camo's Avatar
Says he has over 10 left but will only let me buy 3.. says it's only for customers who have bought less than 3 items from him over the past 10 days.. -.-
"Weissach" 1982 Porsche 928 auto
Old 03-13-2013, 02:52 PM
MPDano's Avatar
That seller is a moron then. Move on to the next seller at a buck more.
Bosch 0437502047 Fuel Injector | eBay
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-13-2013, 03:11 PM
camo's Avatar
Yeah must not wanna sell em too bad..
That one says the same thing..
I'm going to wait until tomorrow to order them when I'm in a better mood and not rushed to get to class.. ^.-
Old 03-13-2013, 03:20 PM
928: Serial Enabler
82 Wiessach.
And you are going to buy CIS injectors?
Am having a glass of wine, but only one.... Guys, isn't the 82 an LJetronic car?
Can we revisit this before you plunk down the pecuniary?
I mean, I've got a set of LJet injectors from an 82 if you have to have replacements.
Am not yet convinced of that.
The richness situation is more likely due to needing a new oxygen sensor. When bad, the Ljet cars suck gas.
Have the engine grounds on the passenger cam cover been adjusted on this car?
Old 03-13-2013, 04:47 PM
My '81 is L jet so I'd guess Chris is correct!
Old 03-13-2013, 05:36 PM
MPDano's Avatar
Uh oh, camo! Are your injectors the same as I pictured or do they have an electrical connector on them?
Old 03-13-2013, 05:54 PM
MPDano's Avatar
So, I got my injectors out and I've decided to just replace them with the Mercedes injectors. What kind exactly and where do I get them? Link please?
Also, I need the injector connectors and I cannot find them anywhere.. Any ideas?
Your Injectors are out. Please post a pic of one.
Old 03-13-2013, 05:56 PM
camo's Avatar
I'm not home now, I didn't really look at the injectors, but I do know that there are electrical connectors the injectors came off of that need replaced on the car. If my math is correct, yes they do have electrical connections.
Old 03-13-2013, 06:02 PM
camo's Avatar
I do believe it looked like this one, kind sir.
1982 porsche 928 injector - Google Search
Can't upload picture from phone right now.. Sorry
Old 03-13-2013, 06:08 PM
MPDano's Avatar
Dude? When you said you we're going to replace them with MB's, then I assume you meant the CIS since there are no MB electronic injectors for our cars. Send your L-Jet injectors to Witchhunter. Good catch Landseer!
Old 03-13-2013, 06:15 PM
camo's Avatar
Sorry MPDano, I didn't know what CIS and L-jet was until today.. -.- I was going by what my neighbor said.. Anyway, thanks Landseer, saved me a couple hundred bucks!
Thank you too MPDano!
Old 03-13-2013, 06:19 PM
camo's Avatar
If they're the original injectors, they have 126,XXX miles on em. Should I just replace em? Or clean em? Nothing wrong with em as far as I know... Besides getting 10 mpg..
Old 03-13-2013, 07:12 PM
928: Serial Enabler
For now just use them.
If clogged, the car will run lean.
In my experience, that means it will run hot, high on the gauge.
Needs a new oxygen sensor.
Probably needs to have injectors removed for a different reason: new fuel hoses and injector-to-manifold O-rings.
Old 03-13-2013, 07:59 PM
1979 5sp 928 project
Agreed, good catch Landseer. Would have made for a very difficult install with very little hope of success.
1979 928 5sp project
1984 928S 5sp black on black
Old 03-13-2013, 10:26 PM
camo's Avatar
And there's only 1 oxygen sensor per car right?
Old 03-14-2013, 12:41 AM
928: Serial Enabler
Yes, I think the 82 uses a single wire sensor, bosch.
You can use newer ones with three wires, leaving the 2 heater wires disconnected I think.
Research Lambda sensors for more answers.
Old 03-14-2013, 04:40 PM
MPDano's Avatar
I would actually just get the proper one since the connector will already be there. Pretty much plug n play. I got mine from 928 Intl.
Oxygen Sensor 80-82
Item Number : 911 606 123 00
Unit Price: $89.00
Or use that part number here at Pelican to price compare.
Old 03-14-2013, 04:51 PM
camo's Avatar
Ok, thanks Landseer and MPDano.
Old 03-15-2013, 04:04 PM
camo's Avatar
So... A Few of my injectors seem to have small cracks.. Is this serious? I guess I'll find out when I have em cleaned..
Might be hard to see, its at the Top in the brown.
Will that effect functionality?
On the bright side.. My room smells like fuel..
Old 03-15-2013, 04:06 PM
camo's Avatar
This one might be a little easier to see..
Old 03-15-2013, 04:18 PM
