Miata(sunburst yellow garage queen) 2001 Ford Excursion |
I travel N.Y to N.C. often but in other cars than my 79SC. Always full auto club services and cell phone of course, gps is so handy for gas stations and food. No radar in Virginia they are illegal and speeding with northern plates can be trouble.
Fuses Alternator Belt Flashlight Tool kit as supplied Pelican bookmarked as where ever you are some help/advice is available I have ready for my SC so I can now make a few long distance trips in addition to the above mentioned items: Spare CDI Coil Fuel Filter Rotor Dizzy Cap Relays Fuel Pump A coil of 12AWG wire Wire/Cable Ties Duct tape Multimeter External voltage regulator I make the trip in one 12-14 hour day with almost no luggage so space is not an issue. I had a few more items for 2 water cooled VWs I drove about a million miles between them and only got flatbeded home 3 times which were due to broken CVs and once for corroded grounds. Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires Last edited by BlueWing; 03-04-2014 at 09:40 AM.. |
2 cans of fix a flat....
Did a trip with one of my buddies in his 82 911 and the only thing we were happy to have brought was a can of tire fix stuff... Halfway through the rocky mountains we picked up a 4 inch nail in the rear. Nothing around for miles. Saved our ass.
Howiee 1983 euro sc |
wannabee wannabee
$5 tire plugs, air compressor, pliers
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
The '87 has one of those collapsible space saver spare tires. You will probably want to make sure that you have a working air compressor.
-Ethan |
86FlatSix
So I guess going back to NJ in 2 weeks will be a slow journey for me. PS - had a flat at Orlando so better have those fix a flat or something handy. Good thing it happened a few blocks away from those tire shops
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) Last edited by JQ911; 03-04-2014 at 02:16 PM.. |
Don't stress about it. My trip was over 5000 kms: http://forums.pelicanparts.com/new-zealand-australia/796074-my-hemingway-moment-tasmania.html
I had my moments but all I had was my iPhone and a credit card. Get out and do it. |
taking a long trip...
Thanks all for the valuable advice.
How many miles on your car? You may want to replace the reference and speed sensors.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
911 rookie
Lots of cold beer just in case you want to pull over and admire the scenery.
trip
1987 carrera 79,000 miles...
