LinkBack Thread Tools Rating: Thread Rating: 5 votes, 5.00 average.
beancounter
jwasbury's Avatar
Jacob's rebuild thread
And so it begins...
Engine is on the ground. Teardown will commence in the next couple weeks.
Leakdown was 44% on cylinder 6, as I mention in this thread:
Leakdown test reveals ugly truth
The engine has about 60k miles on it.
Goals:
To build a reliable street engine, with a little extra performance over stock, upgrades that are complementary to the mods I already have:
K27S, Turbo SSI heat exchanger system by Rarly L8, Rarly L8 muffler, Kokeln intercooler with full 965 intake.
Current plans are:
Take it down to the crank.
3.4 LN Engineering Nickies cylinders and JE pistons (7.5/1 compression ratio)
Heads reconditioned and mild porting (probably to 36mm)
Do the twin plug machine work (to allow for easy future ignition upgrade, just in case)
Might as well do the cams (probably SC)
New headstuds
ARP rod bolts
LN Engineering offers slip fit 100mm P&Cs which will yield a true 3.5 liter. I am considering this route.
Opinions and suggestions welcome
I'll update this thread as I make progress.
cheers!
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 08-16-2009, 08:09 PM
beancounter
jwasbury's Avatar
Special thanks to Pelican Vinny (screen name Vin-barrett), who worked with me today on my virgin engine drop. You are the man!
Jacob
Old 08-16-2009, 08:37 PM
Congrats! Who is going to do your rebuild?
Yasin
Old 08-17-2009, 04:04 AM
Blackbird Pilot
Reaper930's Avatar
Awesome Jacob - glad to see it going in for a bit more pep and a 3.4 will not disappoint! hope it goes well
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 08-17-2009, 06:13 AM
beancounter
jwasbury's Avatar
Yasin
I'm doing it with the help of this forum, Wayne's book, and a few wrenching buddies.
Jacob
Old 08-17-2009, 06:32 AM
Vin-barrett's Avatar
very cool
subscribed to the thread
-Vinny
1983 911SC
Old 08-17-2009, 06:49 AM
Crotchety Old Bastard
RarlyL8's Avatar
If you enlarge the exhaust ports or swap heads that have larger ports you should cone the gasket protectors on the SSI exchangers to match. The ID of the pipes will allow for velocity without choking with the cone transition. This will retain good off-boost torque for driveability as well. I would not swap out turbos until you are finished and see the results. If the desire is low boost street torque monster you may be just fine as is.
Old 08-17-2009, 07:47 AM
beancounter
jwasbury's Avatar
I was really only thinking of enlarging the intake side of the heads...is it a waste to do that and not touch the exhaust side? The turbo is practically brand new...I'd rather not change it. I don't plan to run more than .8 Bar.
Jacob
Old 08-17-2009, 07:56 AM
Turbo Hooligan
ohhhhhhh subscribed bro! I didn't think you'd get started on her this early. I thought it was going to be more of a winter project. If you don't plan on turning up the boost, I'd go for the 3.5. no replacement for displacement.
btw, are you going to strip out your A/C or try and recharge it?
D-Zug
Old 08-17-2009, 01:28 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Subscribed!!! ,, Make sure you document the$$$ too we'd like to see that
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 08-17-2009, 04:31 PM
Champagne on Beer Budget
HelmetHead's Avatar
Sub'd... Headed down this road too!
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 08-18-2009, 05:36 AM
beancounter
jwasbury's Avatar
A/C will remain in the car and making it work decently is on the to do list. Engine rebuild is to keep me happy, and the A/C rebuild is to keep my wife happy.
Jacob
Old 08-18-2009, 07:20 AM
Wayah Road Warrior
Shadetree930's Avatar
Where are the pics!
C'mon man ... this is the Turbo board ... we need pics of EVERY step along the way.
Start with the opening of the 1st beer bottle, then the hookers ... oh ... I mean yeah ... engine drop pics.
And DO NOT FORGET the obligatory Jacob in the engine(less) bay pic.
02 996tt White
87 930 GP White (Sold)
87 911 Targa Guards Red(Sold)
Old 08-18-2009, 09:07 AM
beancounter
jwasbury's Avatar
Some progess and some pictures
My engine sat on the atv jack for about two weeks after the drop...life got in the way plus there was a little logistical issue that required completion prior to tear down ----> I had to transport the engine from my rented garage (a few miles from my home) to my home garage. The engine move was completed this weekend, and tonight I got to make some progress on the teardown. I removed the engine tin and pulled the manifold and the entire CIS as an assembly.
Engine in the stand prior to tonight's work:
CIS injectors "pickled" in seafoam:
Manifold and CIS induction removed:
I noted that every one of the plastic CIS injector blocks had some amount of cracking. Nothing was visible from the outside, but each had a crack propagating from the inside on the cylinder head side. Cylinder #5 was the worst and there was actually oil underneath the injector block.
remember that I had 44% leakdown on #6, so I was getting a lot of blowby. Crankcase pressure was pushing a lot of oil into the intake. I think that the cracked injector block on #5 was leaking and allowed the oil to seep out. In the past I noted that the threads on #5 spark plug were oily...now I know why.
More to come...
Jacob
Old 08-31-2009, 08:08 PM
juicersr's Avatar
Great work Jake. Taking apart your motor is a fascinating journey into it's inner workings and a truly great learning experience.
Keep the pix coming.
'79 930/934 replica
80 RSR-look(Now in Sicily)
914/6 2.7 (Projekt 908/3)
1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW
D-Zug Produkte/D-Zug.com
Old 08-31-2009, 09:40 PM
juicersr's Avatar
PS - Is that your Duc in the corner? Mandatory pix of her without the cover at some point in this thread.
'79 930/934 replica
Old 08-31-2009, 09:42 PM
onboost's Avatar
Jake..
Looks like you're making great progress.. better than me the last few weeks! Good luck and enjoy the journey.
Paul
RGruppe #180
Old 09-01-2009, 09:16 AM
Turbo Hooligan
Keep the pics coming Jake, and I 2nd the mandatory pics of the Duc!
D-Zug
Old 09-01-2009, 10:36 AM
spence88mph's Avatar
no matter how many rebuild threads I see, I enjoy reading another, subscribed, great stuff!!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 09-01-2009, 10:38 AM
torresmd's Avatar
Subscribed as well. I would love to tackle something like this someday.
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 09-01-2009, 03:40 PM
