LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
Chain fence eating turbo
Originally Posted by NICE 69 S View Post
Quite a project. Just wondering why you didn't rotate the throttle bodies 180 and put the fuel bars in the middle. That would have given a straighter line into the intake port if the manifolds were cast with a slight offset to the valve cover sides.
Bob B
I've never seen that done that way?
Old 10-26-2016, 12:10 PM
Brando
quattrorunner's Avatar
wow
Turbo powa!
1977 911s. it's cool
Old 10-26-2016, 12:56 PM
Originally Posted by Tippy View Post
Whoa! Nice project! I too went down this path but stopped for various reasons.
I also had that exact Triumph. Bike was a turd, so you're finally using the ITB's for a good purpose! HAHA
One caution, I'd ditch that AEM dizzy adapter, it is not accurate enough in my opinion for what you're doing.
If it were fuel only, I'd say it'd be ok, but if full ignition control, I'd be hesitant using that.
Think gear lash and what that equates to in degrees!!!
Go with a crank trigger from GoingSuperFast.
Thanks man, interesting on the EPM. Any more info on the issues? From what i've seen it's supposed to be more accurate than a trigger wheel setup, plus it provides a cam position signal.
Originally Posted by Ferrino View Post
Amazing work - thanks for sharing! Having your manifold design cast is baller! I think I will go with that Bussmann unit for my Microsquirt project - the tutorial you linked to looks excellent.
Can you elaborate on why you switched from cable to a solid linkage, please?
Thanks! Honestly, the reason I went to the solid linkage is because i think it looks cool. I'm sure the cable setup would have worked fine.
Quite a project. Just wondering why you didn't rotate the throttle bodies 180 and put the fuel bars in the middle. That would have given a straighter line into the intake port if the manifolds were cast with a slight offset to the valve cover sides. Bob B
The way it is now is a good balance of the injector path and airflow into the intake port.
As noted above, when i first set these up I was going to use cable linkage. The way the linkage hooks up to the ITB's is on the fuel rail side. This would have allowed the bellcrank in the middle of the engine, with the cables running under the ITB's to hook up to the ITB linkage. It could have worked the other way around, but it would have been tight. This configuration gave me a little more room with the cables to sweep around.
Also for my fuel setup I was mimicking the fuel setup from a 3.2 with the fuel rails on the outside.
Old 11-02-2016, 04:48 PM
Wiring has continued
All new connectors and terminals were used for every plug.
Insulators on the coil pack wires
Wires stripped
Terminals crimped
Braided wire wrap on
Plug on, heat shrink shrunk
And repeat
Old 11-11-2016, 03:29 PM
Beautiful wiring job! When I redo mine, I'm going to crimp rather solder, so 0 splices.
Old 11-11-2016, 03:43 PM
911SC Tinkerer
merlinfe's Avatar
Clay,
Where did you get the rod for the bell crank on the manifold? Also, what bushing did you use on the passenger side to mount the armature linkage?
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 11-12-2016, 05:06 PM
911T '72
DeRRis's Avatar
Hello Clay,
Is there any chance I could buy a pair of your intake manifolds?
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 11-13-2016, 08:26 AM
Originally Posted by merlinfe View Post
Clay,
-Steve
I had a few of the pivot rods made for the manifolds. The bushing are part of Al's linkage kit.
Old 11-13-2016, 11:02 AM
CBRacerX's Avatar
Very nice work. Tempted to follow in your footsteps, which means I have the same question as DeRRis.
Chris
https://dergarage.com
‘07 GT3, '80 SC Weissach (For SALE), '01 986S, '11 958S, '18 Stelvio, '18 Dursoduro 900
Old 11-13-2016, 05:10 PM
Eng-o-neer
Tremelune's Avatar
Mesmerizing.
Old 11-14-2016, 02:55 PM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
I'd also like to know what I can do to acquire a set of your manifolds Clay.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 11-15-2016, 08:49 AM
911T '72
DeRRis's Avatar
I ordered them from Clay through his website
CCM Triumph ITB Manifolds - Closed Course Motorsport
Dennis
Old 11-15-2016, 08:53 AM
Dennis - I appreciate the plug, but let's try to keep this thread about the build!
While the wiring was moving, I also worked on the fuel.
The car was setup previously with Weber's and had a low pressure fuel pump installed.
I used an AEM unit to replace it.
Old 11-15-2016, 02:21 PM
So more wiring. I missed this pre-install pic of the main harness
Laying out the wire runs to all of the sensors
And installed a -6AN fuel line between the two rails
Vacuum lines from each TB to a vacuum manifold
Old 11-24-2016, 07:27 AM
The injectors are 30lb units supplied by Rasant Products
The coil packs are Audi 2.0T units, these are a little long but do the job for now. There is a short variant that i'll be switching to shortly.
For oil pressure, I used a universal 0-100psi 0-5v sensor with an adapter at the high pressure port location
This is the fitting - M10x1.0 M10 1.0 1/8 NPT Oil Fitting Pressure Tee T Adapter
For oil temp, I used an AEM 1/8 NPT temp sender with a Auto Meter 2267 Oil/Temperature Metric Adapter in the cam cover
For IAT, I used an AEM 1/8 NPT unit that I drilled and tapped into one of the ITBs
As noted previously, I used an universal vacuum manifold to collect all the vacuum lines off the ITBs. This serves the GM 1 bar map sensor and vacuum reference for the fuel pressure regulator
I also added a spring to the bellcrank linkage to help the throttle return
Old 11-24-2016, 12:35 PM
Ferrino's Avatar
Wonderful stuff - I especially like your photography. Regarding the Audi COPs - I picked up a used one just to see how it would sit against the holes in the valve covers and mine was just loose in there - really didn't like that. I guess you could put some sort of spacer ring in there. Do the shorter ones actually rest against the covers?
Old 11-24-2016, 02:10 PM
Beautiful install!! I'm in your town as we speak.
Old 11-24-2016, 02:17 PM
Mick_D's Avatar
That's pretty sweet, CLay. One day I'll want to do something very similar. Those Triumph ITBS look great!
Old 11-24-2016, 02:18 PM
Wer bremst verliert
JohnJL's Avatar
Kudos, nice adventurism, creativity, documentation and bravery. Keep it coming.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 11-24-2016, 02:30 PM
What crimper are you using? Are they double-crimp?
Old 11-24-2016, 02:36 PM
