944 shift knobs?
Quick and easy question: Where can I find an aftermarket shift knob that will fit my 944? I'm growing less and less fond of my stocker and it's mal-fitting 5-speed plaque every day, and I can't seem to find any of the clip-fastened ones like Porsche uses.
1985 Porsche 944 - '85/1 N/A, currently for sale. 1971 Datsun 240Z - Street / AutoX car. 2005 MINI Cooper S - Insane daily driver |
This is not really the answer you're after, just unsolicited info...
It's hard to improve upon the functional design of the factory Porsche shift knob/handle. As you will quickly realize if/when you use an aftermarket shift knob, the OE unit very effectively isolates very harsh vibrations and noise. I tried aftermarket shift knobs (MOMO) but eventually went back to the OE shifter w/a short shift kit. YMMV
bertman 84 944 Original Owner 65 Plymouth Satellite 08 Mercedes-Benz E 350 Sport |
There are aftermarket ones with the rubber isolators (at least I think that's how they're set up)
go here: http://www.9xauto.com/944.html Look under interior > custom shifters. There are lots of aftermarket ones available...need an adapter though, and they will vibrate and make noise if you don't take extensive measures to prevent it.
"I Am The Stig!" MistahSinclair 1986 N/A Daily Driving Project! |
unindicted co-conspirator
I put a Momo knob on, it looks great, but yes, it does transmit more vibration, but not enough to be a problem
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
In over my head
You can also try Jager Engineering / Garage 9. I have been very happy with the quality of their products to date.
http://jageng.com/garage9/index.php?cPath=49_76&osCsid=d2e07f06ea9346cb17b87eb8d5647403
Fergus 86 951 Graphite Metallic 86 944 n/a Garnett Red Metallic (SOLD!) 74.5 Triumph TR6 (restoration project) 05 Subaru Legacy (winter car) |
Hmm, any more vibration coming through and I think my hand might explode whenever I touch the shifter... I'll keep that in mind.
Still, 2 seconds of harsh vibration every now and then vs permanent visual improvement, I dunno. *Edit* - good links guys, thanks much. I might actually just be able to get a better 5-speed plaque for the top off of 9x auto, saving me oodles of monnies, LoL.
1985 Porsche 944 - '85/1 N/A, currently for sale. 1971 Datsun 240Z - Street / AutoX car. 2005 MINI Cooper S - Insane daily driver Last edited by Z06C5R; 04-22-2008 at 08:54 PM.. |
add speedforceracing.com to the list
Keith 1986 Porsche 951 |
Quality
Where are you getting the 2 seconds of harsh vibration from? [I only ask because I get a harsh vibration right at 4100 rpms or so... I'm thinking balance shaft or some how motor mounts (hitting a frequency?)] thx p3
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
I think the harsh vibration is referring to the shifter itself.
On the stock shifter, if the rubber bushings inside are gone or damage it will vibrate a LOT at certain RPMS. The non-stock shifter I have vibrates a little, in a similar way, at around 2000rpm when the engine is pulling hard.
Nope, I still have perfectly intact bushings inside the shifter.
I get a high-frequency buzz-vibration at about 3400-3600 rpm, which I have a suspicion might be balance shafts or clutch (though both were serviced by a Porsche mechanic recently...) as suggested in other topics I've read on the subject. At any rate, it's quite different to the low-frequency shaking I get at 1000rpm from what I know to be bad motor mounts.
