Eldorado's Avatar
colour of the wire for the stock 944 shift light
hey, does anyone know the colour of the wire to the stock 944 shift light in the tach?
my car had one at one point, and when I pulled the cluster last year, a bulb socket different from the rest fell on the ground and I found a wire (if memory serves it was a black wire with green stripe).... I'm wondering if this is the shift light...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 07-16-2007, 07:34 PM
Send a message via AIM to Icey1174
Could it be called the "Illumination Potentiometer" in the electrical diagrams? I find it in the back of the Haynes Manual. I do not see a "Shift Light" or "Shift" anything anywhere. This thing is connected to the speedo. It says "Grey/Blue" and "Gr" for the wire colors if that helps you any.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 07-16-2007, 07:57 PM
Eldorado's Avatar
hmm.. illumination potentiometer...
you know, i have no idea...
Kyle
Old 07-16-2007, 08:44 PM
pdx944's Avatar
Google is your friend
"The present popular usage of the term potentiometer (or 'pot' for short) describes an electrical device which has a user-adjustable resistance. Usually, this is a three-terminal resistor with a sliding contact in the center (the wiper). If all three terminals are used, it can act as a variable voltage divider. If only two terminals are used (one side and the wiper), it acts as a variable resistor. Its shortcoming is that of corrosion or wearing of the sliding contact, especially if it is kept in one position."
Old 07-16-2007, 08:51 PM
Eldorado's Avatar
I know what a potentiometer is... lol :P
I just dont know if that's what they call the shift light..
Kyle
Old 07-16-2007, 08:53 PM
pdx944's Avatar
I doubt it. I am guessing it is the cabin dimmer.
Old 07-16-2007, 09:22 PM
Eldorado's Avatar
oh that makes sense...
Kyle
Old 07-16-2007, 09:54 PM
Well thanks for the info! I still do not see a "shifter light" in the diagram.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 07-17-2007, 06:13 AM
Let's go shooting.
Dark Skies's Avatar
My dash is currently out - I'll see if I can see a black wire with a green stripe and where it plugs into - I labeled everything. Won't be until tomorrow though - it's coming up to one in the morning in the UK.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 07-17-2007, 04:41 PM
pdx944's Avatar
Wow sorry guys, i just reread my posts and i came off as a real *******, sorry 'bout that.
Old 07-17-2007, 07:52 PM
Eldorado's Avatar
no worries - didn't think twice about it..
Kyle
Old 07-17-2007, 08:00 PM
cold starter
JustinL's Avatar
I think Porsche called it CASIS Computer Aided Shift Indicating System if I recall correctly.
Does anyone know how the DME decides when to illuminate the light? How does it know when to shut the light off when you push the accelerator down without a throttle position sensor? Is it a rate of change in the AFM threshold?
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 07-18-2007, 08:36 AM
Send a message via AIM to olerebel
Wow, I didn't even know there was a shift light... does it come in all 944s? If so I guess mine doesn't work
1989 944 n/a
Old 07-18-2007, 10:44 AM
Eldorado's Avatar
a lot of previous owners cut the bulbs out because it gets annoying (apparently).
I'm 90% sure that all 944's have it...
Kyle
Old 07-18-2007, 04:48 PM
It's a liitle orange light on the top part of your tach. It comes on to tell you when to shift to help you save gas.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 07-18-2007, 04:52 PM
Let's go shooting.
Dark Skies's Avatar
I've looked on mine with the dash out and the only bulbs present are for illuminating the clocks when the main lights are on. No black wire with green tracer I'm afraid.
Old 07-18-2007, 05:01 PM
Now that I think about it... I doubt there is a wire. It should be a part of the circut on that green ribbon backing with a blub holder that you put the bulb in and twist into the socket. That's how all the rest of the blubs are back there. Does that make sense???
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 07-18-2007, 05:04 PM
Eldorado's Avatar
our bulbs dont twist in, the early cars are different than your 87, John...
Kyle
Old 07-18-2007, 05:19 PM
SORRY! I thought you were trying to trick me!
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 07-18-2007, 05:20 PM
Politically Incorrect
onZedge's Avatar
The upshift indicator circuitry is inside the tach, so no separate bulb and socket. FSM says replace the tach if the bulb burns out! Is it possible that the extra socket/wire is for the "time to change the O2 sensor" warning light located between the tach and speedo? I'm not exactly what year/model had this "feature".
Edek
'87 924S
'91 535i
Old 07-18-2007, 05:56 PM
