Straight shooter
You mean to say you don't want to add the hump to the hood too?
![]() The shorter 4 cyls do sit further back so there is more room due to less slope of the hood. You might get away with it. The water neck on the bell housing side is also present on the vw/Audi 1.8t. There is space beneath the OEM outlet on the Audi head where you could relocate it with some machine work to create more space and blocking off the OEM port. Similar to the Mitsubishi, you would possibly need to whittle a solution out of a block of aluminum. Found this from a 924 swap in the UK: ![]() ![]() This is the vw/Audi 1.8T...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Banned
what is with folks on these boards .... seriously ... delusionally nuts. so brand obsessed they can't see past that crest of Stuttgart up there ... |
-Brad 2002 Carrera2 1986 944 Turbo |
Straight shooter
Lemons 944 build (Team Got Wood)+ testing videos :: motorgeek.com ![]() Looks like they tried to race and then just tossed the Porsche engine out after two identical catastrophic failures. Racing heritage doesn't mean jack to people who actually want to drive their cars hard and have fun.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values Last edited by Lapkritis; 04-02-2014 at 09:34 AM.. |
I could put a fridge in there. Mount a giant Roots blower in front of that engine and make the 1.8 feel like an 8.1... Last edited by v2rocket_aka944; 04-01-2014 at 10:06 AM.. |
I would love to build a high compression 3.0L na with standalone, direct ignition, dry sump and ITB's. It would cost a lot and probably be unreliable and need constant tweaking, but that's what motivates me. I think it's good that we are a diversified bunch, it doesn't mean one person is stupid doing it one way when they can do it another way cheaper, better and faster, it just means that that is the way he or she wants to do it.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
Straight shooter
Lol, nope, not putting words in your mouth, actually agreeing with you
Parrothead member
If we ever happen to meet up, I owe you a few beers. One of the best posts Ive ever seen on here.
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
There are a few guys on Rennlist who have built some offset crank i4 Porsche motors very cheaply which are circa U.S. 450-500whp. I believe they make a strong argument for those of us that actually want to drive our cars with Porsche motors in them. Nobody is wearing Rose coloured glasses here. We don't think the i4 P motor is the be all and end all. Some of us just prefer to stick with the brand and improve upon it. If there are others that don't give a damn about this, then they have options. The V8 is clearly the most popular and running a lazy n/a V8 does make sense in terms of service costs and general reliability, however so do our motors if they're taken care of. My car is currently representing the model and marque quite well and lapping at about Cup Car speeds. I take a great joy by achieving this and keeping with the original layout. Don't blame people for going with the swap though, just doesn't 'sound' right to me. Purely subjective of course.
Patrick Youtube 333pg333 86 modified 951 Last edited by 333pg333; 04-01-2014 at 07:51 PM.. |
Is it possible to put another Porsche engine in these like a 2000's model cayman or boxster engine just to keep it Porsche and make it newer or up to date.
White and Nerdy
I'd like to chime in and say thanks to those who weighed in on the Rover V8. Years ago I'd seen some pics of some rather expensively done up 944's in the UK with the swap, so it was what immediately came to mind. Seems to only be a viable alternative to a 'Vette engine if you're willing or want do have a "built" engine instead of simply trying to get it to fit.
If performance is your goal, it really is hard to beat the lightweight modern 'Vette powerplants. I may be taking apart/rebuilding/upgrading the engine in my '84 944 mostly for the experience acquired along the way. Going into it - I do not see it as a sensible thing to do, but frankly, if we were all sensible, we'd live and work in the same place, and not drive at all. As for the post made above mine, you'd want to be good with a cutter/welder. ![]() Yes, it could be done, probably best to cut the rear out of the car and put in a subframe, locating the engine in the back half of the car. I doubt the width of a horizontally opposed engine would fit in the space of a midly slanted inline 4. You could of course, go super wide body with spreading out your strut towers with totally new fab work. Not impossible, but perhaps not practical. ![]() The 944 kinda is what it is if you want to stick to Porsche powerplants. The 951 will be a lot faster for similar cost.
Shadilay. Last edited by Tervuren; 04-01-2014 at 09:32 PM.. |
Straight shooter
Rover V8 swap (another 924 in the UK):
http://www.volkszone.com/VZi/showthread.php?t=568605 ![]() ![]() ![]() ![]() Looks like the intake manifold is a bit too tall...
i messed around with a couple of buick and oldsmobile 3.5s (from which the rover was derived). interesting engine. not good at high rpms though. too flexible. a girdle is needed. the olds was better than the buick, due to the head design. they had a few different compression ratios too, so you could mess around a bit there. very lightweight engine, at 302#. not a huge amount of torque, but not bad in a lightweight car. the rover engine has a better rear main seal than either of the predecessors, and is a stronger alloy. all of the engines are a bit tall though.
1995 993 C2 |
Straight shooter
Patrick Youtube 333pg333 86 modified 951 |
Engineer of profanity
All the while people keep saying that the 911 platform is "outdated", and "old technology". I guess it's not outdated enough that a rear engined car can't beat a Corvette on a race track. The question is what is it with people who can't read statistics and realize that GM hasn't done much of anything in endurance racing? In fact, Corvettes didn't do ANYTHING until they stole the transaxle platform from the Porsche 924/944/968/928 series. They were the worst handling sports cars made until then. Also, show me a Corvette that will make 1000hp and I'll show you Porsche 911's that will make 1200-1400 with two less cylinders. Not to mention Porsche had a 240mph race car in 1970. There is no comparison. Also this is a Porsche forum. So if you don't know the history of Porsche, or say Ruf. Maybe you shouldn't be spitting nonsense here. The Audi 5 cylinder swap looks cool. The 944 body was built at Audi Neckarsulm anyway. lol They used to put Rover V8's in Triumph TR7's. So Triumph responded with the TR8 which was a TR7 with a production Rover V8.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black Last edited by 924CarreraGTP; 04-02-2014 at 03:21 PM.. |
I'm just a young whipper-snapper, but spent more time as a child at PCA events than at little league. While I appreciate Porsche history and technology, no company, person, engineer, or engineering team is infallible. Furthermore, no one beats father time. As the days go by, our vehicles become more and more outdated. From a historical standpoint that's fine. And I wouldn't advocate someone putting a LS swap into a 944 cup (or for that matter a Silver Rose). However, on a dime-a-dozen early 944 or non-special 944 turbo (like mine), I don't see the tragedy. |
That Guy
Regarding those Audi swaps, the quality of the builds done in Sweden and Finland always impresses me.
Looks like the black one lost the vacuum booster. I would guess from the lack of master cylinder in the engine bay they went with a pedal box inside the cabin. Would be interesting to see more pictures if anyone can find them.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
