Not for the purist, but you just can't throw rocks at those number! Nice results!
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Yea, we figured around 380 or so if you take the Mustang results and the Dynapack results, combine the two and allow for the reduction in PSI. I might be talking to you about an EFI conversion this spring...............
Any time, we'd be happy to work with you on it, get you the next 60hp/100ft.lb. or more. :-)
3 restos WIP = psycho
Currently going together:
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
3.3 litre
Flowed case 7.5-1 Cr 2.5 race cams High butterfly ITB's Well massaged heads 96 lb injectors TEC3-R engine management 935 headers Twin 54mm custom built turbos 23 lbs boost water-methanol injection Aluminum rods Horsepower- you get the idea! |
beancounter
[QUOTE=kenikh;8232427]
8.5:1 CR on CIS seems pretty aggressive. Normally the territory of EFI builds IME. What boost level are you planning to run?
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
[QUOTE=jwasbury;8232999]
.8 BAR for the time being. Cams will help since off idle dynamic compression is lower than sc and stock cams. Twin plugs are there to help, as well. This is a known configuration that has successfully run 1 BAR with perfect AFRs.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 08-27-2014 at 05:52 AM.. |
Why all the compression and SC cams but stock 32mm intake ports?
From your post, it sounds like you are recommending that I should.
I would if it was my car.
I know there is the rationale that small ports = higher port velocities, and thus better low speed drivability, and if you choose follow this, no problem. You're entitled to your opinion. My $0.02: I used to adhere to this as well. If Ruf and Andial did 36mm ports, then that has to be best, right? But the more we ported heads, the better and better the cars got. More punch. More torque. More HP. More drivable. Now 36mm is our minimum size (most you can bore stock plastic injector blocks) and most of our CIS engines are 38-40mm (40mm is ID of stock CIS gasket). Heck, when SC and Carrera heads were plentiful, a lot of builders used to slap them on 3.3L Turbo engines. A 3.3L with 41.5mm 3.2L heads is by no means a lazy engine off the line.
I defer to your expertise. I'll call Ollies and tell them to add porting to the bill. Question then becomes: What's a set of aluminum injector blocks from TurboKraft run if I go with >36mm ports? Do you port the exhausts to the same spec?
I opened up my intake ports to 40mm to match them to the 40mm aluminum CIS injector blocks I have. Also opened up the holes in the flat manifold to 40mm and smoothed out the internal edges around them leading into the inside of the manifold best I could.
There's no flat spots or shortage of off the line and around town torque below 3000 rpm, none at all! Try it you'll like it
If you have a gasket set, you'll only need the blocks & insulators, $470. Exhaust ports -- I'd open them, too. At some point you're limited to the ID of your exhaust manifolds. What is the OD of your manifolds' primary pipes?
Factory Euro HEs
I would!
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
Exhaust port specs given euro HEs? 38mm or ?
I know no one wants to be on the hook for me making a decision, but unless someone has a reason to go another direction, I am leaning to 38I/38E, given I am currently running Euro HEs. Again - input appreciated and I promise I'll post a dyno pull once all is said and done to repent for diverting this thread.
Chain fence eating turbo
My car is a Carrera and has far more low end torque than a friends 965 with CIS.
I can even chirp the tires now (new 285's) by popping the throttle in first at idle speeds with my G50. I made a recent change to my EFI and discovered this. It's really torquey, and I think Carrera are 41mm ports?? Another words, do it!!
Mike Hakimi Empire Pacific Investigative Services www.epis.us epg@usa.com |
I have heard that anything over 550WHP for aircooler engine will damage the motor, unless you have the flat fan, like the 935 engine? Do any of you guys run that kind of power on track? If so how much power and how long has the engine lasted? The head is the issue from my understanding?
