Best Carpet Adhesive
Hello All,
I am fixing some carpet issues and I would like any input on the preferred carpet adhesive. Brand and specific type would be appreciated. I realize that the professionals would use a carpet adhesive pot - but this will be a home installation. Any guidance would be appreciated. Thanks All, Chris |
Other people will undoubtedly have another take, but I use 3M Super 77 spray adhesive. It is a high tack contact type adhesive.
be here now
3M is the best.
Rob.... '66 911, '74 911, '85.5 944, '69 914-6, '65 356C, '01 986, '04 955S, '97 993 C2S, '55 356 OUTLAW, '98 993 Cab, '55 356 Speedster, '06 955S, '58 356A, '96 993 C4S, '87 BD 911, '95 993, '06 997S, '11 997.2S, '74 914 2.7, '15 981S |
Dap Weldwood contact cement if you don't feel like dealing with over spray. I went this route because I felt like I could control the application of adhesive a little better with something you brush on rather than spray.
1982 911 Targa, 3.0L ROW with Webers |
+1 on the Dap Weldwood.
Jay B. 85' 911 - Black 69' 911 - Signal Orange |
The 3M spray is actually surprisingly easy to use and I didn't find overspray to be an issue at all.
cheers hg 1988 911 Cabrio |
be here now
I did not have any issues with overspray. I held a small piece of cardboard to "mask" any area that I had to protect, but even if there was a little that's what 3M adhesive remover is for!
It also depends where we are talking about. I recently did the entire carpet set in my '86, and used 3M Yellow spray adhesive for most of it, along with some Weldwood contact cement at the A pillars, tops of the door pocket pieces, etc. I don't think which adhesive you use is all that critical for most of it, just use one that dries reasonably quickly, and make sure to get good coverage so it doesn't pooch out in spots. Also, make sure to have very good ventilation, the fumes from the adhesives are pretty noxious.
The Lakewell install videos on Youtube are well worth watching for general carpet installation how-to.
John 1972 911T 3.0L Coupe 1986 Carrera Targa 1989 BMW M3 2007 328iT |
+1 on the fumes. I actually did mine over last winter doing a couple pieces at a time. Both the dap and 3m put off some pretty hardcore fumes.
Be very careful with 3M Super 77 spray adhesive.
As a graphic designer, we used this all the time. Lots of tiny dust sized particles of glue floating around, you breathe those in and they are in your lungs forever. Wear a Mask!!!! For carpet, use a brush and a quart of glue.
_______________________________________________ 45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop. |
Taking it apart is easy
I used 3M Super 77 with very good results. No issues 4 years later.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
No glue on the horizontal floor and tunnel pieces.
Did you get the memo?
Agreed, I did full carpet in my '88. Mask liberally with masking tape and masking paper before spraying.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
This sounds interesting. I am going to be working not the carpet in my project car......can you elaborate on why? not disputing it at all, just want to learn.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
French Import
Try a good quality dual sided tape. Easy to re-do if you didn't position everything correctly in the first place.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
It makes sense as they are more easily removed for future access to the tunnel and also for cleaning or replacement. I have done a couple full carpet installs plus repairs on client vehicles. The 77 is ok, a little more professional is the 3M 08088 General Trim Adhesive. Still a "convenience" can. Nozzle gives some control for the spread of adhesive. It's also a stronger bond than the 77. For areas like gluing down the rear seat cushions I use the 3M Yellow Super Trim Adhesive 08090. DAP contact cement on door pockets and other vinyl/leather trimmed areas. Esp. at edges where you want a strong bond right away. Can be purchased at your FLAPS or other supply stores. Around $20.00/can. 2 should more than do 'ya. Cooper |
I much prefer 3m super 77 to 3m general trim adhesive. I spray out of the car however. I found the bond to be stronger, and it only loses a few degrees of max heat resistance. Agreed on contact cement for the high tension areas. I preferred the super77 for foam and underlay, and 3m trim adhesive for carpets (less overspray allowing application in the car)
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 03-24-2016 at 03:13 PM.. |
Administrator
We used 3M Adhesive Spray for our 190SL carpet install project. We mostly used it for the thermal and sound deadening material, which it worked great. For the carpet we're actually going to use velcro so that we can remove the carpet when needed for cleaning or other reasons. But our 190 also didn't come with carpet and was stripped almost completely. Otherwise, the 3M would be a good choice, as already suggested above.
If you're going with the DAP/Weldwood (which I did in some areas), use the solvent based in the red can, rather than the water based in the green can. For what it's worth, I found that the gel-type was a lot neater to brush on for avoiding the snot-like drips when the brush leaves the can.
Uncertifiable!!!
I'm just finishing the interior of my build. After several adhesive and glue missteps I settled for 3M 08090 Super Trim Adhesive for EVERYTHING. Stays really sticky for a long time so you can take your time to adjust, reposition and tighten. I found 3M 08088 to be lousy stuff, aka no sticky, perticularly for stiff square weave carpet. Nozzle is quite direct and for tight spots around the headliner I sprayed adhesive into a small container and applied with small brush. 3M cleaner works well too.
![]() ![]() ![]() Hope this helps. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
