OBX 930 Header Question
Sorry if this has been discussed but I can't seem to find it.
My question is, where the two parts of the headers meet, is there suppose to be a clamp or something? Do you use RTV to seal them? Just seems strange to not use anything there? Thanks in advance Spence
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
Yes, you should of got a clamp with them.
16 VW Touareg 05 Porsche Cayenne S 87 Porsche 930 84 VW Rabbit GTI |
Thanks BMAN, damn....I didn't get the clamp or any hardware gaskets etc...
Please excuse my newbieness but what sort of clamp would that be called so I can buy one?
They call it T-Bolt clamp http://www.clampco.com/products/t-bolt-std.asp
thanks a lot mate!
Me like track days
Clamp that join? On B&B that join is left slip for expansion/contraction -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
A fellow Pelacanite
Take that clamp off. You are straining everything.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
resident samsquamch
No clamp on mine; didn't run one with my B&Bs and don't run one with my OBXs. Never had a leak from this junction...
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Same on GHLs.
'77 S with '78 930 power and a few other things. |
You can force some RTV in the groove before pushing them together and bolting it up... won't hurt anything but the RTV may dry partially ruining any sealing qualities before you finish moving it around getting the header flanges onto the studs and around the oil line next to the #3 cylinder.
that can go quickly or be a pain in the... I have to have the B&B stainless braided 90degree oil line fitting loose while fitting the headers onto the exhaust studs to manuever things around, then position and tighten it as the headers are snugged up. That B&B header joint there is around an inch deep and a snug fit. I've never heard mine leaking so it's not a problem. Clamping sounds like a bad idea since the headers and the engine will expand different amounts and that joint lets the two sides move or slip away and back from each other a little during heat cycles without creating stress and eventually cracking. Clamping it will squeeze the outer pipe down a little and probably make it harder to take apart and refit in the future. |
This joint has to exapand. DO NOT CLAMP IT!!
Stephen 94 3.6Turbo 6-speed AWD |
A fellow Pelacanite
The clamps that come with headers are for the heater pipes.
Well looks like the clamp will be coming off in the spring
Macht Schnell
Hi,
I bought these used from a Pelicanite. They don't have an expansion joint at all, they are solid. I think I have some leaks inside the heater boxes. http://www.lesgarten.com/pix/porsche/DSCF0608.JPG Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT |
+ 1 on no clamp, the collector under the turbo will crack into a million pieces
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Keep in mind that the motor under boost can and will expand up to 5mm! What will happen to the pipes if solid or clamped. Something has to give!
Macht Schnell
A question. Are all Headers for 930's, with the exception of mine, equipped with some type of expansion/slip joint? Ohh, by the way, after I put the flow restrictor in the oil line, I quit smoking out the neighbors! DOH! Les
Only the ones that last. All the ones that I know of are slip fit or have an expansion joint in it to cope with the movement of an air cooled aluminum motor.
LOL, don't feel bad, I have shops all the time get mad at me when I tell them check to see if you put the ball in. I am always greeted with "well it worked fine with the other turbo" LOL, yea I know....check the ball.
spence, im thinking about trying the obx headers but i would like your feedback re: installation and performance. what kind of turbo ic etc are you running? thanks in advance , kevin
We found few nearly loose grinding pieces in them. If those go in your turbo.... Falk
87 930 bblk/blk 88 3.6 white/blk |
