85.5 944
Chucked's Avatar
Finally took the 85.5 in for a new clutch. 140,000 miles on the original rubber center disk ain't bad at all. It will also get the only944 short shifter. Now I have to be patient until the MORPCA DE at Mid Ohio end of April.
Old 03-10-2014, 04:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2141 (permalink)
1990 944S2
Send a message via Skype™ to ChrisRL
Dog leg arrived and put it on the handle, then put the handle links in the door. All good, even remembered the new seals - but the Tumbler's now jammed and the key won't turn at all.
Thought they'd supplied the wrong side dog leg for a second, but cross checked the part number with the PET and no, it's the correct part.
Thing is, the dog leg was broken off when I lifted it out of the door so I have no reference as to how the lock parts need to interact...
84 944 gold sold
90 944S2 black current DD
89 735il white fixing
89 GL1500 white restoring, 01 955i S3 black current DD
01 955i Sprint brg customizing, 89 955i Daytona gold restoring
Old 03-10-2014, 09:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2142 (permalink)
1990 944S2
Thing is, the dog leg was already corroded and broken off when I lifted it out of the door so I have no reference as to how the lock parts need to interact...
84 944 gold sold
Old 03-10-2014, 09:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2143 (permalink)
Originally Posted by ChrisRL View Post
4) got started on H4 conversion. Had a pair left over from a previous 944 but Clark's and others say to start the car, put the headlights up and then pull fuse 3 (headlight motor fuse) and I don't really want to start the car while it's still up on stands, so the headlights are sitting until next time;
There is a dial on top of the head light motor that you can use to manually raise the lights.
Remove the rubber cover on the motor and it should be right there.
You still have to pull the fuse as well.
Cheers.
Old 03-11-2014, 07:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2144 (permalink)
1990 944S2
Nufy, thanks.
BTW do you know what happens if you just use the emergency headlight manual crank *without* removing the motor fuse first? LOL!!!
84 944 gold sold
Old 03-12-2014, 08:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2145 (permalink)
In my case it partially opened then cycled through a full open/close sequence...
Ended up back where I started...lights down...
Old 03-12-2014, 01:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2146 (permalink)
1990 944S2
Fixed the door lock finally (see separate thread) and now moving in on the headlights.
Having someone over to check the oxidized black paint too..
Question: The lock rod knob (part 33 on the PET 804-05 - mine holds the red LED from the alarm system, and when I pulled it up to unlock, the entire knob came off the locking lever stem. I guess this is just superglued at the bottom, away from the cables? It's totally loose right now.
Thanks!
Chris
84 944 gold sold
Old 03-12-2014, 08:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2147 (permalink)
Back from Beyond
New rear shocks. Old ones were really, really dead. PS one was providing no damping at all, as most of the fluid leaked out, and the DS one had seized.
And, well, since I was down there... I resealed the tranny and changed the fluid too. Guess what? Nothing stripped! Not the CV bolts, not the tranny plugs. Secret - you can get an impact gun on the fill plug.
So now I'm feeling virtuous...
Oil change tomorrow.
Old 03-14-2014, 04:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2148 (permalink)
Tightened my cv axle bolts... For some reason the passenger bolts always come loose... Oh and found a neighbor with a pristine 84 944 that he wants me to work on to get it driving again. Needs some engine work
Old 03-14-2014, 07:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2149 (permalink)
Andrew Gawers' Dad
CHICKS's Avatar
You're just in luck. Ideola is haveing a 10% off sale on stage 8 locking CV bolts.
Old 03-14-2014, 08:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2150 (permalink)
Quote
Hmm but I only need one side lol
Old 03-15-2014, 10:11 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2151 (permalink)
Back from Beyond
Oil change took 2hours. With son. Went like this:
Son, here's how to position the drain pan and remove the drain plug.
Dad, that looks like it's gonna take a while to drain. We better play foosball while it does.
Son, good idea.
Half hour later:
Son, here's how to put a new filter in and here's how to fill the crankcase with fresh oil.
Dad, that funnel looks like it's gonna take a while to drain. We better play foosball while we wait.
Tomorrow we do Mand's Jeep. That could take 4 hours... Doing it our way...
Old 03-15-2014, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2152 (permalink)
1990 944S2
Washed the car, taking all that NM and transit dust off, and started attacking the heavily oxidized hood. It worked okay, and if I knew how to post photos here I'd do it, since there's not a lot available online about hoods as oxidized as mine is.
It was kinda sorta a test cleaning because I figured if this wasn't going to work then I'd do a vinyl on the hood for the interim. More pressing systems need the attention for the time being.
Working on the pax headlight as well, but at least the car's cleaner overall now...
84 944 gold sold
Old 03-15-2014, 06:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2153 (permalink)
AFM #725
Gawernator's Avatar
I haven't seen my 944 in months, separation anxiety!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 03-16-2014, 11:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2154 (permalink)
Mike_944's Avatar
Well I decided to buy this the other day. I guess I have a thing for unreliable german cars. :P
I'm selling my daily 944 later this week and keeping my 944S as a project car.
2002 E46 BMW ///M3 (Daily)
1987 Porsche 944S (Project)
1985.5 Porsche 944 (Sold)
Old 03-20-2014, 02:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2155 (permalink)
1990 944S2
Pax headlight turned out to be the usual dreaded broken ground wire. Soldered it back together and re-wrapped everything and it turned out just fine.
Will go with pureview's H4 harness very soon - excellent product, BTW, but really really wanted to get this one solved before I moved on.
The new harness will bypass the pax side lighting loom anyway, and would have been the ideal workaround had I not traced the fault to its source - but... :-)
Another squawk bites the dust!
84 944 gold sold
Old 03-20-2014, 08:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2156 (permalink)
PetrosS2's Avatar
Old 03-22-2014, 02:26 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2157 (permalink)
AFM #725
Gawernator's Avatar
I think my Porsche is lonely
Old 03-26-2014, 09:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2158 (permalink)
curtisr
curtisr's Avatar
Son, good idea.
Half hour later:
__________________________________________________ _____________
= Priceless
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 03-27-2014, 04:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2159 (permalink)
Chunkerz's Avatar
Today I rotated the engine a few times to prevent the rings from sticking to the cylinder walls since my car will be stationary for a while.
I also got my flywheel off so I can get it resurfaced.
A month or two ago I did these things:
I removed the front brakes, control arms, and sway bar so I can replace the ball joints, all the rubber bits, put on new tire rod ends, new struts/springs, and paint the control arms/dust shields.
These shocks definitely need to be replaced...
My old engine support bar that I thought I'd never use again came in handy when I needed something to support the engine so I can remove the crossmember to clean it and replace the engine mounts.
Draining the power steering fluid so I could remove the rack while attached to the crossmember didn't go as planned, so I had to abort and support the crossmember with a jack stand.
A few more fun pictures of my current situation:
These axles are shot.
Parts scattered everywhere under my car. I'll never get this thing back together....
Old 03-27-2014, 03:53 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2160 (permalink)
