Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
I Want That Bov Sound
i was wondering which blow off valve i should use to get the phhhsssstttt sound when shifting gears and such. and will this require a new waste gate as well as a new BOV? so what should i get?
Old 06-04-2007, 05:06 AM
Engine swap pro
myskyon's Avatar
evo motorsports bypass valve that will make the sound but you would neet to have a MAF setup to hear it. and with the MAF setup the stock one will make the sound too. also you will not need a new wastegate. there are some bypass valves that vent to atmosphere. but i have read very little about people using them on our cars.
87 951 ---- "R2" - under the knife
87 951 ---- "R1" Parting out - Gave to a good friend
88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out
06 WRX ---- The "RUE"
Old 06-04-2007, 01:58 PM
cold starter
JustinL's Avatar
Do you want it done cheap or done right?
Cheap: pull your stock bypass valve out of the J-boot and plug the J-boot hole. You'll pull in some unfiltered air and you will run rich whenever the valve is venting air... so at idle and shifting.
Right: Convert to MAP based fueling, and buy a true BOV with adjustable preload. Install a better intake.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 06-04-2007, 02:03 PM
Super Moderator
nize's Avatar
ricer 951's are bad.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 06-04-2007, 02:45 PM
thankyou that makes alot of sense. could you tell me what parts you used on your car or what parts u would recomend i get. thanks
Old 06-04-2007, 04:31 PM
Super Moderator
nize's Avatar
this is exactly what you need right here;
http://tinyurl.com/ynpk8l
Old 06-04-2007, 04:54 PM
is that one one that says whoopp whoop
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 06-04-2007, 06:45 PM
if you want to hear the turbo. and the release of pressurized air from the bov. all you need to do is buy a MAF kit.
not only will you ge thte sound but a hefty performance gain aswell.
87 951 = home made MBC, Large Turbo, Autothority MAF, Mafterburner, custom fuel system w. 55lb injectors, 951MAX chips, water/mentanol injection, 2-stage Nitrous injection, punched out cat, Magnaflow muffler.
944's are like kids, the average owner has 2.5.
Old 06-10-2007, 10:47 AM
Super Moderator
nize's Avatar
so awesome ! this is what you need right here for that mad tyte turbo bov sound to make your buddies jealous! yeah !
http://tinyurl.com/yp7m2p
Old 06-10-2007, 11:13 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
LOL hey now, it's a legit question he asked.
He didn't want to know where to get the JDM wheels or Altezza taillights for the 951.
On that note, where do I get JDM wheels and Altezza taillights for my 951?
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 06-12-2007, 11:27 AM
what are some good MAF kits?
'83 944
'87 951
Old 06-14-2007, 06:45 PM
well autothority has the tested and true one.
whats good about this one is it is just a pluged in venture.
bad. it costs about 1700 and has now fuel control ability,
Lindseyracing.com has a good unit, with fuel controler.
whats good about the lindsey kit is that you can control the fuel delivery (being able to adjust for larger injectors.)
it is also a bit cheaper.
since i like the "stock look" I decided to go with the autothority one which i sand blasted and painted black.
I did not pay the 1700. instead i found a used one for $300.
Old 06-14-2007, 08:35 PM
I also perfer to have one computer controling everything. so im setting my system up for a 'stand alone' in the future.
Old 06-14-2007, 08:37 PM
Engine swap pro
myskyon's Avatar
i am running the LR with the mafterburnner and i love it. i also have the evo motorsports Bypass valve and i love the sound of the blow off. from what my buddies say its pretty loud out side the car. but in side its not loud but noticeable.
Old 06-16-2007, 07:12 AM
Keithr726's Avatar
Send a message via AIM to Keithr726
My EVO motorsport bypass valve makes an obvious sound. Sounds like a BOV just not as loud and ricey. It also doesn't make me run rich.
Keith
1986 Porsche 951
Old 06-20-2007, 12:48 AM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
While we are on this thread, does anyone know of a bypass valve that will mate up to the flange style mount?
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 06-22-2007, 03:50 PM
Super Moderator
nize's Avatar
can you clarify what you mean by 'flange style mount' ?
Old 07-17-2007, 05:04 PM
THE ROTHMANS 956s had BOVs that vented to atmosphere....I wouldn't consider that "ricer" since it was 20 years ago. Turbo XS RFL bov for the 1.8t audi fits fine and with the right spring holds boost well. I have never had any problems with the set up. No unfiltered air. No crazy readings. Much stronger than the factory one. Several track cars around here run the same setup. 6 years and 30+ track days and still holding perfect. My 2cents ....
1986 951 - "MOV OVR" Lindsey super 61, 55lb inj, Spec Billet FW, Spec Stage 3 hybrid clutch, Swain Coated hard pipes, Yellow H4, GT MTRSPT LSD, GKN MTRSPRT hollow billeted Axles, Leda/koni coilovers (400/500), Racers Edge delrin and billet kit M030 bars with heim joints, Custom Baffled oil pan, PTRFLD R11 pads, Forged 3 piece alum wheels, 3" turbo back AIR CARBON LIP
Old 08-12-2007, 05:15 PM
Ornery Bastard
Here's the thing: There's zero performance difference between a well sorted diverter valve setup and a well sorted BOV setup. None.
However, with a flapper-type AFM (or even a MAF), there's no way for the ECU to meter accurately when the valve does vent. The purpose of the diverter valve is to ensure that metered air does not escape from the manifold. Unless you're running a MAP sensor based ECU, there's no way to accurately meter for fuel when a BOV vents and you _will_ run rich during those times.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 08-12-2007, 10:34 PM
Your right, there is no performance gain. I never said there was one over durabilty. If anything one could argue that the bov tied back into the intake track will help spool the turbo faster. I choose to hear the sounds of the vehicle. I have had a track session where a vac line came loose and the first thing I noticed was the sound change from the bov.
Benefits/problems are nil for sure, as is the same with running (Maybe...) rich during upshifts or llifting whilst on boost. The very same kit I mentioned comes with bits to recycle it back in and I have run it both ways (just to satify all of the "end of the world" warnings and rumors. No differance in afrs were realized.... My 2 cents and worth only what was paid...
Old 08-12-2007, 10:56 PM
